Introduction: Using the Align Tool in Tinkercad
Picture of Using the Align Tool in Tinkercad
I use Tinkercad to do all of my 3D designs and have learned a lot from all the tinkering (ahaha) around I've done. One of my fellow interns at Digilent asked a question about how the align tool works, so I figured I would write an instructable about how to use the align tool.
Step 1: Select Two Objects
Picture of Select Two Objects
When you use the align tool, you'll likely be trying to align two objects in your design. The first step is two select whatever two objects you want to align.
You can click and drag around them to select them or hold shift and click both items.
Step 2: Open Align
Picture of Open Align
Next you'll need to find the align tool. The align tool is located in the upper right corner in the adjust menu.
Step 3: The Align Tool
Picture of The Align Tool
You should now see the dots and grid of the align tool. I will go through each dot in this Instructable.
Step 4: Preview Align
Picture of Preview Align
Note that if you hover your mouse over one of the dots, you can preview what the align tool will do.
Step 5: Align Horizontal
Picture of Align Horizontal
The 3 dots in the front are to align horizontally. The right or left options will line both objects up by the right or left edges. The center option will line the objects up horizontally by their centers. You can see an example of each type of alignment in this step.
Step 6: Align Vertical
Picture of Align Vertical
The 3 dots in the front are to align Vertically. The top or bottom options will line both objects up by the top or bottom edges. The center option will line the objects up vertically by their centers. You can see an example of each type of alignment in this step.
Step 7: Align Depth
Picture of Align Depth
The 3 dots in the front are to align by depth. The back or front options will line both objects up by the back or front edges. The center option will line the objects up by depth by their centers. You can see an example of each type of alignment in this step.
WillB31 (author)2015-12-13
When I align one shape to another, how do I indicate which shape is supposed to move, and which one stays put? It doesn't seem to matter whether I select A, then hold shift and select B; or select B, then shift-select A: Shape B always ends up moving, and I need it to stay put, because it's already aligned with a bunch of other stuff. Am I missing some secret technique?
After your objects to align are selected click the object you want to stay put. Now use the align handles
That works perfectly! THANK YOU!!! I was trying like crazy to figure out how to do this.
photostashbiz (author)WillB312016-03-21
Try grouping the shapes you need to stay together, then align, then ungroup if need be. I'm just learning myself, so take my advice with caution! ;-)
ChrisW545 (author)2017-06-29
This looks gret, but I can't see what I came for and I wonder if you can help me. How do I tell the align tool that I specifically want A to move to align with B so that B does not move at all? I've had some success with locking B but it's not consistent. Thanks for any help you can give.
hardwarejunkie (author)2016-12-27
Thank you! It was very helpful.
DetlevB1 (author)2016-07-29
Thanks for your support. It really helps to get along quickly. Keep on like that.
y2kgixxer (author)2016-04-28
Great Write-up +1
Shantell_Martin made it! (author)2016-02-19
This helped me out a lot I was only clicking one object to align and that is why it was not working for me till now.
VictorB41 made it! (author)2015-10-20
Nice instructions.
Thanks a lot.
SuperRistopaha. (author)2015-08-27
Thanks! That was helpfull!
eLab (author)2015-06-14
That's a very useful tool!
kbray3 (author)2015-06-10
wish I had this a few days ago before I wasted hours trying to figure out what I needed to do to align objects. I wonder if they will ever bring the command line to tinkercad.. anyway great instructable
About This Instructable
25,662views
11favorites
License:
More by Commanderfranz:Decoding VGA Signals With a Portable Logic AnalyzerHow to Use the Protocol Analyzer on the Discovery to Test SensorsAnalog Discovery 2 Quick Start
Add instructable to:
