3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Utilising Credit Card Offers To Get The Best Deal For You
A lot of people nowadays are using more and more credit cards – it is certainly not unheard of to have multiple cards, typically using some for larger purchases and other for smaller ones. But even if you are fairly savvy when it comes to credit cards in general, have you considered a credit card balance transfer?
What are balance transfers?
Simply put, when it comes to using a credit card there will be an interest rate on the credit that you use. However sometimes that can get too high, or you may feel you can get a better deal elsewhere, and with credit cards with 0 interest on balance transfers, this is certainly true.
If ever you feel that the interest is getting too much, consider transferring your money onto a different card, with a much lower or non-existent interest rate.
What to look out for
However some credit card balance transfers will come with strings attached. Most often, any deals offering you extremely low interest rates will be only for a certain time period, for example credit cards with 0 interest on balance transfers may be such for a few months at most, or maybe other money which you then put in will have a higher rate.
What you must take care of in this is in order to avoid any exceedingly high rates after the trail period is over. Sometimes certain card companies will offer a really low rate only to trick you into staying on and then setting an extremely high rate – ensure that you always read any fine print in whatever contract you sign in order to avoid this.
The benefits
That said, there are also a huge number of benefits to credit card balance transfers, such as the fact that you can move your money around whenever you feel the need to, in order to try and keep your costs in interest as low as possible.
If you are able to find a company that offers you a very low rate and then keeps the rate fairly low after the time period is over, you may feel tempted to stick with that company. But if you are able to save even more by hunting out other introductory offers, then why not?
Credit cards with 0 interest on balance transfers can save you a lot of money, and if timed correctly you can move your money around with relative ease, allowing you to avoid paying the ever increasing interest rates on your money.
However some companies will obviously be averse to this and it is likely that there may be a minimum contract term, so be sure to look out for this.
Is this right for you?
When it comes to your money ultimately the decision is up to you. But anyone who has done their research into credit card balance transfer will easily vouch for the benefits of doing this. Once you get used to how it all works, if you are careful to start out with whilst you are learning the ins and outs of it, you can find it relatively easy to transfer your money between different accounts and so save yourself a lot of money, whilst gaining any other benefits and introductory offers of a particular credit card.
Obviously what it comes down to is how much you use your credit card, and the amount of use will affect just how many times you choose to do this. But so long as you look into every aspect of it and make sure not to fall foul of any potential traps, you can save a lot, just make sure you look for expert advice if necessary.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:imaculatejohnson(SEO Peace)
Imaculate Johnson is a Content Writer by profession. She is a seasonal writer at a copywriting firm since 2004, and has wrote many informative content for hundreds of clients and websites. She also ma...
more »
