With this one I am hoping to get the 100 watts.
Here is how I did it.
First we need:
--5 pvc tube. size 3"X10' (hardware store)$48
--3 bike wheels. size 12" (junk yard or ask your kid to use their bikes for a minute) maybe $5
--Ametek38 volt (ebay or surplus store) $60 (a problem with ametek, it needs 500 rpm to reach 14.1volt.
--Or buy windblue alternator (ebay) $250 it will only need 200prm to reach 14.1 volt
--1 square foot 1" plywood or anything 12" diameter (laying around)
-- 3 X 2x4 X 12' studs (from lumber store)$11
I am not going to name the tools, but I used the usual tools.
faroun
Remove these ads by
Signing UpStep 1PVC pipe
2-Using a template, to where I want the hole so the pipe did not travel past the rim, I simply drilled the hole (as shown in the photos)
3-I laid the 1/2 pipes down alternating ends. We all know that the pvc has one end wider than the other to be able to fit to each other (phlange)
That was it for the pvc..really ...that was.
faroun
the drum or savonius works on tork and most will not excceed 200rpm.
lift is more effecient, but the rpm causes few issues so it has to be build well.
sam
i cant promise a full instructable, and i am so bussy at this time.
maybe in the future i will create it.
i have about 17 vids on you tube to see the Evolution.
regards
sam chamas
Looking at the photos, I'm thinking that you really cant turn the vanes any more towards the *outside* of the rim because you wouldn't have anything to attach to the rim. The way the vanes are constructed requires the orientation shown. If the builder had left a small ring at either end, that ring could be attached to the rim, allowing the vane to be rotated so that the concave face presents more 'windwardly', but this would make constructing the vanes MUCH more difficult, with little realized difference.
@Faroun:
Have you considered twisting the vanes along their length? As half a pipe, the vanes should have much greater flexibility around their vertical axis. You could rotate the rims w/respect to each other to twist the entire assembly. Would be interesting to see if it had any effect.
I like this design a lot, Nice Job!
regards sam
I was noticing the other day that wind gets greatly accelerated when it goes around the corner of a building, so I thought this would be the ideal place for mounting one of these turbines. How much vibration do they make? Would it cause structural problems for a building it was mounted on?
sam
you have my blessing and permission.
be carefull when handling power tools, i am sure an adult will giude you through your project.
Exccellent Choice and good luck.
regards
Although i am not sure about the Alternator or the volt, im sorry but if i cant get my hands on them i may have to do something different, even though ill try my best to make it
the letter "V" stands for the num,ber of pvc Vanes, v10 has 10 vanes at 3"
V8-4" has 8 Vanes at 4".
the intersting design got the GSD at harvard attention.
http://www.greenenergywindturbine.com/harvard/preview.html
regards
sam
Looks like the photos on the link you give actually designed the center bulge in.
I'm seriously thinking about building one but I'll build my own alternator. I have a few links on this if you haven't seen them already.
http://www.windstuffnow.com/main/projects.htm
http://www.otherpower.com/wardalt.html
http://www.otherpower.com/wardmil.html
