3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
V10 (vawt,savonius,vertical axis,windturbine,ametek)
Step 4PVC blades Assembly
PVC blades Assembly
  • last photo ←
Before you start you need to know that the spaces between the spokes vary closer to the centre, so use the wider side of the pvc on the more loose separation between the spokes on the wheel, that is why we Alternated the pvc end...remember.
1- Slide all bike Rims in place first
2-Screw the end rims first, one PVC at a time.
3-Once you finish the end Rims, then you screw down the mid one.
faroun
6 comments
Feb 4, 2011. 8:19 PMjj.inc says:
I see allot of PVC VAWT's with the blades crammed together like on this, I also see 55gal. drum ones that have two blades stacked up with more drums. Is one really better or are they just two different ideas.
Oct 3, 2010. 7:12 AMPhred1701 says:
@al_taka:
Looking at the photos, I'm thinking that you really cant turn the vanes any more towards the *outside* of the rim because you wouldn't have anything to attach to the rim. The way the vanes are constructed requires the orientation shown. If the builder had left a small ring at either end, that ring could be attached to the rim, allowing the vane to be rotated so that the concave face presents more 'windwardly', but this would make constructing the vanes MUCH more difficult, with little realized difference.
@Faroun:
Have you considered twisting the vanes along their length? As half a pipe, the vanes should have much greater flexibility around their vertical axis. You could rotate the rims w/respect to each other to twist the entire assembly. Would be interesting to see if it had any effect.
I like this design a lot, Nice Job!
Sep 21, 2009. 7:00 PMal_taka says:
I'm laying out my vane design right now and I came across this step above. What was the reason that you have the open end of the vanes facing mostly into the turbine instead of having the open end facing the incoming air? Also, I chose an odd number of vanes so birds will see very little light through the spinning turbine.limiting their kamikaze effect. Your advice on wasted air inside turbine made me think to use 4 to 6 inch pvc vanes. Thanks for your advice Al
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
69
Author:faroun(Wrapwind)
