V8-4" is made from the follwing:
-8 x 4"x10' PVC pipe cut to shape as in rendering($11.89 each)(95.12 total)(vanes)
-2 x 3"X2" permanent caps (sewer pipes aisle)($2.99 each))($5.98 total)(brackets)
-1 X 6" bike axle from an old bike (free or few $)(top axle)
-1 X 5" long male/female adaptor (arbor) ($7.99)(bottom connection)
-1 X 12" hard plastic tricycle wheel (free)(center bracket assembly)
-24 X 1"x1/8" screws ($1.99)(screws)
-1 X Ametek dc motor ($60.00)(generator)
-frame made from 2x4 ($11.00)(frame)
Total of::: $182.08
My Goal Still is to generate 100 watts at 35km/h
So I hope you guys enjoy this one like the ones before it.
Regards
Faroun
Remove these ads by
Signing UpStep 1Vanes
I have cut the vanes to shape as designed in Cad. this design is much more effective in retaining the wind and producing rotation energy. trust me i tried many diffrent cuts and i wasted alot of money to come up with this one, so take my advise.
note: I rendered a drawing for you to see how to cut your vanes (PVC).
I hope I explained it correctly..
And A 1/8" hole is drilled at each side and it is 1" from side and 1" away from bottom.
Again you have to alternate the pvc pipes because of the flange end.
That is it.
Regards
Faroun
but if i remember right the electrons flowing through the wire create a magnetic field in the opposite direction just like dropping a magnet down a copper tube. If you havent done it look it up on youtube its pretty sweet.
my experience I get 67vdc at 2600 rpm (before replacing about 45vdc at the same rpm) . neodimium magnet size 1"x0.5"x0.25" and the I completed test this motor for wind turbine 12vdc @ 240 rpm.
very cheap and simple way to reduce rpm ametek 38vdc motor for wind turbine.
the last vawt i made is the V18-4" http://www.youtube.com/watch?v=3QOoMPLGD6c
and now i am working on a FAWT silo, i have not done fancy testing yet, i am still building turbines. http://www.youtube.com/watch?v=AKvhCEr7oUY
i am going to post pics soon on my site to show the Fawt Silo
thanks
If it works it will also solve your problem of the air hitting the ground. They come in any size.
http://www.surplussales.com/HeatVentAir/fans-squirrel-cage.html
The magnets are only 9.00 each, and the pillow blocks keep everything centered.
Here's a link:
https://www.surpluscenter.com/item.asp?UID=2009091717050656&item=1-2345-C&catname=
The wind coming out the bottom is a concern, use a curved cone shaped deflector under your fan to redirect the air.
Or flip the fawt upside down to shoot the air straight up, (too much work).
On a side note:
Did you see the Windmill that makes water for people living in the desert. It drives a small compressor that acts like a dehumidifier and extracts water vapor from the dry air.
Amazing.
the only new thing is that i got lucky and contacted by a very prestigous person who asked me to send him one of my turbines the V8-4" to Harvard ECOLOGICAL URBANISM Exhibit, i shipped it last month and now it is on display i am hoping to get pics for you guys to see it.
here is one pic that i found on the net.
http://www.flickr.com/photos/quilian/3401946567/
best regards
