V8 vawt,savonius,vertical axis,windturbine,ametek)
http://www.vawt.tk After making the V10 I realized that off the shelf, cheap dc Motor requires alot of RPM, I do not want to gear something made of so light material that it does not have the mass to sustain the rotation, so I decided to design and build one that has more RPM yet has the same Blade area and that is when I decided to build the V8.
V8 is made from the follwing:
-8 x 3"x10' PVC pipe cut to shape as in rendering($9.89 each)(79.12 total)(vanes)
-2 x 2"X1" permanent caps (sewer pipes aisle)($1.99 each)(brackets)
-1 6" bike axle from an old bike (free or few $)(top axle)
-1 5" long male/female adaptor ($7.99)(bottom connection)
-1 9" hard plastic tricycle wheel (free)(center bracket assembly)
-24 .75"x1/8" screws ($1.99)(screws)
-1 Ametek dc motor ($60.00)(generator)
-frame made from 2x4 ($11.00)(frame)
Total of::: $164.08
Goal is to generate 100 watts at 35km/h
So I hope you guys enjoy this one like the ones before it.
Regards
Faroun
Step 1Vanes
Vanes
  • last photo ←
The Vanes are made from white 3" PVC cut down the center.
Later, while it was spinning I realized that it was losing air in the middle, so I modded the vanes by adding another section of pvc in the middle. The photos will explain more of what I am saying.
But in future I should have cut the vanes to shape and that will double the cost of the pvc to $75.00.
note: I rendered a drawing for you to see how to cut your vanes (PVC).
I hope I explained it correctly..
And A 1/8" hole is drilled at each side and it is .5" from side and 1" away from bottom.
Again you have to alternate the pvc pipes because of the flange end.
That is it.
Regards
Faroun
7 comments
Jun 15, 2009. 8:43 AMmosesravoori says:
It is too long,make it short and widen it so that u have gud power and also bearings which gives more energy
Oct 10, 2008. 7:10 AMthetwobros4 says:
but how does it make is power i see no batteries or anything like that.right now i am build a VAWT and i wanted to see how magnets and ETC work?
Oct 24, 2008. 11:30 PMstatic says:
The mill drives a "1 Ametek dc motor ($60.00)(generator)" to produce power. The USNavy electronics course is on-line, and would be as good as any resource to learn electrical theory, but don't expect it to be to be a step by step manual for designing, and constructing electrical power plants.
Oct 5, 2008. 10:33 AMPKM says:
The youtube video is here for those that are interested.
Have you measured output wattage at your usual wind speed? Also, slightly more involved question, do you know how these perform with other objects close to them? I'm imagining a big rectangular frame the size of a barn door full of them- at maybe 50 watts each that's a respectable amount of power.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
68
Author:faroun(Wrapwind)
