V8 is made from the follwing:
-8 x 3"x10' PVC pipe cut to shape as in rendering($9.89 each)(79.12 total)(vanes)
-2 x 2"X1" permanent caps (sewer pipes aisle)($1.99 each)(brackets)
-1 6" bike axle from an old bike (free or few $)(top axle)
-1 5" long male/female adaptor ($7.99)(bottom connection)
-1 9" hard plastic tricycle wheel (free)(center bracket assembly)
-24 .75"x1/8" screws ($1.99)(screws)
-1 Ametek dc motor ($60.00)(generator)
-frame made from 2x4 ($11.00)(frame)
Total of::: $164.08
Goal is to generate 100 watts at 35km/h
So I hope you guys enjoy this one like the ones before it.
Regards
Faroun
v8-.mov8 MB
Remove these ads by
Signing UpStep 1Vanes
Later, while it was spinning I realized that it was losing air in the middle, so I modded the vanes by adding another section of pvc in the middle. The photos will explain more of what I am saying.
But in future I should have cut the vanes to shape and that will double the cost of the pvc to $75.00.
note: I rendered a drawing for you to see how to cut your vanes (PVC).
I hope I explained it correctly..
And A 1/8" hole is drilled at each side and it is .5" from side and 1" away from bottom.
Again you have to alternate the pvc pipes because of the flange end.
That is it.
Regards
Faroun
vawt+generator+charger controller+battery+convertor+appliance.
all i am showing here is vawt+off the shelf dc motor/generator(pmg)
if you need a custom build generator go here please http://www.instructables.com/id/Faroun-Savonius-Wind-Turbine/
thanks
faroun
Have you measured output wattage at your usual wind speed? Also, slightly more involved question, do you know how these perform with other objects close to them? I'm imagining a big rectangular frame the size of a barn door full of them- at maybe 50 watts each that's a respectable amount of power.
