Step 4Fitting it inside.
First, screw on the motherboard panel and put daps of hot glue on the platforms and quickly put on the motherboard, while making sure that all of the sockets are accessible through the panel. Now, do the same task for the hard drive.
After you have done that, slip on the power supply socket and use glue to make sure it doesn't go anywhere. Now, screw on the ground wire to one of the closest holes.
And finish the process with gluing on the power supply to the platforms on the hard drive the same way you did with the motherboard . Again, be VERY careful with the power supply, it can still shock you even if it is unplugged.
Now connect all the wires (Fan, power supply, hard drive, LEDs, power button). Try to use the shortest possible wires to connect the hard drive wires to the motherboard, as longer ones will touch the power supply and melt, or restrict air from circulating inside.
Make sure 2 thirds of your crackers have been eated.
6
comments
Add Comment
Add Comment
