Introduction: VERY SIMPLE KNEX GUN!
This knex gun is a beginners gun it only needs 50 peices this in cludes 16 reds with 3 teeth, 5 yellow half moons, 3 red rods, 11 little greens, 5 orange connectors, 5 white rods, and one blue rod. It also fires white rods!
Step 1: Build the Barrel
to build the barrel you will need 12 red connectors, 3 half moon connectors, 1 orange connector, 2 red rods, 1 little green rod, 1 white rod.
Step 2: Build the Barrel
To build the barrel you will need onw orage connector and one red rod. You will also need some scotch tape to wrap around the joint where the two pieces connect.
Step 3: Build the Handle
To build the handle you will need 4 red connectors, 2 yellow half moons, 4 green connectors, 3 orange connectors, 1 blue rod, 8 little green rods, and 4 white rods.
Step 4: Put It All Together
i will tell you how to build this gun in order of the pictuers.
1. insert ram arm in the hole in the barrel.
2.this picture show you where to put the rubber band.
3.to connect the handle to the barrel just snap it on to the red rods at the back of the barrel.
4. if you have any mods for this gun please message them to me!!!!!
