VGA Snake With Arduino Uno
Introduction: VGA Snake With Arduino Uno
After VGA Pong, I have reproduced another color version of classical game for Arduino Uno and a VGA monitor:
VGA Snake!
The link for the video is here
...and here the link for the code.
It is for a single player, it has four colors and a resolution of 120 x 60 pixels. As before, my goal is to avoid any special shield or support IC.
You just need few resistors, a DSUB15 connector (the classical VGA one) and four buttons.
Step 1: Instructions to Built Your Own Color Snake With Arduino
First you can download the Arduino game code here, then you need the VGAx libraries from Smaffer on github published here.
Once you have the code uploaded an an Arduino Uno (I have Rev. 3 and IDE 1.6.4) without errors, you can start to build your own "console".
You need:
  1. an Arduino Uno Rev.
  2. a DSUB15 Connector, i.e. a VGA female connector or a VGA cable to be cut.
  3. resistors: 2 x 68 Ohm; 2 x 470 Ohm and 4 x about 1 to 2 kOhm
  4. four buttons
  5. some piece of cable
  6. facoltative: a PC board to hold the pieces together and create your own shield
  7. facoltative: pins to connect the shield to the Arduino
Connect everything following the upper schematic.
For more details, you can read this post in the Arduino Forum.
    • Epilog Challenge 9
      Epilog Challenge 9
    • Paper Contest 2018
      Paper Contest 2018
    • Trash to Treasure
      Trash to Treasure
    Hello Rob,
    I attempted to make the VGA snake instructable and I came across a problem with the code
    Arduino: 1.6.7 (Windows 10), Board: "Arduino/Genuino Uno"
    VGAX.h: No such file or directory
    #include <VGAX.h>
    I installed the VGAX libraries, running the latest arduino software and am using an arduino rev 3
    I was hoping you could shed some light on my problem. any help would be appreciated.
    Hi HaashimR,
    after you download the VGAX library you have to unzip it (thus you get all the files in vgax-master) and copy it in the Arduino libraries folder. For instance, in my case I have:
    C:\Program Files (x86)\Arduino\libraries\vgax-master
    I have Arduino IDE 1.6.4 (Windows 7).
    I hope this helps.
    good its pretty good
