VHS Rope
42,777
283
37
Published
Introduction: VHS Rope
About: I work residential-commercial maintenance. My job makes me come up with solutions on my own, most of the time. The more things I know how to do the better, quicker, and safer I can do my job. Remember wha...
Here is my first instructable. How to make rope/cord from a VHS Tape.
(back story) I saved a bunch of recordable VHS tapes from the dumpster. I, like most people, consider VHS to be out-dated and poor quality. So in-turn I wanted to repurpose these tapes. One of my ideas was to make rope / cord from the magnetic tape inside. I was amazed to find no one else has done this (or maybe I didn't look hard enough). Thus starts the instructable.
Supplies used:
  • 1/8" metal rod (could probably use coat hangers)
  • Couple pieces of scrap wood
  • VHS tape (of course)
Tools used:
  • Drill
  • Drill bits (size of your metal rod)
  • Screwdriver (to open the VHS tape)
  • Razorblade or scissors
  • Gloves (important as always)
  • Pliers (I used linesman pliers)
Step 1: Open Your VHS Tape
This step can vary depending on the way you want to open it up. You can unscrew the screws holding it together and it should come right apart (depending on stickers covering where it separates).
Technically you could just try to smash it open if you don't have a screwdriver. However I found these VHS tapes are rather tough to break.
So it is now open and you have the tape. Hopefully the tape is completely on one spool [Be Kind Please Rewind]. If it is not, manually wind it on to one spool. And cut to separate from the other spool.
Step 2: Stretch the Tape
Here is the part that takes some practice.
First put your gloves on so you don't get a friction burn (I got one before I put my gloves on)
Now take one end of the tape in one hand and the other end in your other hand (about 12"-16") and stretch it so it thins down to a "string". Don't pull too hard or it will snap. It always eventually snaps ::Note:: You can tie two snapped ends together. If you do you'll just end up with a tiny bump in your rope.
After it is stretched, grab another 12"16", stretch that and keep moving up the tape.
I just let mine fall on the floor and wound it up after I got 20-30 feet.
Ounce you get the hang of the stretching, it goes very quick.
I did about 100 feet in about 5-8 minutes.
Step 3: Wind Your "String"
Wind up your stretched "string" I used the other blank spool that was in the cassette.
As you see in the one picture I barely went through the tape and already have a lot of "string"
Step 4: Build a Rope Making Jig
Here you need to make a "rope jig".
Hopefully the pictures show the jig I made in detail enough to "copy it".
  • Drill three holes in a line in one piece of wood.
  • Bend your metal rod into a hook shap and put it through the hole.
  • Bend the rod down.
  • Guesstimate or measure an amount before the next hole and bend 90 degrees.
Repeat this process for the other two "hook cranks"
  • Measure or guess the spacing for your hole on the other piece of wood.
  • Mark your spots and drill your three holes.
  • Push the second drilled piece of wood onto the 90 degree bent rods.
That is half of the rope making jig.
Second half is making one "hook crank" on another piece of wood.
Step 5: Create a Spacer
You will also need to make a spacer that keeps the three "strands" apart from each other while winding.
  • I cut out a circle from wood
  • Drilled three holes near the edges
  • Cut at an angle towards the drilled hole from the outside of the circle.
  • then sanded each "line holder" smooth
  • Also sanded all other edges to round
Step 6: Secure Your Jig
Now you need to secure your jig to something.
I only made a 5 foot rope here for testing purposes.
However you could set up your jig outside for 20,30,100 feet. How ever long you want your rope to be.
Step 7: Load Your Jig
  • Start by tying one end (of VHS string) to one of the hooks on the three hook jig.
  • Now lace it over to where (however far away) you put your other half of the jig.
  • Lace it back around to the same hook you tied on.
  • Do this as many times as you want for a stronger rope (I had six on each hook.)
  • Tie off that string to the hook when you have the amount of strings you want.
Repeat the this same process for the other two hooks.
Step 8: Operate Jig
Now you have your jig loaded and are ready to use it.
Moving the "handle" piece of wood up and down will turn the "hook cranks" which will be twisting your multiple strings together.
When the strings are twisted tight it is time to insert your "spacer" down at the other end where the "single hook crank" is.
Unfortunately this step needs another person to tun the single crank while you guide the "spacer back down the rope being formed. ::Note:: You do not need to pull the spacer. the tension being built up should be pushing it backwards. You are making sure it stays on, and not getting stuck.
Step 9: Whipping the Ends
Whip it... Whip it good!
Ha... Anyway tying up the ends is called whipping the end.
When your spacer is at the end (near the three "hook cranks") you need to whip the end. Or in other words. You have to tie the end so it doesn't unravel. Do this before you remove the "spacer"
After you whip both ends...[[ Important BOTH Ends ]] You can remove it from your jig by cutting after your whipped end.
Hopefully this picture helps with how to whip it.
Step 10: Your Done...Thank You
Ok. You should now have an amazingly strong cord / rope made from a VHS tape.
Possible uses of your new rope:
  • Add it to your pack for backpacking (it's very light)
  • Tie down your tent
  • hang up a bird feeder
  • Make a leash for your dog (how thick did you make your rope)
  • Use in one of your next DIY projects!!! :)
Outdoor Workshop Contest
Runner Up in the
Green Design Contest
Runner Up in the
    • Stick It! Contest
      Stick It! Contest
    • Woodworking Contest
      Woodworking Contest
    37 Comments
    SAFETY ALERT: VHS tapes are covered in a very thin layer of heavy metals, which makes them TOXIC to touch. The metals can absorb through your skin. The metals allow them to be magnetized. This is why they are not recyclable. THEY SHOULD NEVER BE HANDLED WITH BARE HANDS FOR ANY REASON. Making a usable item such as a rope by hand is (unfortunately) a terrible idea.
    Thank you for your "Safety Alert". (knowing my response may cause other
    responses, here we go) Yes VHS tapes have a layer of metals on the Mylar
    tape. Like (If you are old enough to remember) 8-Tracks and audio
    cassette tapes. Every day we touch "acceptable level toxic items" Our
    drinking water has "Heavy metals" in it. Some of which our bodies
    actually need. There is more of a toxicity "safety alert" for changing
    the toner in your laser jet printer. Thank you your attention to a
    possible issue (if not wearing gloves)(and don't eat the rope).
    "Terrible ideas" are how inventions are made......(Random quote ) "We
    are the music makers, and we are the dreamers of dreams"
    FYI, VHS tape is usually made of mylar, which is why it's so strong.
    However as plastic without UV protection it will probably break down in the sun over time.
    tell that to all the cassettes and videotape's I've seen stranded on the side of the street.
    Do you know the breaking strength of your rope?
    The rope I made (18 strings) held at 150 pounds.
    Thank you. I like your bracelet. I have also made chainmaille bracelets that are similar in design.
    Thank you, I'm glad you like it :)
    the jig could likely work for cut up shopping bag loops as well. Great idea for the VHS tape!
    SO INTERESTING and usefull tip to recycle that, why dont you upload a video showing how much weight have yoou charged with it? seem so good to know how strong is that rope . also, a single vhs tape how much meters yields of rope ?
    congratulations and regards from mexico
    I got about 200 meters of "string" and didn't use the whole tape. So a guess, per tape, would be anywhere from 300-450 meters.
    great idea! i will try that for my next victim! lol. j/k
    Whenever your in a "bind"....muwuha ha ha ;)
    I like the rope making jig better than the actual VHS rope!
    Thanks. I probably could have made two mini instructables. :)
    I think one can at least approximate larger breaking point weights with a simple lever, e.g., your 150 lb test on the short side of a 1:2 lever would equate to 300 lb, assuming negligible friction at the fulcrum.
    Any word on how well it weathers? Any tests on it's breaking strength for three strings? Six? More?
