The operation is quite simple, the USB cable connects to a thumb drive inside the device. The thumb drive has been cracked open to expose the circuit board, USB power and the drive LED output has been tapped into. These 3 points are wired to a small circuit board, there is a circuit that stretches the drive pulses into an on or off signal that is buffered by a transistor to power the internal motor and LED lights. The pulse stretcher was needed since the USB drive would flash when it was being accessed. This would have caused the motor action to be very jerky and the internal lights would also have flashed.
The cost to purchase all the parts for this project should be between $10 and $15 depending on the deal you can get for the USB thumb drive and assuming that you have a few items in your parts junk box. Construction time should be 3 to 4 hours but it took me longer since I took a ton of pictures along the way and has some belt drive (or should I say rubber band drive) issues.
I am posting this project here since many of you may not have seen it on Hacked Gadgets.
Remove these ads by
Signing UpStep 1Gather the parts you need
- VHS Tape
- USB Cable
- DC Motor
- Thumb Drive
- 4 X Blue LEDs
- 4 X 68 ohm Current limiting resistors
- 3 X Diodes
- 1 X 220 ohm resistor
- 1 X 1000 uF capacitor
- small perf board
- hook up wire
- hot glue
- Rubber band
In the next iteration, though, why not make the cable detachable? That would make it possible to make it a kind of "secret safe" that can store important files safely on your shelf of VHS tapes that no thief would even think of carrying off.
1 TB for 100$ on harddrives and 10$ for 16GB flash, it just doesn't make sense.
I once had to service PDP4 computers with a whopping 16kb of core memory. It was 20k$ at that time(the memory only), but it was used to control Mega$-machines so i had to keep it alive.
http://www.corememoryproject.com/main.php
But seriously, a 1TB is sold for 110 Swiss franks with the actual exchange of 1.10 SFR/$ that makes exactly 100$. See here:
http://www.microspot.ch/microspot/category/Festplatten_Intern_Samsung/II_Festplatten_intern&manid=Z00069/detail.jsf
With the flash drive, i was too low. I must have seen a 8GB for 10$ in a add. The 16GB are more like 30-40$, sorry for that. By the way, the prices for hardware have been historically lower in the US. But lately, the prices seem to converge. I didn't see much difference last July when i was in Silicon Valley.
10 PRINT "DONT BOTHER!"
20 GOTO 10
CSAVE "DONT.BAS"
Oooh...this has been done before,i bet a pile of tapes could be uses to store several gigs of space!
Maybe even a terabyte
A British firm has launched a storage device that enables home users to backup PCs with VCRs.
Backer 32, from Danmere, allows users to store up to 4GB of information on one four-hour videotape.
The company is marketing the Windows-based storage product to the home user who may find the low price point more attractive than larger and pricier peripheral storage options like Zip drives. Backer 32 retails for a suggested price of $69, compared to Iomega's 100MB Zip drive, which costs around $200. Traditional hard drives go for still more.
The product, designed for PCs using Windows 3.1 or higher, can perform the data transfer in the background while the user runs other programs.
Backer 32 uses either an internal 8-bit ISA PC expansion card to connect from a PC to a VCR (or camcorder), or an external interface between the PC's printer port and an external module. Both transfer data at speeds up to 9MB per minute.
Backer 32 is available directly from Danmere or through distributors.
