3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
VHS Tape Storage Drive
Step 5Wire up the Thumb Drive
You will need to solder wires to the USB positive and negative connections. Have a look at this USB pinout page for information or just meter the outside pins to determine the polarity. Some helping hands will make soldering the connection easier. I would recommend using some helping hands that have a magnifier built into them. The third connection that you need to solder to is the LED output that was identified in the last step. One word of caution here, I soldered to the surface mount resistor to access the signal and it worked fine but broke off a few minutes later. Even though the gauge of the wire was small it had enough leverage to pull the solder and pad from the surface mount device. I had to scrape the solder mask from the trace and solder to that. Once I confirmed that it was working I poured hot glue over the entire device to make sure there was no more strain on any of the connections.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
46
Author:abbtech(Hacked Gadgets)
You can see my blog here: http://hackedgadgets.com and my personal site here: http://alan-parekh.com
