Wouldn't it be nice to have an inexpensive little box that cut the mains voltage down by 5 or 10%? Well, here it is!
This instructable shows how to make a "vintage voltage" adapter (as described on the GEOFEX website), using a transformer and parts easily obtained at the local "big box" hardware store. I highly recommend you read the GEOFEX article for background before continuing.
NOTE: This project involves dangerous and potentially lethal mains voltages. Do not attempt this if you do not have experience working with 120V.
NOTE: Most solid state equipment made from the 1970s on has no problem with slightly higher mains voltages.
Apologies, this article is North-American-centric, because I have no experience with other voltages worldwide. :)
Remove these ads by
Signing UpStep 1Obtain the parts
- an outlet box
- an outlet extension box (no bottom)
- an outlet box cover (with one switch and one outlet) (1)
- a replacement "tool power cord"
- an outlet
- two cable clamps
- a center-tapped 12v6 transformer, 3 to 5 A secondary (e.g., All Electronics TX-125)
- a fuse holder (e.g., Mouser 576-03453LS4X for 3AG size fuse)
- A fuse, suitably sized for your transformer (3 to 5A).
- wire, screws, nuts, lock washers, solder, crimp-on-connectors, etc.
(1) The ideal cover would be one outlet, one "blank," but I was unable to find one.
Reminds me of something the fella at a local electrical repair shop told me about this town's power, up until the 60s, before the town was attatched to the national grid, half of the town was powered by DC, and the other half was AC, as we had two power stations here (part of one is still in existence, but obviously no longer used for power generation, it's a "professional clothing" warehouse these days)... :)
Makes me wonder how we ever got along with such crazy electricity supplies here in the UK... :P
Do you know what happens if the primary goes open circuit (a common failure mode of mains transformers)?
PCBPolice Electronics Forum - we need some users....please!
Sorry for the confusion.
Some vacuum tube/valve equipment, due to the high internal DC voltages used, are potentially subject to overstress.
Relatively little tube equipment has been made since the 70s, mostly guitar amps and high-end stereo equipment.
Some folks might use this box to deliberately under-volt their tube guitar amp to "brown" their sound. lol
--mark
