ARDUINO BASED VOICE ACTIVATED HOME APPLIANCES
10,420
212
14
Published
Introduction: ARDUINO BASED VOICE ACTIVATED HOME APPLIANCES
ACTIVATING HOME APPLIANCES with voice using bluetooth is a simplest way of making your home "A SMART HOME". In this series of STEPS.we are going to find out how cool is that to switch on the fan by simply sitting in a place.
INTERESTINGLY you can command your ARDUINO like "IRONMAN COMMANDS JARVIS"
i had made a sheild for arduino and bluetooth.ARDUINO is at the back of the board.
Step 1: HARDWARE REQUIRES
COMPONENTS
1) ARDUINO UNO
2) HC05
3) RELAY BOARD
4) ANDROID PHONE
5) JUMPER WIRES
6) LAMP
CONNECTIONS
BLUETOOTH --> ARDUINO UNO
Tx --> (0)Rx
Rx --> (1)Tx
5V --> 5V
GND --> GND
2ND PIN OF ARDUINO --> RELAY’S 1st pin
3RD PIN OF ARDUINO --> RELAY’S 2nd pin
Step 2: Step 2 :SOFTWARE REQUIREMENTS
ARDUINO IDE
BLUETOOTH APPLICATION
This project is done in arduino ide and it’s available in the following link https://www.arduino.cc/en/Main/Software
The Bluetooth application we used is AMR VOICE. This application converts the voice commands we give into text and then it transmits them to the arduino via serial communication. The application can be downloaded by this link https://play.google.com/store/apps/details?id=robotspace.simplelabs.amr_voice&hl=en
Then the same is read by arduino as strings and then it performs the switching function of household items with the help of relay circuit.
Step 3: PROGRAMMING
the simple and easy program to do such a project explained below
// VOICE CONTROLLED HOME AUTOMATION
#define light 2 //CONNECTED TO RELAY 1
#define fan 3 //CONNECTED TO RELAY 2
String voiceString;
String light1="*tesla turn on the lights#";
String light2="*it's too dark tesla#";
String light3="*lights on tesla#";
String light4="*tesla turn off the lights#";
String light5="*turn off the lights#";
String light6="*i dont need lights now#";
String fan1="*tesla please turn on the fan#";
String fan2="*turn on the fan please#";
String fan3="*fans on tesla#";
String fan4="*tesla please turn off the fan#";
String fan5="*turn off the fan tesla#";
String fan6="*tesla i dont need fan right now#"
String FL1="*turn ON everything#";
String FL2="*it's too dark and hot tesla#";
String FL3="*i want fans and light#";
String FL4="*turn off everything tesla#";
String FL5="*no need of fan and light tesla#";
String FL6="*turn off everything tesla#";
String GD="*good night tesla#";
void setup() {
Serial.begin(9600);
pinMode(light,OUTPUT);
pinMode(fan,OUTPUT);
delay(3000);
void loop()
while (Serial.available())
delay(10);
if (Serial.available() >0) {
char c = Serial.read();
voiceString += c;
Serial.println(voiceString);
if (voiceString.length() >0)
if((voiceString.equalsIgnoreCase(light1))||(voiceString.equalsIgnoreCase(light2))||(voiceString.equalsIgnoreCase(light3)))
digitalWrite(light,HIGH);
else if((voiceString.equalsIgnoreCase(light4))||(voiceString.equalsIgnoreCase(light5))||(voiceString.equalsIgnoreCase(light6)))
digitalWrite(light,LOW);
else if((voiceString.equalsIgnoreCase(fan1))||(voiceString.equalsIgnoreCase(fan2))||(voiceString.equalsIgnoreCase(fan3)))
digitalWrite(fan,HIGH);
else if((voiceString.equalsIgnoreCase(fan4))||(voiceString.equalsIgnoreCase(fan5))||(voiceString.equalsIgnoreCase(fan6)))
digitalWrite(fan,LOW);
else if((voiceString.equalsIgnoreCase(FL1))||(voiceString.equalsIgnoreCase(FL2))||(voiceString.equalsIgnoreCase(FL3)))
else if((voiceString.equalsIgnoreCase(FL4))||(voiceString.equalsIgnoreCase(FL5))||(voiceString.equalsIgnoreCase(FL6)))
voiceString="";
Step 4: READY TO GO
Open the app and connect to the Bluetooth module.
If connected THE GREEN/RED LED IN THE HC-05 WILL GLOW ONCE EVERY 3 SECONDS.
Once connecting speak to the arduino with the commands you had set for the lights and fan to be turned on and off.
one of the SMALL DEMO is shown in this VIDEO.
    • Oil Contest
      Oil Contest
    • Planter Challenge
      Planter Challenge
    • Clocks Contest
      Clocks Contest
    14 Comments
    may i know what is that blutooth shield which is used ? and can you show a proper circuit diagram or this , please reply as soon as possible sir please
    can you write a code for 4 relays pls
    I was thinking of making this project but by mistake I bought a remote controlled relay in place of a normal one and return of the product does not seem possible. So plese tell me if I will be able to make this with the help of remote controlled relay??
    check out how the relay works and try to find out an optimum solution to run it properly.
    if not send me the relay details and datasheet for the same. i'll help you with it...
    I searched online and came to conclusion to control the remote of the relay to arduino but that seems to complicated and I might not be able to do that as I am a beginner. So I will make any other project with it.
    But I have bought a regular 2 Channel relay module but I don't know how to connect 2 devices(a bulb and a fan) to it. I read online that I have to connect the power line from mains to COM pin of relay but I don't know what about the other relay to control the second appliance as there is only one wire which supplies the power. Can you please tell me how to connect both of them to the relay?
    Thank u for your help :)
    Would you please post a link for all the components to buy them online, please give me specifications of the relay board and the shield
    there are many online sites available for you to check out with products. i hope it will be costly. and since we are selling those products in affordable rate you can ping us to this mail
    altsense2015@gmail.com
    Video will be coming soon...
    Most relay boards are provided with 3 terminals for connection. The middle one is the "common' terminal with NC and NO on both sides. Relays work just like switches.
    All you have to do is to take the two wires connected to the switches on your switch board, give one to the common terminal and the other wire to either NC or NO.
    The coding can be changed according to the connection. ie., if you have connected the wire to NC, make the relay pin LOW. If connected to NO, make the relay pin HIGH
    what are the components that you have used here? i think tou havent mentioned all the components here and it will be great if you instruct me how to connect this device to our home circuit.
    thank you
