Step 4: Sir not appearing in this film
First key on means you don't start the car... it's just keying on to check lights, program the computer, etc.
Key on
Now, open your VCDS software with the cable plugged into the DLC connector under the drivers side dash you should still have apart
Go to Engine
Go to Coding
Change the coding from 1 to 2
Save
Exit
Key Off
Key On
Go to Engine
Go to Fault Codes
Clear Codes
Exit
Exit
Now your car is configured for a manual transmission car.
put the car into reverse, you should have reverse lights, remove the car from reverse
start the car briefly, check for unusual noises
mount the tires, and take it for a quick spin
check cruise control and that all gears work properly
Come back and reassemble the interior in the reverse order you took it apart and you are DONE!
Now you too can have 50 MPG at 65 MPH!
Remove these ads by
Signing Up
Not Nice
Visit Our Store »
Go Pro Today »
