VW Beetle Turn Signal Lamp
6,989
145
10
Published
Introduction: VW Beetle Turn Signal Lamp
About: Just let it roll off your back like it was drizzle off plumage.
Father's Day is quickly approaching and you still haven't bought anything from Dad. Well look no further!
If your dad is like any other dad on the planet, he has a fascination with cars, likely including the good old fashioned Volkswagen. You may not have the money to buy him a '53 split window Beetle, but you can definitely dig between the couch cushions to find the dough necessary to complete this sentimental gift.
Overall, it took me about 45 minutes to complete this build, including taking pictures and running to Radio Shack.
Not including tools, it is totally possible to do this build for solely the cost of the turn signal. Just get resourceful. Bust apart your old walkie talkies that don't work, harvest parts, build.
Step 1: Assemble Supplies
These are the parts I had around the house that made it easiest and cheapest for me to build. You can substitute, add or subtract as you please, that's the beauty of it.
I ended up not using the plug for the bulb I bought because I bought the wrong plug for the bulb.
The bulb is http://www.radioshack.com/product/index.jsp?produc...
I found this to be the best bulb as it was one of the brightest readily available, plus the fact that I immediately knew that it was rated for 4 cells.
The hardest part to find will likely be the actual turn signal. I found mine at the local Pick-a-part for somewhere about $5. I would definitely suggest making sure that the signal comes from a non-desirable year, so you don't destroy a piece that someone is willing to pay big bucks for. Superbeetle turn signals are a dime a dozen.
Step 2: Connect Your Components
I made a stupid mistake and picked up the wrong plug for the bulb I bought and ended up just soldering the leads to the actual bulb, which I won't regret until the light bulb blows and I make the longest light bulb change of my life.
Using a SPST switch, an incandescent bulb and a battery holder, there is literally no way to wire this bad boy up in a way that it will not work. Therefore, if you haven't had much experience wiring, don't freak out, this is a great beginner project.
Step 3: Drill Hole for Toggle and Dry Fit
I would definitely suggest drilling a hole through the metal part of the signal and then continuing through the plastic VERY carefully as to not crack it. It's been through probably 30+ years in the sun. Then simply make sure that everything fits nicely inside the signal.
Step 4: Cut Cardboard Bottom Cover and Secure Components
I simply put the light on top of a piece of cardboard, applied light pressure to match the concave of the light and traced. I then cut out the piece of cardboard that is to later serve as our bottom cover.
I secured the components underneath with mostly hot glue and Velcro. You can do it however you want, but the one thing that I would say is VELCRO THE BATTERIES! so that later you can replace them easily without having to rip off tons of hot glue. I also dabbed a bit of hot glue on the ends of the screws that run through the turn signal to keep them from rattling about
Step 5: Finishing Touches
The last step is to fasten the bottom cover to the turn signal and break out the Windex to get rid of all of those bothersome fingerprints.
Wrap it up and give it to Dad on Father's Day.
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    10 Comments
    Wow! I found a brand new one of these in a box today, leftover from my Steampunk VW Bug makeover, and thought: "I bet I could make a lamp out of this!" Well you beat me to it and kudos for the inspiration! (And you got my vote;-)
    That's cute. I got the light but cant decide on whether to use a bulb or led's. Almost want to make a pair for either side of my desk.
    found all these parts for free in my backyard! Can't wait til finals are over to start!
    Cool idea. I saw a car light at the junk store a couple of weeks ago but didn't buy it because I couldn't think of how to use it :)
    very cool... and warm at the same time ;-)
    cool gift and a nice simple circuit. you should make annother instructable about that circuit you did...! you can even make it solar, your dad can set it by the window during the day, and when he comes home from work, it'll be charged !
    It is a flashlight bulb rated for 25 hours. It's more of a novelty than a flashlight haha
    What's up buddy?
    I guess the lightbulb was not burnt out because people dont use them that often
