Tired of having to plot out where supports and clamps are located?
Look no furthur, because you have found the right place.
I will show you how to make an effective Vacuum Table for you CNC Machine.
Remove these ads by
Signing UpStep 1Materials
- 6" X 6" X 3/4" MDF
- Surgical Tubing - Can be free if you go to a hospital and get all the tubing that they use for I.V. food bags.
- Some of the accessories that usually come with the surgical tubing (plugs)
- A Vacuum
- A Drain Plug
Tools:
- Drill
- Drill bits
- Counter Sinking bit
- Ruler
- Pencil
It would be a simple matter using your cnc to cut one track around the outside of all the vac holes of a suitable depth and width to suit the seal. I'm not sure where we bought our seals from, we had rolls and rolls of the stuff but car door seal or fridge door seal may well do the trick and it will make the trimming far more secure, no more slipping jobs.
Keith
Atleast 1 pro is that it will lift the material slightly above the table, so there wont be any risk of damaging the mill table.
:D
We didn't have a problem with the base being damaged as each job to be trimmed had it's own tool board, the cutter was set at Z= -5mm so the cutter made a groove in the base but because it was unique to the job the cutter just ran in the previously made groove on each subsequent trim. The tool baseboards were made of 18mm MDF. You could use a similar method if you plan on trimming a lot of parts that are the same.
It may be worth trying the O-rings just because it's an easier solution if it works but if not then you know how to proceed. I'll try and find out a supplier for the square section seals if I can get hold of one of the guys I used to work with but I can't promise, I'll post or pm you if I do find out.
Keith
Keith
Thanks,
Ian
