3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Vacuum & Compressor
Vacuum & Compressor
Simple vacuum pump for veneer pressing, board building. Also doubles as a low volume compressor for small airspray jobs. This is presented as a tool for building stuff, I've been using it for years and built it without documenting the process therefore its not really an 'instructable' but more of a general plan for creating the tool. All thats needed to put this together is a 1/2" wrench, some PTFE tape and parts from http://www.joewoodworker.com/veneering/welcome.htm
Step 1Pump
Pump
8 comments
Mar 18, 2006. 2:00 AMcokebottle tuque says:
your mising the point in that there are no instructions as to how you actualy made the thing. though it looks like you just modified a vacuum pump...
Sep 2, 2009. 1:00 AMemver333 says:
what type of pump did you use? Is it a 12v tire inflator? up to what pressure can it reach inside the tank? How long can you fill it up?
Apr 19, 2007. 4:10 PMstatic says:
Respectfully, I feel it would make a simpler instructable if you dealt only with the vacuum side of things. Better detail in how the connection to the vacuum bag would be appreciated. If one can't find a free volume tank,(what you labeled vacuum chamber, one can be built from PVC less expensively out of a length of pipe, and 2 pipe caps. Perhaps you had the pipe T on hand already I don't know. Anyone who has a car, has a vacuum source. Not as handy as a dedicated vacuum bench, but something to do the odd job. Those who's shop already has a good air compressor Harbor Freight sells a venturi type of vacuum pump. Some used an old refer compressor to build one with. S.
Apr 2, 2006. 3:46 PMgummiworm says:
Can this be used in the construction of high-performance solar panels? The kind of solar panels that calls for silicon and vaccums?
Mar 18, 2006. 1:04 PMcokebottle tuque says:
ok (1) did you do any wiring to control the pump by using pressure switches or is it all done manually? (2) ware did you find a vacuum gage that dident cost an arm and a leg? (3) is it just a vacuum pump with an added tank or did you change something in the pump that is not readily obvious?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
37
Author:radiorental
Appreciate what you've got, every day will bring something new.
