3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Vacuum Former 2
Vacuum Former 2
This is the redesign of the vacuum forming machine I built this past summer. Here my first design Vacuum Former and if you look at the last step you can see why I redesigned it. If you don't know what a vacuum former is check out the links on the first step of my other instructable. I'm not going to go over everything again but you can use my other instructions to build the oven, platen, and frame. Only minor changes where made to these parts and a different base was made.
First I think I should go over why my old machine didn't work and why the new machine works a whole lot better. With my other design the plastic was heated while sitting above the oven, I did this because heat raises and I thought this would heat the plastic more effectively. As you see I underestimated how effectively this method actually heats the plastic. The plastic got to hot, sagged to much, touched the coils and caught on fire. The new design holds the plastic below the oven so that when it sags it falls away from the coils. It might not heat the plastic as fast but the heating process is much more controllable.
Step 1The New Base
The New Base
The new base was made to hold the oven upside down, hold the platen directly below the frame and hold the frame in place while the plastic sheet is being heated. The base was made from standard lumber you can get from Lowes or Home Depot. I nailed it together with a nail gun but screws could be used too. It also has some small angle brackets and hex bolts. Here is a list of everything you'll need.
Materials needed for the Base:
Qty Item
1 1x4x8ft lumber
2 1x2x8ft lumber
4 1in angle brackets
4 5/16in-18 x1.5in hex bolts
4 1in wood screws (for the angle brackets)
The pdf has drawings for the oven and the new base. The base parts are VF-09 to
VF-14. There is also an assembly drawing of the base with all the parts labeled. The angle brackets were drilled and tapped to 5/16-18 threads for the hex bolts. This is so you can clamp frame to the oven while the plastic is being heated. To take the frame out once the plastic is heated you have to loosen the 4 bolts pull the frame forward and off the bolts and then just lower it onto the platen.
21 comments
Sep 2, 2010. 10:24 AMTornadoCat63 says:
O.k. everything seems good, but... what's about the air-aspiring pump? I think that an usual household vacuum-cleaner isn't enough... Please, let me know where to find a vacuum pump, efficient, reliable and cheap!
Feb 16, 2011. 11:44 AMabadfart says:
try a shop vac they are quite powerful
Oct 13, 2010. 6:12 PMtrialbyfire says:
I started building a vauum former but I used perf board for the platten which has holes about every 1/2 in (I'm guessing, I'm not with the pice right now). I havent finished my oven yet but my guess would be if you had used the perf board (That stuff you hang tools on with hooks) you might be able to avoid the webbing since it has a vacuum source closer to every piece of the parts that you are duplicating, along with letting the plastic sag a bit more. This is just a theory at this point since my device isn't finished yet but it makes sense to me.
Feb 10, 2010. 2:14 AMnabukadnazar says:
we wanna watch it while it's running. could you add some videos pls?
Aug 30, 2010. 9:16 AMMakoKatana says:
that would be excellent!
Sep 12, 2010. 8:48 PMGhost Wolf says:
yes it would!
Sep 2, 2010. 11:05 AMfly_boy_bc says:
So it is still NOT working correctly.
Sep 2, 2010. 6:56 AMpleabargain says:
It would be great if you could annotate your photos a little bit. As far as the framing is concerned, have you considered grid beams? http://gridbeam.biz/photos.htm I have found them enormously useful in speeding prototype frames/structures.
Dec 3, 2009. 9:46 AMydeardorff says:
I have landed a picture wall heater, which is basically the same as your upper section but comes pre made.
My hope is to find one more of these and make a 30 x 60 inch vaccum former. This way I can only fire up half of it when I dont need the full size, or both when I do.
Is there anything I should know electrically about these before I start hacking and cutting my wood stock pile up?
Dec 4, 2009. 6:42 PMydeardorff says:
Its about 26 by 38 inches. I was planning to just remove the painted skin or face, to expose the inner coils.
Im hoping to land two of them, so I can combine my CNC router projects with the vacuum former. I plan on making some custom car body parts.
Sep 3, 2009. 12:14 PMGM2009 says:
Oven: I am making something similar but more compact. Oven is about 380 x 380mm and four Quartz heaters each 415W. Will use 20A diode to reduce heat if needed. Instead of concrete board I am using FIBEROCK. It is light, fireproof, quite solid and can be easily cut with utility knife. Board was $13CAN. I've tested board with butane torch. Eventually it would kind of burn but only at the edges and when torch was very close. Oven will have Al underlining and U-shaped reflectors to help distribute heat. I will also use thermostat since I've salvaged (new) B&D oven. It was under $50 and buying heaters on internet would cost more. Heaters have some kind of metal shields on top of them. They have some (smartly designed) holes that let heat more at the end of the heater than in the center. Comment: I think that vacuum table needs to have better surface than unfinished plywood. That would help creating better seal.
Sep 10, 2008. 3:01 PMslimguy379 says:
whats a good site to get polystyrene? and are there any substitutes? I need a few 12" X 12" sheets. hopefully cheap
Jan 6, 2008. 9:41 PMSeamusDubh says:
Good improvements from the original design. Part of you problem with the webbing comes from the sharp squared off angles of the pieces. The way around this to either make the sides shorter or lessen the angles. Or if thats not possible, use some gloves (heavy leather) and press down slightly at the corners prior to and slightly during the vacuuming stage. Don't press down too hard or you'll leave indentations or glove prints. The pressing also helps in certain spots that might be slightly recessed.
Jan 8, 2008. 4:20 PMSeamusDubh says:
I figured as much, but at least the test run was useful.
Jan 6, 2008. 3:09 PMservant74 says:
This may be a silly question, but what kind of plastic are you thermo forming? Where would it be typically available? Home Depot? On doing the thermo forming, I assume you wait till it has 'sagged' the appropriate amount, pull the holding frame toward you, then push it back against the back uprights as you drop it (place it gently that is) on the platten and your mold on the vacuum base. Is that about right? Great instructable. TIA
Jan 1, 2008. 9:47 PMkillerjackalope says:
For the webbing, get the plastic as hot as possible and possibly a bit of extra suction, that'll reduce the webbing distance a bit but there's always a limit to what the plastic can do, though if it doesn't hurt the design you could drop a mm or two of thickness and be careful bout heating and the webbing would be lessened, as would the overall strength of the design. By the way I did and interesting experiment in making a tube on the vacuum former and found that with thick plastic you do some interesting stuff by stretching it with the vaccuum. It picks up way more detail.
Jan 1, 2008. 12:58 PMGorillazMiko says:
Cool, but I never knew there was Vacuum Former #1...
Jan 1, 2008. 12:23 PMLinuxH4x0r says:
Cool! although I personally prefer just using an iron and polystyrene
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
90
Author:dbc1218
I enjoy building things more than actually using them.
