3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Vacuum Former 2
Step 3Test Run 2
Test Run 2
  • last photo ←
I cleaned up and tested the oven and put everything together for another test. This time I had a fire extinguisher ready just in case. The plastic took about five minutes to heat up and sag about 1.5in. The oven smoked a little because of the soot and ash still in it but I think that will eventually burn off. I put some left over pieces of wood on the platen to make a tray organizer for a desk or tool box drawer.
The plastic formed pretty well but it could be better. I think I need to let it sag a little more. On one side it pulled out of the frame so I'll have to put some spacers on the frame to clamp the plastic tighter. I also need to experiment with different shapes to figure out how to avoid the webbing that happened at the corners. The shop vac worked pretty well but this could be upgraded too. Overall this is a good start though. I want to make some body parts for my motorcycle and I have a few other ideas. I hope this was enough info for you to make your own vacuum forming machine and if you have any questions just post and I see if I can help out.
4 comments
Oct 13, 2010. 6:12 PMtrialbyfire says:
I started building a vauum former but I used perf board for the platten which has holes about every 1/2 in (I'm guessing, I'm not with the pice right now). I havent finished my oven yet but my guess would be if you had used the perf board (That stuff you hang tools on with hooks) you might be able to avoid the webbing since it has a vacuum source closer to every piece of the parts that you are duplicating, along with letting the plastic sag a bit more. This is just a theory at this point since my device isn't finished yet but it makes sense to me.
Feb 10, 2010. 2:14 AMnabukadnazar says:
we wanna watch it while it's running. could you add some videos pls?
Aug 30, 2010. 9:16 AMMakoKatana says:
that would be excellent!
Sep 12, 2010. 8:48 PMGhost Wolf says:
yes it would!
Sep 2, 2010. 11:05 AMfly_boy_bc says:
So it is still NOT working correctly.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
89
Author:dbc1218
I enjoy building things more than actually using them.
