Step 2The Oven
Now we need to cut the hadibacker board. Hardibacker board is basically drywall for around showers, it used because it doesn't absorb moisture. Its made with cement so its also a good heat insulator which is why its used in the oven. You can cut the hardibacker by scoring it with a utility knife and then snapping it but that can be hard to do when you need long thin pieces. I would recommend using a jig saw to cut this board. I found out the hard way that you can't use a normal jig saw blade to cut cement board, so you will need to get a masonry blade for your jig saw. When you go to the hardware store to get it, look for one that says it will cut tile, thats what you want. The blade doesn't have teeth, the cutting edge looks like a glue/sand mixture just globed on to the blade. I started with cutting the long thin pieces first, parts VF-03 and VF-04. First I cut them to the 2-1/2in. width and left them a little long. Then I went and fitted the pieces to the frame, so that every piece fit nice and snug. You want to keep the oven as tight as possible so you don't have to worry about holes or gaps for the hot air to escape.
Now you need to make the aluminum inner lining side parts, VF-07 and VF-08. This is aluminum flashing which you can get from any Lowe's or Home Depot. I got a roll that was 14in. wide because the flashing will be used on the bottom panel of the oven which is 11in. wide. Aluminum flashing is very easy to work with and can be cut with normal scissors, I'd recommend a nice sharp pair just to make it easy. Again here cut the pieces to the 2-1/2in. width and a little long, then fit the pieces to the frame. Now screw this all together through the flashing, Hardibacker, and into the wood.
I know the animation is not the best but I think it gives you a really good idea how the oven goes together. This is my first real attempt at using SolidWorks. You might be asking how does the large sheet of Hardibacker, VF-05, attach to the plywood, VF-06. That will be explained in the next two steps.
VF Drawings.PDF55 KB| « Previous Step | Download PDFView All Steps | Next Step » |
comments
Add Comment
Add Comment
