3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Vacuum Bagging Basics
I must preface this entry with a citation for a homespun vacuum source that saved my bacon in this exercise. DrCrash has a great solution using nothing more than a hardware store bicycle pump for this project, as there was no way I'd encumber my little apartment with an unwieldy electrical unit.
Vacuum bagging is a commonly used technique in composites, and for good reason. When done correctly, your part will have a nice, uniformly distributed compression about the surface of the layup. This in turn helps to minimize any voids (e.g. bubbles and wrinkles) in the buildup of layers. Also, when used with a porous substrate made of peel-ply and breather-cloth as we'll see, it assists in having the optimal ratio of resin to reinforcement (e.g fiberglass, or carbon fiber, or Kevlar) by squeezing out the excess.
The project is quite simple for illustrative purposes. I'm making a small container from a mold of a nice tea container lid. I'll go over the steps to make this part, but the vacuum bagging phase is what this topic is about, so we'll be delving into that a bit more thoroughly.
First, a few suppliers that I've had quite good success with:
Fibreglast dot com - Lots of supplies for the intrepid.
Aerospace Composite Products - They also had the check valve and bag attachment and 1/4" neoprene tubing used in DrCrash's vacuum tool, and very personable customer service.
Tap Plastics While they don't have much for vacuum bagging, it's still a worth while source to mention with all their instructional material and from my experience, good staff.
USPlastics Is also well known supplier.
Both TapPlastics and Fiberglast have some very good instructional material that is invaluable for someone learning about new techniques.
Step 1Ingredients
Ingredients
  • vacuum bag stuff
For the hardware store bike pump vacuum:
Check Valve Only allows air to pass one way in the vacuum line. The one available at ACP appears to be for an aquarium (brand name tetra), but it works okay.
1/4" neoprene tubing Acts as the vacuum line.
Tubing clamp holds the air out of the line once the vacuum has been set
Bag Connector securely attaches the hose to the bag.
ACP has all the parts that I used to make the pump.
For the bag:
Bagging Plastic The stuff I'm using is made of stretchy and resilient plastic, and it comes in 60" wide rolls, that you can purchase by the yard from the suppliers that I mention.
Bagging tape is a ribbon of pliable and sticky material that's coiled up on itself such that one side is covered with removable wax paper. You could probably use window caulking, too.
Peel-Ply is a plastic fabric that wont stick to your layup but allows resin to seep through.
Breather Cloth Is a high-loft material placed on the outside of the Peel Ply to absorb the resin and allow the vacuum to be passed uniformly over the surface of the layup.
Knife or Scissors The bagging material is kind of hard to cut; I've found a good rotary cutter works best.
Masking Tape Holds the peelply and breather cloth together when wrapping the layup. Also good for holding down the vacuum bag plastic when making the bag
Straight edge for measuring and will help hold the bag down when sealing the edges.
Cutting mat also handy. I got this one made by Fiskars, but I found that the rotary cutter can slice through the top layer :(
18 comments
Nov 13, 2011. 6:33 AMdmanske says:
Thank you for taking the time to do this.
The sealant tape you are showing, looks like 'Butyl Tape'. I have a roll of it in my basement. It is available at any good building supply that sells metal roofing. Quality metal roofing companies (e.g. Everlast Roofing) require butyl tape during the installation along gable end edges between the rake flashing and the metal sheet. Just ask for butyl tape at a good building supply place. You may not have good luck at a big box store. Just a heads up.
Dec 12, 2010. 6:18 PMhardlec says:
Is there a picture of the finished item?
I have an adapter for my air compressor that pulls a vacuum. Would this be useful?
Not trying to be inappropriate, but: Why would a zip-lock bag fail? I ask this to learn, not to try to make an actual project with a zip-lock bag...
Feb 6, 2010. 12:21 PMtazmaniac_37752 says:
I f ya want to go to the trouble you can use a A/C compressor from a car then all you'd have to do is add a motor of somekind, they already have valves installed and you can pull about 27 lbs( which i believes varies according to your elevation!) Tks for this instructable been wondering about this very thing!
Feb 7, 2010. 12:32 PMtazmaniac_37752 says:
LOL yeah I already have one! I put hoses on one way and use it as a vaccume pump then switch the hoses and use it for compressor to run my air brush!
Feb 7, 2010. 12:34 PMtazmaniac_37752 says:
Srry what i was interested in was  the homade vaccume bags! I figured they would make great storage for my seasonal big game hunting clothes!
Mar 1, 2008. 10:24 AMSlagnaf says:
I built a vacuum pump out of an old fridge compresser to use as a desoldering station. My question is: Does anyone have any ideas about how to build a trigering device, so the the vacuum does not run all the time?
Jan 24, 2009. 3:13 PMpetercd says:
I used a vacuum advance from a car distributor, soldered on a tab that activated a heavy duty microswitch which was connected to the compressor's power. I used springs adding more to get different vacuum levels, wasn't an exact science but it worked. :)
Dec 2, 2008. 2:12 PMjamesotron says:
Just a quick question - what did you use to tint the resin?
Oct 7, 2007. 11:53 AMRagged Edge says:
Shortshift thanks for mentioning our kit. We have never really had a problem with offgasing causing loss of vacuum in our Roarockit Thin Air Press system. You may see a small loss of vacuum right after the initial pressing. I check my pressing for the first five minutes. Ten seconds of pumping with the manual pump always beings it back up to full vacuum. The small loss of vacuum is cause from the trapped air being pulled from the skateboard veneers and foam mold. Even when use epoxy in the Thin Air Press there seems to be no problem with holding vacuum. We have actually left sealed bags sit for months while travelling to find them still holding vacuum when we return. Ted from Roarockit
Oct 3, 2007. 3:11 PMdrcrash says:
Here's a YouTube video of a guy demonstrating vacuum bagging of composites.
http://youtube.com/watch?v=s12pUg9ypVU
(He's doing a bunch of carbon fiber motorcycle parts in a big bag, with an electric pump, but its basically the same deal, if anybody wants to see it in action. That video series isn't bad. If you look at the "related" tab you can find the episodes demonstrating the layup, etc.)
I suspect that the bike pump will work for big bags---maybe even Trubuchet03's fairings---if your bag is well-sealed, you have a reservoir, and you suck most of the air out with a vacuum cleaner first. After that, you just need to pump now and then to keep up with the solvents outgassing.
Oct 2, 2007. 8:00 PMtrebuchet03 says:
Nice :)
An alternative (and less likely to leak) method for going around corners with sealing tape is to place your thumb on the tape on corner (maybe slightly before to allow clearance) and force the tape to make a rounded edge. The stuff is stout enough that it will handle it just fine and maintain its seal abilities :)
Always keep in mind that the worst thing you can do to a vac-bag part is to apply a vacuum, and then release it (you're basically forcing air into places that you just displaced of resin :/)
I didn't go too far into vac bagging details - but here's a larger part made and vac bagged (for inspiration and such :p) :)
Large Part Making
Oct 2, 2007. 9:10 PMtrebuchet03 says:
Slow :p
~30mph -- but we weigh way too much (~90lbs total vehicle weight) and our fairing has way too much structure to it :p This year's goal is sub 50 pounds - so a 12-15 pound fairing is about where we want to be.
The irony is - that fairing was made on a "low end" budget - for a fairing :p
Oh,
US Composites is another good supplier (we use them and fiberglast) :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:shortshift
