3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Vacuum to Wet-Vac
Vacuum to Wet-Vac
I came up with this when I was house sitting for my parents and the basement started to flood. The original was made with a 5 gallon bucket. I have made two since and found that culligan style water jugs work better. I don't have one currently constructed, I am bored at work and piece this together with MS Paint. hehehe. But you should get the basic idea. This is my first Instructable, I've been reading instructables everyday, and I've been dying to post something. Hope this helps some of you out.
I use this same concept to piggy back 3 shop vacs together to get more suction once. My boss brought his boat out of the water this year with-out pumping out the septic tank. Of course we didn't want to ruin a shop-vac bu pumping sh** into it, and we were told that one shop vac didn't have enough pull. It worked great unfortunately we didn't get any pictures. Happy Sucking!!
Step 1Materials
Materials
The marterials you need include:
1) Vacuum with a hose
2) 5 gallon water jug (Can be a bucket, but this requires more cutting and sealing)
3) Utility Knife (or equivilent)
4) Length of hose, or vacuum tubing
5) Duct Tape
19 comments
Oct 17, 2010. 11:18 AMmttrout says:
I followed this exactly and it works awesome. I have a shop-vac but don't like how I have to take the thing apart, and then let everything dry out for a few days afterwards.
This is so nice, easy, quick and works with our more powerful vacuum to clean up spills and stains.
Thanks for the instructable!
Aug 7, 2010. 9:43 AMthebair says:
Can this be used as a leaf vacume.
Jun 3, 2010. 4:18 PMausisit says:
You can use a 25 or 30 litre home brew or chemical drum with the tap fitted for easy empty. But very smart idea in the first place simple, modifiable and obviously workable. The bigger or stronger the vac power the bigger your water catcher can be. For example a 1.5 hp vac motor can handle a 40 litre tank.
Feb 27, 2008. 6:24 AMsylvtoso says:
We needed a solution to clean the dirt out of our pond and this works like a bomb BUT the jug fills up too quickly - HELP! Do you think it would work to drill a small hole at the bottom and hook up a hose through which the water could drain?
Oct 18, 2009. 11:32 PMdjr6789 says:
you could just hook up 2 or 3 of these in series?
Oct 16, 2009. 9:12 AMkikiclint says:
probably not, since there will be a vacuum pulling in all directions, it would then just leak air pressure, taking away from your suction.  I would suggest some kind of plug, which you could turn off the vacuum, pull the plug, and 2 minutes later your ready to go again.
Jan 24, 2008. 3:18 PMRobbie245 says:
I found a cool web based tool for helping identify the causes of different types of wet basement problems. Its at http://www.b-dry.com/wet-basement-analyzer.html
Oct 24, 2007. 7:46 AMlieuwe says:
I might use this but in reverse to shoot water, I have got one of those bubble mats(reversed vacuum cleaner)
Aug 30, 2007. 10:40 AMSwartzkip says:
We use the same setup with a metal container for cleaning out the woodbuning heater in the livingroom. No more messy stuff al over the place :)
Mar 18, 2007. 12:18 PMAymericRdV says:
We use that princple in my lab all the time. If you want to have larger capacity or make sure you never accidentally suck in water into your vacuum cleaner you can hook the water bottles in series. caveat: This will only work wellif your seals are tight otherwise you are going to loose suction...and that would suck..or not;) your friendly neighborhood Microbiologist
Jan 2, 2007. 4:43 AMEdgar says:
Nothing wrong to point out-The idea's PERFECT!
Simplicity's allways the best choice.
A very good alternative to a Water jug, in this and other Projects, is the Jerrycan type 20 Liters plus Detergent Bottles the Restaurants and Hotels, etc., use.
They get rid of those frequently, and these suckers have a screw-on lid, just like Jerrycans!
So go bother your local Hotel Restaurant, get a lot of these beauties for free...
And the guys will THANK you for it!
Oct 31, 2006. 2:39 AMrickharris says:
You could make a cyclone - it is more effective and only a bit more complicated.
[cyclone DIY]http://codesmiths.com/shed/workshop/techniques/cyclones/
Oct 28, 2006. 3:20 AMMyself says:
The same concept is used to snag the heavier wood chips and metal bits before they damage the impeller in a shop dust-collection system. It works great! I've used a similar setup to make a prefilter for my friend's pool vacuum. The cover failed in the spring and he ended up with gobs of leaf debris on the bottom of the pool, which was clogging his filter so fast he could only run it a few minutes between cleanings, each of which caused the pump to lose its prime, and it was going to take forever to clean the pool. So we rigged some chicken wire and window screen into the middle of a 5-gallon bucket with some fittings cut into the top, and effectively quintupled the filter area. It'd run a lot longer before clogging, and opening the bucket to dump the gunk could be done without depriming the pump, Very handy technique! You can accomplish some of Dan's heavy-solids removal without chopping two holes in your container: Put a "combination tee/wye" fitting on top of the water jug, so that lighter material passes straight over but heavier stuff falls in. It's not as good as the two-hole route but you can use unmodified jugs for it, and if you set up several in series, you can even remove one for emptying (just cover its port) without shutting down the vacuum.
Oct 28, 2006. 10:09 PMMoogle says:
Better yet, get a PVC T fitting that fits snugly over the bottle top, and a pipe that fits loosely into the neck. Get an adapter for the two sizes of pipe, cut/sand out the inner rim so that the smaller pipe can go straight through the T junction into the bottle. Attach the vacuum to the open T fitting, and the hose to the smaller pipe. (Good luck getting all those fittings to work). That will accomplish both not needing to modify the bottles and safely protecting the vacuum from pretty much everything.
Oct 28, 2006. 7:35 PMJunkernaut says:
sweet
Oct 27, 2006. 4:15 PMHoopajoo says:
Picture this rig set up with a 55 gal. PVC drum. WOW! Think of the capacity!!!
Oct 27, 2006. 4:13 PMve2vfd says:
If you want to make sure no water makes it in the vaccum cleaner, add a floating ball thats slightly bigger than the bottles hole. The ball will float and block the vaccum hose as the water rises thus preventing a ruined non-wet/dry vaccum. :-)
Oct 27, 2006. 1:34 PMtrebuchet03 says:
Wow, good idea :) I'll have to keep this in mind :)
Oct 27, 2006. 1:10 PMdan says:
this is a good method, it also works well if you want to vac up a lot of heavier solid matter like dirt - the dirt will fall into the first container and the vacuum will only get the stuff light enough to fly into the second tube.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:montanaro2006
