Introduction: Valka Costume (How to Train Your Dragon)
After seeing How To Train Your dragon 2 at the theatre I couldn't wait to make this costume. I may never wear it ,but it is now posed on a mannequin in our entryway.
Step 1:
In an effort to keep cost down and try to reduce the vast amounts of supplies I already own, I decided to make this costume entirely from painted fabric and foam. It was a very inexpensive costume to make even if you had to buy the fabric.
The base of the pants section of the costume is a pair of loose fitting pants that I already owned. I stuffed the pants tightly . Over the pants I wrapped the lower leg (below the knee) with quilt batting. Then I made strips of fabric that were about 3 inches wide and wrapped the legs of the pants in the fabric strips. I had several yards of a light weight cotton fabric that I used to make 3 inch wide strips from. There are about 15 yards of fabric strips in this costume overall.
The pants are wrapped all over except at the knee and the top of the waist. I wanted those areas free of excess bulk.
To keep the layers of fabric strips in place I painted the entire surface area of the wraps with a 50/50 mix of white glue and water. After letting the glue dry thoroughly I painted on stripes of brown ,orange and burgundy craft paints.. I loosely followed the lines of the fabric strips. The stripes are thinner than the wrap lines so there are more than one color on most of the fabric strips.
For the spikes that go on the sides of the calf section I used a foam exercise mat .There are 5 spikes about 3 inches long on the sides of each calf area. The spikes are covered in masking tape to round the edges and then covered with a caulking material.They were then painted with brown craft paint. The spikes are very light and flexible.
The spikes are glued to the calf area using a silicon adhesive. I like GOOP. It is strong , waterproof and remains flexible.
Step 2:
The bodice of the costume is made of strips of fabric that were cut into 3 inch strips. There are about 3 different fabrics used on the body section. As long as the fabrics are similar the finally look will be good. Once the fabric is painted , the differences in the fabric are no longer noticeable. I have a body form in my size that I used to keep the right size and shape as I was forming this section.
Starting at the bottom I zigzagged back and forth working my way up to the neck area. There is a slit down from the neck at the back to allow the bodice to be stepped into. The arm holes are a couple of inches larger than a vest would normally have to allow for ease of movement.
While wrapping the body section I folded the wrap fabric in half as I went along. The folded cection of the strips are faced down with the raw edges of the strips faced toward the neck. As the body was wrapped upward only the folded side of the strips show.To keep the fabric strips in place I used pins. The body was then painted with a 50/50 mixture of white glue and water. When the glue was dry the entire bodice was base coated with a burgundy paint . Once dry a top coat of burnt orange was applied.
There are little armor accents on the top of the costume. These pieces were all made from craft foams. The circular pieces go on the shoulders and the little triangles go on the elbows. After I was done with all the painting , I glued these on to the costume.
The shoulder armor has 5 layers that I gently curved and using duct tape on the underside taped together. The shoulder armor is made from a red craft foam that I painted with brown and orange paints.
The turquoise paint was applied after all the top parts were completed and glued in place.
Step 3:
For the arm gauntlets I started with a pair of knee socks that I cut the feet off of. The socks were slipped over a cardboard tube and wrapped with quilt batting. The batting was then covered with strips of fabric and then painted with a 50/50 mixture of white glue and water. The glue was allowed to dry and then the gauntlets were painted in the same fashion as the legs of the costume.
I made similar spikes to the ones on the legs. These spikes were about 1.5 inches long. GOOP glue was used to apply these to the sides of the gauntlets.
There is a claw like hand that sticks out from the wrist. Foam from a 1/2 exercise mat was used. The foam hand was covered with masking tape, a layer of caulking , then a top coat of brown paint. The claw was glued to the wrist with GOOP glue. At the elbow area a triangular piece of armor was glued on.
Step 4:
The costume has 7 flaps of varying length that hang from the front of the costume. The flaps are made from a coarse grey fabric that I streaked with brown and grey paints. There is a dark brown belt. The belt is about 12 inches wide . I cinched it down by creating a couple of pleats. The belt is glued to the center back. The front flaps are slipped under the belt In the front of the bodice . The flaps are glued in place with GOOP glue.
There is a top loin clothe that was made from 2 crudely cut triangles of dark red fabric that were topped with streaks of orange paint. These loin clothes were glued under the belt on top of the grey flaps.
The large belt buckle is a foam circle painted with craft paint and glued to the front of the belt.
Grommets were added to the back opening and a shoe lace was used to tie the top closed at the neck.
Step 5:
When all the pieces were completed I assembled the costume and using a dry brush with a watered down brown paint I streaked and weathered the costume all over. This gives the costume a more authentic look. A costume that looks too clean doesn't look like it is "real" I wanted my Valka costume to look like something that a women in the wild could make using crude tools. I am usually trying to make my costumes very clean and uniform. I had to resist the urge to make it look to regular and even.
Step 6:
Under the top I have a burgundy turtle neck shirt.
The shoes are a pair of thrift store brown suede boots.
There is a cape that was made from a rectangle of burgundy gauze fabric that i tattered at the bottom and sprayed with a black mist of spray paint. The cape is glued to the top of the shoulders under the shoulder armor.
This is not an incredibly difficult costume , but it does require a lot of time .
Halloween Costume Contest
