To build my version of the ValveLiTzer, you will need everything listed in gmoon's instructable. I bought nearly everything at Antique Electronics Supply, except for the LEDs (eBay), resistors and capacitors (local electronics shop), and wire.
EDIT: Be sure to check out an alternate version of this design, which I call the ValveLiTzer Trifecta. Same circuit, very different case!
ELECTRONICS
1 12FQ8 tube
1 9 pin miniature socket
2 1/4" mono jacks
1 50k linear potentiometer
1 500k audio (logarithmic) potentiometer
1 SPDT (on/on) footswitch
2 blue LEDs
2 1000uF 25V electrolytic capacitors
2 1Mohm resistors
1 470k resistor
1 220k resistor
1 47k resistor
2 470 ohm resistors (for LEDs)
2 0.01 uF capacitors
1 0.1 uF capacitor
solder
24 AWG stranded wire
CASE MATERIALS
about 2 square feet of 17mm thick Russian Birch Plywood (aka Baltic Birch)
about 1 square foot of 2-3mm thick plexiglass, Lexan, or polycarbonate plastic sheet
about 1 square foot of 3mm thick aluminum or brass plate
7 3/4" countersunk wood screws
some rubber stick-on feet
wood stain (your choice of colour, I used "Cabernet" red oil-based stain)
wood finish (I used Minwax Polycrylic water-based finish)
TOOLS
A band saw
A scroll saw
A drill press
A belt sander (or a sanding belt for the band saw) - optional, though good to have!
A Dremel tool with a drill press attachment
A 1/8" milling bit for the Dremel
A polishing bit for the Dremel
200 and 320 grit sandpaper
a 1/2" wide paint brush
A 1/2" wood chisel
assorted drill bits
and countersink bit - optional, you could also use a 3/8" drill bit
soldering iron
ETCHING SUPPLIES
A variable output (up to 12V) DC power supply capable of 3 amps
a piece of scrap aluminum
a tub large enough to hold the cut aluminum pieces
salt water
a clothes iron
a laser printer
a sheet or two of glossy photo paper
Remove these ads by
Signing UpStep 1The Case
Plates of aluminum are set into the top, providing a strong stable surface to mount the switches, jacks and pots. The aluminum is etched with the names of the various components.
The bottom of the pedal is made of diffused (sanded) polycarbonate plastic, which is illuminated from the inside by two LEDs.
I started by drawing the case in Adobe Illustrator. Using the diameter of the valve as a starting point, I drew circles and arcs accordingly until I came up with the design below. There are a few concentric cutouts visible, that indicate the various profiles of the pieces. I also marked the locations of the various components that would be mounted on top.
I then worked out a separate template for the text that would eventually be etched onto the aluminum. I picked a font that matched the aesthetic of the case - you can use virtually any font in the world using the etching method!
online mastering
Just a couple of questions:
On the C1, C2, C3 - the capacitors ; are they 600v, or 400v? Did you use the 4 pin 1/4 mono Marshall jacks found at Antique Electronics supply? Where did you obtain the 16v 1000uf capacitors ; and are they absolutely necessary as I don't see them in the original schematic ; and I see you added another (2 instead of 1).
Again, awesome stuff and THANK YOU!!
Yes, I think I used the Marshall jack. You can use whatever you want, though.
I got these caps at Sayal, a somewhat local electronics components chain. They shouldn't be hard to find, though. These filter the power supply and should be used if you're using a wall-wart ac/dc converter. If you're using a battery they aren't necessary.
http://www.facebook.com/photo.php?pid=3685285&l=44bc234cf1&id=630911404
http://www.facebook.com/photo.php?pid=3685287&l=ab4f4be9f3&id=630911404
Wiring:
http://www.facebook.com/photo.php?pid=3685303&l=6effc23467&id=630911404
It has amber LEDS underneath the valve and the case, so it gives a lovely glow when on, can't get a good picture of it in the dark though:http://www.facebook.com/photo.php?pid=3685297&l=88ea6fafb6&id=630911404
It's not a matter of dropping the bike...it's just a matter of when. Everyone drops their bike eventually.
=p
Dm
