My first version, the ValveLiTzer Redux, features a prominent "figure 8" design with the tube sticking out the top, etched aluminum plates, and a glowing blue base.
This Instructable will describe how I built the second one. The guts are the same, but as you can see the case is very different. It's also made of Baltic Birch plywood, but the case is a rounded square with the tube inset and mounted sideways. There are aluminum plates on all the sides, and the knob labels glow when the pedal is plugged in.
If you want to make one of your own, you don't have to use gmoon's exact schematic. You could fit a lot of different pedal designs inside this 5x5 inch case, changing the labels and knob locations as necessary.
Remove these ads by
Signing UpStep 1Design, Materials and Tools
I used one of my favourite materials, Baltic Birch plywood (aka Russian Birch plywood) to build the case. The case is actually several layers stacked together. The main case is a layer of 1/4" plywood glued to a 3/4" piece. The bottom of the case is a single layer of 1/8" plywood. The top is the most complicated. It is made of a 1/8" plywood bezel, with 1/8" polycarbonate hidden inside. A layer of aluminum duct tape is applied to the plastic, and acts as a mask for the component labels. The top is laminated with a wood veneer to conceal the plastic and the label mask.
The sides feature inlaid aluminum, with the front panel etched using electrolysis.
It's... kinda tricky to make, but I'm sure you can do it. With the right tools, that is!
MATERIALS (case)
1 6x6" piece of 3/4" Baltic Birch plywood
1 6x6" piece of 1/4" Baltic Birch plywood
2 6x6" pieces of 1/8" Baltic Birch plywood
1 5x5" piece of 1/8" transparent polycarbonate, acrylic or Lexan plastic sheet
about 25 square inches of 1/8" thick aluminum plate (brass or steel would work, too)
a few flat head 1/2" wood screws
20 inches of aluminum duct tape
Carpenter's glue
Two-part Epoxy (the longer the set time, the better)
Spray-on adhesive
packing tape (optional)
clear acrylic finish (I used Minwax Polycrylic)
MATERIALS (electronics)
1 12FQ8 tube
1 9 pin miniature socket
2 1/4" mono jacks
1 50k linear potentiometer
1 500k audio (logarithmic) potentiometer
1 SPDT (on/on) footswitch
5 blue 5mm LEDs
1 amber 3mm LED
2 1000uF 25V electrolytic capacitors
2 1M resistors
1 470k resistor
1 220k resistor
1 47k resistor
1 510 ohm resistor
1 120ohm resistor
1 220 ohm resistor
2 0.01uF polyester, mylar or ceramic capacitors
1 0.1uF ceramic capacitor (or replace with a 33uF electrolytic for more boost)
TOOLS
A variable-speed scroll saw
A good scroll saw blade for wood (I use Olson reverse skip tooth PGT blades)
A crown tooth scroll saw blade (for cutting plastic)
A drill press and assorted bits (a hand drill would work in a pinch)
A band saw (or a scroll saw with metal cutting blades)
Lots of sandpaper
A sharp knife (use a fresh blade for this - you'll need it!)
A computer and laser printer
An electrolysis bath
A clothes iron
1. how many Watt your resistor, and i can't find 510Ohm(which one is better :560 Ohm or 470 Ohm)
2 how much Volt(DC or AC) for your 0,01 uF and 0,1 uF, since in my town i can't find anything except more than 63VDC
thanks before
The 510 ohm resistor is used for the LED that illuminates the tube. Either would probably be fine, but use the 560 ohm just to be sure.
63V capacitors are fine. Hopefully they will fit (assuming you're making the same case)!
Are you wearing a ring around your finger while working with machines?
Thats a very bad idea, the uncle of my friend lost his finger because his ring got caught in a saw blade.
But, I do remove my ring for some tasks.
and jeff-o seems to agree
this way you cant see if the tube is hot (ready) to use....
I think if you used a small sand blaster (the craft etching type, or airbrush size ones) to frost the labels, and glue the LEDs to the plastic just to one side of the label, to create a "light pipe" that may work as well.
Check out the bottom of this page - the light flows inside the plastic until it hits a frosted section or cut edge:
http://metku.net/index.html?path=mods/glowpad/index_eng
