Step 2Print the Patterns
Using spray adhesive, paste one pattern on the 6x6" piece of 3/4" plywood. Paste one pattern on each of the 1/8" pieces of plywood. Depending on the spray adhesive you use, you may have to let the glue dry for a minute or so before sticking it onto the wood, or it will be too difficult to get off later.
If the plastic sheet you have still has a layer of protective film, you can glue the pattern right onto it. If not, stick down some packing tape and glue the pattern onto that.
The aluminum plate can be cut on its own, but I recommend sandwiching it between two layers of scrap (low-grade) plywood. This makes it much easier to cut.
Allow all the patterns plenty of time to dry, so they don't accidentally peel while you're cutting them out.
Add Comment
