Vampiric Cyberpunk Double Barrel Shotgun
 by gmjhowe
FeaturedContest Winner
Ok, well, as many of you know, bumpus loves a shotgun, for a while he has been demanding encouraging me to build one.
Thanks to Kiteman for kindly point out many just a few mistakes in my write up.
Recently I came across the perfect tubes at work, hence, this project began - firstly, a little video.
The shotgun it self is a fairly normal shotgun, the shells are the special part, each shell is made up from three chambers or 'vials' Each shell contains three substances,
  • A liquid Silver Nitrate Composite
  • A white Metamorphic Acid Substrate
  • And a viscous C4 explosive gel
One shot from this baby, and even the most elder Vampire will fall
Now, on with the how to.
Step 1: The barrel and handle
Ok firstly, you have to make the base.
I held the two tubes together using some big pegs, I then ran PVA glue down the seem, once dry, this holds them together nicely - repeat for either side.
Using the template for the handle on my sniper, I modified it for a sawn off shotgun, I needed to make this one quite wide, so it had two layers of corrugated card, and two layers of dense gmjboard (thick velum mount board stuffs)
I then build up the top of the gun using more of the gmjboard.
Glue the layers together, let the whole lot dry.
Terranan says: Sep 6, 2012. 9:04 PM
MACHINAE SUPREMACY!!! :D
Origin v2 then Winterstorm!
I love Winterstorm....
sonofstone says: Jul 29, 2012. 1:06 PM
do you work with wood sometimes? i'm building a sawn-off double barrel hunting rifle, stock is already been built, barrels welded together, all i need is a hinge, could you help me out on this part?
electfire says: May 17, 2012. 7:08 PM
@gmjhowe
Came across this again recently, and your "shell" design is giving me some ideas...
Though one question... the song in your video you say it's by Machinae Supremacy... but what is the song title?
gmjhowe (author) in reply to electfireMay 18, 2012. 12:35 AM
Thanks! Do share if you create anything. The title is 'Winterstorm'
electfire in reply to gmjhoweMay 18, 2012. 11:22 AM
Thanks for the track info!
I have so many Projects In Progress (or PIPs as I call them)
Hopefully will have finished my Star Wars prop (a prototype version of a lightsaber, in the style of steampunk.) finished before the 25th! There is a local celebration of the 35th anniversary of the first movie, that I want to show off the prop at..
It originally was supposed to be done for May 4th (Int. Star Wars Day), but I goofed up on the month, I though it was next month!
gmjhowe (author) in reply to electfireMay 19, 2012. 3:10 AM
That sounds awesome. I look forward to seeing it.
faustoyacob says: Mar 22, 2012. 7:13 AM
GREAT SHOTGUN!!
brupielink says: Sep 20, 2011. 2:30 AM
That's one hell of a shotgun! Gonna try it myself if i have the materials.
One tiny bit of criticism though.
The vial shells are a great idea and really suit it, but i might be a good idea to
finish the ends of the shells so they look more round and solid, like it's really sealing it off for safety, or to have some sort of acryllic/glass tube/vial over the entire shell itself, making it solid.
Iwantbigboom says: Aug 8, 2011. 4:30 PM
c4 is pressure sensitive
Orkekum in reply to IwantbigboomAug 26, 2011. 8:35 AM
no it's not.
Hugh pressure ANd high impact ANd high temperature
Iwantbigboom in reply to OrkekumAug 26, 2011. 8:43 AM
it depends on what its made of and what form its in
monkeys98 says: Jul 22, 2011. 2:52 AM
awesome, simply awesome
Sabinbp says: Jul 1, 2011. 2:12 AM
those shells look very familiar i saw them in a final fantasy movie or episode of somekind
LilBangarang says: Jun 19, 2011. 4:45 PM
OMG ppl. u crack me up. He's just making it sound cool. It doesn't matter on the realism. No... silver doesn't kill vampires which aren't real in the first place. This is an amazing instructable. Thank you so much man. This officially inspired me. YOU ROCK.
mastiffman says: Jun 4, 2011. 11:35 AM
Very well done; thanks
sonofstone says: Jun 2, 2011. 4:24 AM
why c4, why not nitroglycerine?
DustySeven7 says: Jun 1, 2011. 3:41 PM
Two things. First C4 is what is known as a plastic explosive. It is extremely stable due to the explosive substance being mixed with the plastic. Fire, heat, and electricity will not cause C4 to explode. It takes a special charge of small explosive inserted into it. This causes a reaction in the C4 that make it explode. That is why you see soldiers insert the little metal tube into it. And Second Silver will not kill a vampire, it will only harm them. The only way to kill a vampire with silver would be to have a silver stake go through the heart.
eulaliaaaa! says: Oct 3, 2010. 3:13 PM
Not to be too technical or anything, but C4 needs electricity to blow up. Just saying. Nice Instructable, by the way.
Soul Crusher X in reply to eulaliaaaa!May 17, 2011. 7:58 PM
No, it does not require electricity.
eulaliaaaa! in reply to Soul Crusher XMay 22, 2011. 3:02 PM
Yes, it does. It says in some army field manuals that you can burn c4 and get a strong plastic.
bendog38 in reply to eulaliaaaa!May 24, 2011. 2:33 PM
I'll second that.
Soul Crusher X in reply to bendog38May 24, 2011. 5:35 PM
Sadly, you are both wrong. There are no stabilized, man-portable, explosives that require electricity to detonate. I could go into detail, but this is not the venue for that.
eulaliaaaa! in reply to Soul Crusher XMay 25, 2011. 1:38 PM
So how else would you detonate it? Fire? If so, all it would do is just burn like fuel and turn into plastic.
Mattrox in reply to eulaliaaaa!May 30, 2011. 4:58 PM
Like you say C4 will not explode if on fire(in the second world war some burnt it a safe cooking material).
However putting electricity through C4 will not make it explode. Explosives like C4 are known as "secondary explosives" meaning they need a kick start to explode, for instance some farmers use ANFO(another secondary explosive) to remove stumps(etc.) if they don't have access to blasting caps they use a shot from a high powered rifle to the explosive this achieves the same thing as a blasting cap.
It introduces shock/energy into the explosive somewhat like a starter motor on a truck.
By the way some blasting caps are triggered by electricity.
Cheers, Mattrox
Hephestus in reply to eulaliaaaa!May 3, 2011. 6:33 AM
Could use just a coin cell battery in one end with two metal prongs on the other, when they hit the body, the blood of your target is the conductor setting on the explosive charge :)
eulaliaaaa! in reply to HephestusMay 7, 2011. 12:53 PM
True... Salty fluid is a very good conductor.
The nerdling in reply to eulaliaaaa!May 24, 2011. 9:15 PM
bit of resistance though
Hephestus says: May 3, 2011. 6:30 AM
Started making my own version of your shotgun, im making it out of Mdf and copper piping, gives it a bit for weight to it, Great design though
DannytheGreat says: Dec 17, 2009. 7:10 PM
I know it is just supposed to give a story to it but shouldn't one of the vials have holy water?
Javin007 in reply to DannytheGreatJul 16, 2010. 5:42 AM
I would think holy water, liquified garlic, and silver. (Just to cover all the bases.)
DannytheGreat in reply to Javin007Dec 27, 2010. 7:43 PM
Im catholic so holy water, silver (in case of surprise werewolves), and the c4 was a good idea
jr.tuckluck13 in reply to Javin007Jul 16, 2010. 11:00 AM
Go Hellboy on them. Holy Water, garlic, silver nitrate, etc.
badideasrus in reply to jr.tuckluck13Sep 27, 2010. 9:07 PM
i prefer blade's method. 3 inch silver stakes 12 ga rouphly = 50 cal, so supa bullet. we're talkin like 4-6 inch shells here.
jr.tuckluck13 in reply to badideasrusSep 28, 2010. 5:52 AM
haha this is true
rug in reply to jr.tuckluck13Jan 27, 2011. 7:28 PM
isnt the only thing that kills them are wooden stakes?
-Chrimson_And_Clockwork- in reply to rugMay 9, 2011. 7:24 PM
actually that's just a misconception by holly wood
the wooden stake through the torso is to hold them down while you decapitate them and burn the corpse.
i still prefer the old ways of burying them upside down so they dig their way to hell tho :]
jr.tuckluck13 in reply to rugJan 28, 2011. 7:08 PM
not at all. watch the blade series. silver, uv light, stakes, beheading or dismemberment
rug in reply to jr.tuckluck13May 10, 2011. 3:15 AM
sorry yer i wasnt thinking straight ummm.... uv light works so does stakes and beheading but i've never heard of silver before
weasel999 says: Oct 14, 2009. 9:44 AM
 i believe "metal foil duck tape" is calledmetal repair tape
DELETED_kage_no_akiri in reply to weasel999Oct 17, 2010. 5:35 AM
(removed by author or community request)
weasel999 in reply to DELETED_kage_no_akiriOct 18, 2010. 1:10 PM
idk i used it to seat the spaces in the ducks and it worked wel!!
DELETED_kage_no_akiri in reply to weasel999Oct 18, 2010. 4:10 PM
weasel999 in reply to DELETED_kage_no_akiriOct 19, 2010. 4:13 AM
sorry ducTs like for air
DELETED_kage_no_akiri in reply to weasel999Oct 19, 2010. 4:29 PM
weasel999 in reply to DELETED_kage_no_akiriOct 20, 2010. 11:42 AM
are u kidding u made my day
sonofstone says: Oct 13, 2010. 12:47 PM
indeed, why not make it a spring powered gun, you could take a nerf gun and replace the internals, but the materials you used for this creation is a little to soft i'd think
CyborgKnight says: Feb 18, 2010. 11:48 AM
 could you try to make one that shoots?
halberdear in reply to CyborgKnightJul 21, 2010. 9:00 PM
Why not? Personally I'd go for something either spring or air powered.
I Ride Kangaroos in reply to halberdearSep 2, 2010. 12:50 AM
Yeah good idea!
starfox384 says: Jul 7, 2010. 7:27 PM
I like the music in the video
TheMadScientist in reply to starfox384Aug 27, 2010. 3:41 PM
didnt even have my headphones on (they were on the ground) and I recognised it. he pieced together two or three songs by machinae supremacy.
SRT4ever says: Apr 30, 2010. 11:34 PM
 What's the point of making a fake gun??? No offense, I'm just curious
co2wms7whcc in reply to SRT4everAug 15, 2010. 9:50 PM
There are some of us who consider making collectibles an art.
musicalbee2003 in reply to SRT4everJul 1, 2010. 8:56 AM
Costuming. Notice the "Cyberpunk" moniker? Means he going for a character piece.
gmjhowe (author) in reply to musicalbee2003Jul 6, 2010. 6:25 AM
Actually, I make to sell. This was sold to a person looking to complete their costume.
blueberrypieisgood says: Jul 28, 2009. 7:49 AM
where do you find tubes like that? I would think christmas wrapping paper but those look too thin...
WhiteTigerTails in reply to blueberrypieisgoodAug 10, 2010. 10:06 PM
Try going to a UPS store, and find tubes that work~
gmjhowe (author) in reply to blueberrypieisgoodJul 28, 2009. 9:44 AM
They come off industrial laminating rolls. Im not sure where you would get them from.
tanis9319 in reply to gmjhoweOct 8, 2009. 1:34 PM
would pvc tubes work
red-king in reply to tanis9319Oct 17, 2009. 1:39 PM
 if you got them in the right size(use your own judgement for this). yes.
KeannaRoar in reply to red-kingNov 5, 2009. 8:20 AM
Consider Fiberglass instead, It'll have less weight.
jibbers75 in reply to KeannaRoarJul 29, 2010. 7:26 PM
if it has more weight it will feel more realistic
badideasrus in reply to jibbers75Sep 27, 2010. 9:06 PM
u can get fiberglass tubes? for how much? pvc would be infinitely cheaper
KeannaRoar in reply to badideasrusSep 27, 2010. 10:34 PM
Lowes and Home Depo sell them. They are a little pricer, but you don't have the immense weight of the PVC weighing you down.
swilus in reply to KeannaRoarMar 3, 2011. 7:00 PM
Immense weight of PVC lol never thought I would hear that sentence
Tmac121 says: Jun 23, 2010. 4:11 PM
What were all of your base materials?
BeanGolem in reply to Tmac121Jun 28, 2010. 4:02 PM
And to whom did all of your basematerials belong?
M4industries in reply to BeanGolemJun 30, 2010. 7:29 AM
All his base were belong to me.  No one else!
naruto the ninja13 in reply to M4industriesAug 10, 2010. 9:27 AM
no all his bases are belong to us
TyMan210 says: Jul 4, 2010. 4:42 AM
I think I'll just stick with my .357 Magnum. Maybe a couple of grenades, too.
datalot says: Jul 3, 2010. 5:27 AM
amazing *DROOL*
Maxaxle says: Dec 1, 2009. 7:47 PM
Great shotgun, but I recommend adding some sort of lever to break down the barrel, like in a real double-barrel.
ILIKEPIE333 in reply to MaxaxleJan 26, 2010. 7:24 PM
Most break-action shotguns do not use a lever to operate. You are probably thinking of a lever-action which obviously uses a lever.
M4industries in reply to ILIKEPIE333Jun 30, 2010. 7:31 AM
Model 1887 from COD MW2. The best shotgun in the game.
stoobers in reply to ILIKEPIE333Feb 23, 2010. 9:47 PM
Most american over-under and side-by-side double barrel shotguns have a lever on top that is thrown left or right to open the action.
Single barrels often have what looks like a second hammer.
ILIKEPIE333 in reply to stoobersMar 17, 2010. 4:49 PM
Yeah, I know what youre talking about, but I was referencing an actual lever as on the Winchester, although thats probably not what he was taling about.
BlackIceRedbone says: Apr 28, 2010. 7:58 PM
could you make one that cocks
jr.tuckluck13 in reply to BlackIceRedboneMay 14, 2010. 3:52 PM
I have one that cocks...
BlackIceRedbone in reply to jr.tuckluck13May 17, 2010. 4:56 PM
 How did you do it?
jr.tuckluck13 in reply to BlackIceRedboneJun 15, 2010. 10:02 PM
Used a cheap airsoft shot gun. Modified it. If i can find it, i'll post pics
TheGhostOfOnyx says: Jun 11, 2010. 10:01 PM
Also, I think a pump action shotgun would be cool for a future project.
TheGhostOfOnyx says: Jun 11, 2010. 9:06 PM
This is just a suggestion for a way to stop the vials from sliding out, and i think it would look authentic too. Basically it would just be a stretchy rubber material about an inch into the barrels so that when the vials are pushed in, it can't keep going, and when you break the barrel to get them out, they would be pushed out a little already. If I make this, I will experiment and tell you what I find.
valkiraun says: Apr 2, 2010. 3:09 AM
 Talented work. I think i might try my hand at something similar...
tanis9319 says: Oct 2, 2009. 1:48 PM
i have a way to get those vials but they have printing on the sides what do i do?
Derin in reply to tanis9319Mar 20, 2010. 12:55 AM
get something like acetone and try to see if it damages the vial while taking the paint off (use an extra vial)
PastTheVoid says: Mar 17, 2010. 3:34 PM
 Also a great solution for those pesky gnomes that keep messing up my vegetable garden.
adamc90 says: Mar 5, 2010. 5:04 PM
this looks awesome ive always been a sucker for shotguns, to me their just amazing, i was wondering where do i find thisliquid silver nitrate i found the metamorphic acid but not the nitrate XD hunt some vamps xD
wolfboy616 says: Dec 1, 2009. 6:30 AM
 freaking awesome man!!! :D
MichelMoermans says: Nov 26, 2009. 2:43 AM
Congratulations with your third prize in the decoration department. I'm glad to see my vote did matter :)
Great instructable by the way. When my current projects are finished I'm gonna try to make a shotgun myself (a little different though since I don't really like to copy someones work, more of a putting my own twist to it kinda guy)
Plz excuse me for me bad English :)
daltonjcw says: Oct 21, 2009. 5:22 PM
 where else can you get those tubes?
Loosewire; SOE Operative in reply to daltonjcwOct 28, 2009. 8:00 AM
I get some thinner ones from cling film, bako/kitchen foil and some sweets & glowsticks.
gmjhowe (author) in reply to daltonjcwOct 23, 2009. 5:32 AM
 Mine were off a laminator, so you need to find something that uses up rolls of something.
daltonjcw says: Oct 17, 2009. 9:41 PM
very, very good job! the shells/tubes/ whatever.... are awesome!
00Donut says: Oct 8, 2009. 11:11 PM
As seen in picture four, what model of gun did you use as a basis for your trigger/stock?
aussie_in_mo says: Oct 5, 2009. 4:03 AM
For what it's worth you should look into "boning" as a process for hand forming leather to the shape of your stock/grips. Boning involves soaking the leather under water and then pressing it around the item you want to shape it to. It's used to create custom fit handgun holsters or knife sheaths. If you use fairly thin leather then you can get a lot of the detail contours from the stock to come through the leather also.
3xpl0dingR4pt0r says: Jul 12, 2009. 5:29 PM
KINDER EGGS!! Or atleast thats what i think those small orange and yellow containers are. In some pics on the last step. Unless im really dumb. Loved those tho. Good job on the gun too lol.
gmjhowe (author) in reply to 3xpl0dingR4pt0rJul 13, 2009. 4:40 AM
Yes, your correct! I buy kinder eggs for my Fiancé when she is feeling low. Thanks for the comment.
tanis9319 in reply to gmjhoweOct 2, 2009. 1:45 PM
what are kinder eggs?
3xpl0dingR4pt0r in reply to tanis9319Oct 4, 2009. 10:45 AM
They are basically a chocolate eggshell and inside is like a little toy that you put together. Theyre prettty neat.
3xpl0dingR4pt0r in reply to gmjhoweJul 13, 2009. 5:41 PM
Where! I want to buy some. Those are the best!
rob.thieman says: May 10, 2009. 12:10 PM
That is a fantastic creation! I've been considering options for Halloween and I think I've settled on a vampire hunter theme. Thanks for the inspiration.
gmjhowe (author) in reply to rob.thiemanMay 10, 2009. 12:27 PM
Your more than welcome! I hope your costume idea goes well! Thanks for the comment.
tanis9319 in reply to gmjhoweOct 2, 2009. 1:52 PM
question how did you keep the shells from slideing out of the barrels and any way you should make belt shell holder that would be awsom
Jehosephat says: Aug 2, 2009. 11:17 AM
I have been a modder & a weapons builder for a while, and I can say that this is by far the most professional-looking prop I have seen to date.
The most creative part, in my opinion, is the shells.
I never would have guessed to use medical vials, so I tip my hat off to you.
(Very surprised that you were not contacted when Van Helsing was being made)
Also, I need some information on how to properly make a revolver sort of like the Samaritan as boogyheadabc mentioned, but more in a Trigun-style without the weird muzzle.
I would appreciate if you could give a tutorial using the same materials and style as the shotgun you constructed.
Thank you,
Jehosephat
gmjhowe (author) in reply to JehosephatAug 2, 2009. 2:32 PM
Hi, thanks for your kind words, I do have plans for a revolver at some point, very much in a heavy weight magnum/trigun style. But alas as always, time is an issue, I already work with a massive back log of projects! I more than happy to talk through your ideas.
Jehosephat in reply to gmjhoweAug 3, 2009. 9:07 PM
Also, I have posted a question stating to make a steampunk outfit/weapons, regarding my new project: (ominous music)
>>Steampunk Vampire Hunter<<
Any ideas?
Thank you kindly,
Jehosephat
trogdoroth in reply to JehosephatSep 26, 2009. 8:29 PM
Maybe make this shotgun but paint it to look like brass. lol
Jehosephat in reply to gmjhoweAug 3, 2009. 8:59 PM
Thank you for the update gmjhowe. I know exactly what you mean by planning issues (i have a couple of them on my own T.T) I mainly have used wood and I've wanted to start fresh &expand my horizons. Thing is I don't exactly know how to properly work with cardboard or your "gmjboard" as you have christiened it (not a lot of experience with the material exactly T.T) On an ending note, I have to say I simply love your projects. Goodluck & Godspeed, Jehosephat
DJVMAN says: Aug 20, 2009. 12:42 PM
how did you do all of the details
DJVMAN says: Aug 19, 2009. 4:55 PM
where did you get your materials
gmjhowe (author) in reply to DJVMANAug 20, 2009. 3:37 AM
All my materials are left over packaging from the print works that i work at.
DJVMAN says: Aug 19, 2009. 3:06 PM
where can i get the barrel
D0cR0ck says: Aug 19, 2009. 1:13 AM
What is the length of each tube? I can't seem to find that in the Instructable.
gmjhowe (author) in reply to D0cR0ckAug 19, 2009. 4:27 AM
About 350mm ish, but use what ever length suits the style your looking for.
D0cR0ck in reply to gmjhoweAug 19, 2009. 5:06 AM
Thank you.
mr. cool 384 says: Aug 14, 2009. 9:21 AM
mine is so cool thanks it took a while but is great i covered a glue stick in red duck tape and painted the end gold ang it looks like a real shell
Ward_Nox says: Aug 2, 2009. 12:13 PM
gave me ideas to refine the para venom i "invented" never thought to add an acid shouldn't the shells have a space for propelliant? or is the shot gun something like a Gause gun or air riffle?
bobby4505 says: Jul 29, 2009. 11:00 PM
where could i get gmjboard?
bobby4505 says: Jul 29, 2009. 6:19 PM
THIS ONE
bobby4505 in reply to bobby4505Jul 29, 2009. 10:28 PM
would it be possible to buy 6 of the little ammo tubes off you? i need to know if three would fit in a barrel that is a millimeter shy of an inch
bobby4505 says: Jul 29, 2009. 6:18 PM
i mean this other one =P
bobby4505 says: Jul 29, 2009. 6:13 PM
the other one
bobby4505 says: Jul 29, 2009. 12:10 AM
could you make hinges out of wood???
gmjhowe (author) in reply to bobby4505Jul 29, 2009. 9:41 AM
A strong bit of wood would work, but ideally you need metal.
bobby4505 in reply to gmjhoweJul 29, 2009. 12:04 PM
could you give me any ideas? i am using black duct tape right now, and i need an idea for a grip on the handle,preferably something that paint will stick to
gmjhowe (author) in reply to bobby4505Jul 29, 2009. 12:19 PM
I suggest a layer of paper mache. Thinner paper will give a smoother look.
bobby4505 in reply to gmjhoweJul 29, 2009. 1:22 PM
should i keep it black?
gmjhowe (author) in reply to bobby4505Jul 29, 2009. 2:27 PM
yeah, paint it black, or a gun metal grey.
bobby4505 in reply to gmjhoweJul 29, 2009. 3:25 PM
and should i do a layer of paper mache on whole gun? this is what it currently looks like
bobby4505 in reply to bobby4505Jul 29, 2009. 3:26 PM
lol you can see your instructable comments on my computer rofl
bobby4505 in reply to gmjhoweJul 29, 2009. 3:18 PM
also would you mind if i entered mine in cardsborad contest if i give you most credit?
gmjhowe (author) in reply to bobby4505Jul 29, 2009. 3:20 PM
Sure, I am hoping to enter it myself!
bobby4505 in reply to gmjhoweJul 29, 2009. 3:32 PM
i should be done tomorrow's,ill give you pics of finished product
bobby4505 in reply to gmjhoweJul 29, 2009. 3:17 PM
a glossy black or like your first coating of black on your shotgun?
gmjhowe (author) in reply to bobby4505Jul 29, 2009. 3:19 PM
which ever you fancy! its your project!
bobby4505 says: Jul 28, 2009. 11:58 PM
I will hopefully be working on two projects... 1 something like the hellboy revolver and 2 something like your shot gun but smaller. I will post pics if i complete
Cool, i look forward to pictures!
blueberrypieisgood says: Jul 28, 2009. 7:48 AM
Where do you find brackets like that? I have 1 but the screw holes are like nearly 2 inches apart. Is there any way i could possibly work with that?
Yeah, work your design around what you have!
SpiroExDeus says: Jul 19, 2009. 3:13 AM
There's a use for used up injenction pen cartridges?! NICE! To think I've been throwing them all away.
1300519 says: Jul 17, 2009. 9:54 PM
1. You're amazing. 2. I might just love you for that V for Vendetta poster in the background.
laxman735 says: Jul 7, 2009. 6:07 PM
nice computer
gmjhowe (author) in reply to laxman735Jul 15, 2009. 10:31 AM
Thanks.
laxman735 in reply to gmjhoweJul 17, 2009. 6:40 PM
your welcome
The Jamalam says: Jul 15, 2009. 10:16 AM
Jesus christ, this is amazing! How do you come up with this kind of thing?
gmjhowe (author) in reply to The JamalamJul 15, 2009. 10:30 AM
Thanks! It is normally a mix of whats in my head, and a collective build up of past inspirations.
Wesley1 says: Jul 3, 2009. 12:50 AM
Try adding Garlic extract instead of a white Metamorphic Acid Substrate. Like in Blade:)
naruto the ninja13 says: Jun 15, 2009. 6:44 PM
how exactly would this fire ive always wondered sence there is oviously no powder holder or primer on the rounds im geussing its either pnumatic or electromagnetic
Aztof in reply to naruto the ninja13Jun 29, 2009. 1:40 PM
it's a prop, it doesn't fire
naruto the ninja13 in reply to AztofJun 30, 2009. 4:01 PM
Aztof in reply to naruto the ninja13Jun 30, 2009. 5:18 PM
By best guess is that it would be electrothermal
naruto the ninja13 in reply to naruto the ninja13Jun 15, 2009. 6:45 PM
also what detonates the c4?
inumaru in reply to naruto the ninja13Aug 2, 2009. 8:32 PM
naruto the ninja13: the most straightforward answer would be impact of the target
SirBrittanicvs says: Jun 29, 2009. 11:13 PM
How this isn't featured is beyond me. Fantastic work. It'd be cool to see a costume to go along with it. :)
gmjhowe (author) in reply to SirBrittanicvsJun 29, 2009. 11:58 PM
It is featured! But thanks for the kind words!
volquete says: Jun 5, 2009. 6:30 PM
i gotta make one! added to my summer "make" list
gmjhowe (author) in reply to volqueteJun 6, 2009. 1:10 PM
Be sure to hit me with some pictures if you do!
volquete in reply to gmjhoweJun 8, 2009. 11:28 AM
will do, thx for the ible!
benwal says: Jun 6, 2009. 6:51 PM
what is the barrel size (inches or millimeters)
gmjhowe (author) in reply to benwalJun 7, 2009. 6:02 AM
20mm
boogyheadabc says: Apr 28, 2009. 3:42 PM
So it is made of card board?----all you need is a pistol like the Semaritin (Hell Boys pistol) and a sword like blade... a cool outfit and then you've got an action hero!
gmjhowe (author) in reply to boogyheadabcApr 29, 2009. 4:12 AM
I have a handgun and sword already!
boogyheadabc in reply to gmjhoweMay 4, 2009. 3:23 PM
corey_caffeine in reply to boogyheadabcJun 6, 2009. 5:50 PM
hal's armour from fable 2 nice
gmjhowe (author) in reply to boogyheadabcMay 5, 2009. 12:12 AM
It would seem are ideas of what 'cool' is, are mis aligned. I do have a mask in the works.
boogyheadabc in reply to gmjhoweMay 12, 2009. 2:12 PM
boogyheadabc in reply to boogyheadabcJun 7, 2009. 10:11 AM
can't just say thanks for the ideas?
benwal says: Jun 5, 2009. 8:16 PM
yeah i might if i get some hinges and some wood and leather
benwal says: Jun 5, 2009. 3:39 AM
what sought of things do you add to the shotgun like all the 'extras'
benwal says: Jun 5, 2009. 3:38 AM
hey every night i go on the computer just to have a look at this gun it is so cool
benwal says: Jun 5, 2009. 3:37 AM
hey i was thinking if i was going to make one i was going to use pvc but what size? also im only 12 but ive got every thing exept hinges i dont no what type of hinges or if a can just use a long piece of metal hey also i was going to make a wooden stained box for it and a wood hanle plz reply i wod love to hear from the master!
Z123 says: May 27, 2009. 3:46 PM
You should totally make more Steampunk/Cyberpunk guns... They are awesome! I'm working on a gun myself
mariome101 says: May 22, 2009. 5:23 PM
Just thought of something! making this with three barrels that would spin to shoot each shot
gmjhowe (author) in reply to mariome101May 23, 2009. 4:26 AM
Yes, that would be a great idea, i decided against three barrels at an early stage.
A.C.E. says: May 22, 2009. 6:35 PM
wow this is beautiful in that vamperic steampunk sort of way. looks like van helsing or ghost rider kind of thing. definately doing this. do you think if i did this with a real shotgun it would still fire? 5 star : )
A.C.E. in reply to A.C.E.May 22, 2009. 6:41 PM
oh and when i first saw the tiny crescant hole marks on the front part of leather, the first thing i thought of was bite marks, like you used it as a shield or something.
gmjhowe (author) in reply to A.C.E.May 23, 2009. 4:24 AM
haha! bite marks, i like that. Im sure you could paint a normal shot gun to look this way, but im not a fan of real guns, too many accidents to make it worth owning one.
___ says: May 21, 2009. 3:13 PM
Nice face
mariome101 in reply to ___May 22, 2009. 5:21 PM
if you were talking to me thanks I designed it myself
mariome101 says: May 21, 2009. 1:51 PM
As a substitute could i use pvc pipe
gmjhowe (author) in reply to mariome101May 21, 2009. 2:39 PM
Sure
Hephestus says: May 13, 2009. 3:15 AM
hey GMJ if you were to make another snotgun how much would you sell it for and would we be able to buy it for our movie? MIKEY
gmjhowe (author) in reply to HephestusMay 13, 2009. 12:28 PM
You can commission me to make one, starting price of £100.
Mr. Lemon in reply to gmjhoweMay 15, 2009. 7:53 PM
if u are willing to sell ill buy 1 and how much do the shells cost to make
gmjhowe (author) in reply to Mr. LemonMay 16, 2009. 3:41 AM
This current model has been sold, so I can make one anew for you. Which also means that it can be customized to your liking. One set of shells would be included in the price.
Mr. Lemon in reply to gmjhoweMay 18, 2009. 5:57 PM
ok. first i would want the 2 barrels lie ing flat instead of on top of each other second do the bullets actually work
gmjhowe (author) in reply to Mr. LemonMay 19, 2009. 12:36 AM
I refuse to maintain conversation further with someone unable to make a difference as to whether the gun fires or not.
Hephestus says: May 12, 2009. 1:43 PM
i have no clue where to get vials :( lol any ideas where i can none of my family are on medication that use vials
gmjhowe (author) in reply to HephestusMay 12, 2009. 2:17 PM
Small mouth spray things? Try looking at cheap makeup etc.
boogyheadabc says: May 12, 2009. 2:12 PM
what?
Hephestus says: May 12, 2009. 12:48 PM
hey man another amazing project do you mind if me and my mates use your weapons in a film were making will give you credit for them
gmjhowe (author) in reply to HephestusMay 12, 2009. 12:53 PM
Sure, as long as you give full credit to myself, thats fine. Also, any advice you want etc, be sure to ask. I can be your offsite props coordinator.
lilskaterkid911 says: May 9, 2009. 6:04 PM
yeah its pretty awsome i think im going to make one and make a movie you should really make hand guns and stuff to and show us how that would be awsome
gmjhowe (author) in reply to lilskaterkid911May 10, 2009. 2:29 AM
I have made handguns, and rifles.
DELETED_phlynx says: May 9, 2009. 12:15 PM
gmjhowe (author) in reply to DELETED_phlynxMay 9, 2009. 1:11 PM
It doesn't shoot, and it is one of my easiest builds.
JohnMichael says: Apr 23, 2009. 5:00 PM
I think your "shells" in this instructable were very creative. Thanks for sharing.
gmjhowe (author) in reply to JohnMichaelApr 24, 2009. 12:00 AM
Thanks! And your welcome.
Goolie says: Apr 10, 2009. 3:05 AM
Maaan thats so coool. But I saw that double-barrel shotguns usually have 2 triggers, one for each barrel. But overall your shot gun (and especially shells) is great!
idogis1 in reply to GoolieApr 19, 2009. 8:33 AM
An over-under shotgun like this usually only has one trigger, side-by-side shotguns have two.
gmjhowe (author) in reply to GoolieApr 12, 2009. 2:56 PM
Well, i could make something up, but i just couldnt be bother putting in two triggers!
Flash Gordon says: Apr 17, 2009. 12:26 PM
Something I noticed was that most double barrels with side by side barrels have two triggers one for each of the two hammers. But since thats an overunder i dont think it would have two triggers. It could but it doesnt need to. I need to do more research on double barrels... Awesome though fav'd and 5'd
gmjhowe (author) in reply to Flash GordonApr 17, 2009. 2:29 PM
Good point! Thanks for the comment.
Flash Gordon in reply to gmjhoweApr 18, 2009. 12:53 AM
Thanks. Your welcome.
Kush_Slayer says: Mar 18, 2009. 3:35 PM
wow, ok btw, that would be more of a double barrel rifle if it worked, a shotgun shoots shot which is a crap load of bbs(anywhere between 200 or more really small ones or 9 large ones about 1/4 inch in diameter) looks kinda cool though
fuzvulf in reply to Kush_SlayerApr 17, 2009. 9:32 PM
A double barrel rifle has riflings cut or machined into the inside of the barrel, hence rifle. A shot gun can shoot "a crap load of bbs" as well as slugs, rifled slugs, bolo rounds, shock transfer rounds for crowd control, dragon's breath, darts, rock salt/bacon grease*(yes it actually was used though I don't recommend it) secondary propellant based armour piercing rockets, glass ampules, sand and the list goes on.
gmjhowe (author) in reply to Kush_SlayerMar 23, 2009. 3:35 AM
Well, the vials shatter, sending out a mix of the materials, as a 'shot' Think blobs of liquids opposed to lead pellets.
ItalianDragn in reply to Kush_SlayerMar 20, 2009. 10:05 AM
Shotguns also shoot slugs. which is what this would qualify as.
Kush_Slayer in reply to ItalianDragnMar 20, 2009. 2:28 PM
true, forgot about that
jayeng123 says: Apr 13, 2009. 7:03 PM
what is a gmjboard ?
gmjhowe (author) in reply to jayeng123Apr 14, 2009. 2:24 AM
Its a thick vellum board. Kind of like straw board, but thicker.
leaper21 says: Mar 31, 2009. 1:03 AM
Awsome idea gonna give it a go myself
gmjhowe (author) in reply to leaper21Mar 31, 2009. 4:36 AM
Coo, be sure to share some pictures if you do!
BrandonLee says: Mar 30, 2009. 4:30 PM
how do u keep the vials from sliding outta the barrel when its pointed down? and btw i love this gun came out really great
gmjhowe (author) in reply to BrandonLeeMar 31, 2009. 12:03 AM
I put a couple of screws into the tube as 'blockers'.
deathshells says: Mar 18, 2009. 2:38 PM
ive posted before but i have recently noticed that at step 3 there werent pointy bits near the metal connectors but on step 4 there were, have you just added cardboard sprayed and painted the same way as the rest of the gun or am i missing something here!?! hope you can help thanks! (i have added images of what i mean)
gmjhowe (author) in reply to deathshellsMar 18, 2009. 2:51 PM
They are just sections of card i added on to make the brackets fit into with the design. Painted to fit in!
deathshells in reply to gmjhoweMar 19, 2009. 12:01 PM
thanks for clearing that up! ONE STEP CLOSER TO MAKING IT! oh and also what type of tubes for the barrels are they and where might i get some? fabiric shop spare tubes?
gmjhowe (author) in reply to deathshellsMar 19, 2009. 12:08 PM
Mine originally had laminting plastic sheet on them. Industrial shrink wrap has similair tubes, as does rolls of food bags. Fabric shop, and such are good places to look also. Feel free to ask me as many questions as you need.
deathshells in reply to gmjhoweMar 20, 2009. 9:28 AM
cool, thanks again! ill post any more questions if they arise!
keastes says: Mar 11, 2009. 2:58 PM
now just to figure out how to add an ax blade to the thing or a bayonet
gmjhowe (author) in reply to keastesMar 14, 2009. 4:33 AM
I very nearly added an extruding metal spike.
keastes in reply to gmjhoweMar 18, 2009. 5:52 PM
that works
captaincoolness55 says: Mar 18, 2009. 1:40 AM
pretty cool man! :D
gmjhowe (author) in reply to captaincoolness55Mar 18, 2009. 4:12 AM
Thanks!
UberNoober says: Mar 13, 2009. 2:56 PM
YES. Machinae Supremacy for the win! :D
gmjhowe (author) in reply to UberNooberMar 14, 2009. 4:33 AM
MaSu FTW!
UberNoober in reply to gmjhoweMar 15, 2009. 6:33 PM
I'd also like to point out that this is a pretty sweet 'ible. As are all of yours! I think I'd really like to make one of these if I can ever find the time.
gmjhowe (author) in reply to UberNooberMar 16, 2009. 5:33 AM
"Don't find the time, Make the time." - gmjhowe 16/3/2009
cowscankill in reply to gmjhoweMar 17, 2009. 2:24 PM
I added that on my "you" page xD
gmjhowe (author) in reply to cowscankillMar 17, 2009. 3:11 PM
Sweet, i should add it to mine.
Madrias357 says: Mar 3, 2009. 6:40 PM
Just a good thing for me it won't kill Werewolves.
gmjhowe (author) in reply to Madrias357Mar 4, 2009. 12:05 PM
It will kill most things. The silver and acid seem to make a difference.
billybobo3 in reply to gmjhoweMar 11, 2009. 1:24 PM
You'd think the silver would make it more effective against werewolves...or am I stereotyping ? Anyway, that is an awesome prop. Thanks for the Instructable
Madrias357 in reply to billybobo3Mar 16, 2009. 9:00 PM
Only against betas. Alphas are resistant. I know a bit of wolven lore, as far as that goes...
gmjhowe (author) in reply to billybobo3Mar 11, 2009. 2:21 PM
Thanks for the comment! Im glad you like it.
deathshells says: Mar 14, 2009. 10:08 AM
im hoping im not too late, i noticed that someone asked if youd sell it and im wondering is it still up for offer?
gmjhowe (author) in reply to deathshellsMar 14, 2009. 11:53 AM
Unfortunatly this one has been sold. My other ones are for sale feel free to ask a price on any of them. Or you can commision me for one. Or I can sort out supplying some materials.
deathshells in reply to gmjhoweMar 15, 2009. 3:05 AM
damn it! oh well this still looks awesome ill just make one myself! great instructable!
rhino132456 says: Mar 14, 2009. 12:53 PM
does it shoot for real?
gmjhowe (author) in reply to rhino132456Mar 14, 2009. 3:54 PM
Please read the instructable.
HOMEPIE64 says: Feb 15, 2009. 8:59 PM
is the correct word "vampiric" or "vampyrical"????
naruto the ninja13 in reply to HOMEPIE64Mar 14, 2009. 7:52 AM
the correct term for an object of vampire origin is vampiric
gmjhowe (author) in reply to HOMEPIE64Feb 16, 2009. 1:53 AM
who knows.. Its not like they exist really.
moonball33 in reply to gmjhoweApr 2, 2009. 1:23 PM
Only as far as you know.
corey11 says: Mar 4, 2009. 10:57 AM
Dude this thing looks wicked cool!!
gmjhowe (author) in reply to corey11Mar 4, 2009. 12:04 PM
Thanks!
DELETED_KillerBruin says: Feb 23, 2009. 11:19 AM
gmjhowe (author) in reply to DELETED_KillerBruinMar 4, 2009. 9:08 AM
I've got a pop rivet gun that could manage that! This item is waiting to be posted to its buyer. So no more mods.
-JESUS- says: Feb 23, 2009. 12:25 AM
Wow! that's pretty cool. I would make it as a prop if it wasn't counted as a real gun in Australia, i would also use metal and wood. good work though!
gmjhowe (author) in reply to -JESUS-Feb 23, 2009. 4:44 AM
Im in the uk. It is technically illegal here also. But, with it being a prop, and not a replica, its a bit of a loop hole. If they raid my house though, ima have alot splainin to do.
firebird11692 says: Feb 22, 2009. 12:49 PM
Dude, you made an over-under double barrel shotgun. For killing vampires. That's AWESOME.
gmjhowe (author) in reply to firebird11692Feb 22, 2009. 1:55 PM
Thanks! Thats a pretty awesome comment to get.
flipit119_aaa says: Feb 19, 2009. 1:44 PM
although pretty cool if your a 10 year old
kerns says: Feb 12, 2009. 1:17 PM
Nice explanations and cool project. I think your unadorned bolt/screw heads detract though... too mundane! Could you wipe over a bit of putty and touch on some more paint to hide their true nature?
gmjhowe (author) in reply to kernsFeb 12, 2009. 1:42 PM
maybe a dap of epoxy resin and a bit of touch up with a sharpy and silver paint? thanks for the comment!
amakerguy says: Feb 12, 2009. 7:48 AM
To make this instructable you NEED to LOOK at the pictures VERY CLOSELY. you do not describe how you keep the barrel from folding farther then it needs to, and how it stays closed and not open up all the time, and where to get a template for the handle (not everone has a sniper). :-o
gmjhowe (author) in reply to amakerguyFeb 12, 2009. 9:04 AM
I've amended the hinge step with further description relating to the pictures. Regarding the sniper, I've added a link to my sniper rifle ible, so people can figure it out. Originally, for the shape, i just got a couple of web pictures up on screen, then sketched it by hand.
amakerguy in reply to gmjhoweFeb 12, 2009. 11:56 AM
That better, not great but good enough for people to understand it better.
gmjhowe (author) in reply to amakerguyFeb 12, 2009. 12:19 PM
Indeed, but as with alot of my ibles, its not a specific follow exactly guide, things differ alot on the items used. Most people will manage fine with their own commons sense.
amakerguy in reply to gmjhoweFeb 12, 2009. 12:24 PM
Thats true. I'm working on finding the parts for this ible, I already have the barrels, I'm trying to get the handle shape and cardboard. Then the hinge.
gmjhowe (author) in reply to amakerguyFeb 12, 2009. 1:17 PM
cool, any more question do ask, and be sure to show me a finished pic!
mikeEinsein says: Feb 3, 2009. 5:37 PM
2 thingz. 1: are you doing any new projects? 2: in the next few weeks look around on this site for sum new cyberpunk pistols. I made dem sveet!
gmjhowe (author) in reply to mikeEinseinFeb 4, 2009. 12:03 AM
I have many many project ideas. But, as for current projects, 1. The book of time, and 3 'decoder' books, as well as an instrument for reading said book 2. The Liquid Blade of The Three Deserts - spear sword 3. Multi-missile pepper box pistol
mikeEinsein in reply to gmjhoweFeb 4, 2009. 5:51 PM
my confirmed projects include a bulky junk gun with break-in-half action, a futuristic bladerunner type gun, and a compact one barrel sawed-off shotgun. my only set back is the knowledge of how to do a sweet paint job, like the one used in your vampiric shotgun, and lack of a digital camera.
gmjhowe (author) in reply to mikeEinseinFeb 5, 2009. 12:06 AM
The dry brushing really isnt that hard, i can explain it more via a PM if you wish?
mikeEinsein in reply to gmjhoweFeb 5, 2009. 4:37 PM
sounds like a plan. just one question, what's PM
gmjhowe (author) in reply to mikeEinseinFeb 5, 2009. 11:58 PM
If you click on my name, you will get to my profile, once there, cast your eyes to my avatar, then just below that, is a button bearing the name Private Message, this being the elusive PM, that we speak of.
mikeEinsein in reply to mikeEinseinFeb 3, 2009. 5:51 PM
I say. Since i have absolutley no money and i love your work, why dont i trade weapons with you?
I will keep my eye out, i tend to browse all the recent ones.
theblackalbum110 says: Feb 4, 2009. 12:49 PM
I,m planning to make a Cyber-punk lever action rifle. i just need to find the time
gmjhowe (author) in reply to theblackalbum110Feb 4, 2009. 2:11 PM
like the one he uses in terminator? Make the time. I cut out TV in order to make things.
BioMaster1299 says: Feb 3, 2009. 1:01 AM
Blade should've used that on Dracula... If you've seen Blade:Trinity
gmjhowe (author) in reply to BioMaster1299Feb 3, 2009. 5:30 AM
Yeah ive seen Blade trinity! Would have stood no chance...
ajk97 says: Feb 1, 2009. 10:54 AM
Here it is all i need to do is add the leather
gmjhowe (author) in reply to ajk97Feb 1, 2009. 2:44 PM
Very nice! should look pretty sweet with the leather on.
mg0930mg says: Jan 31, 2009. 4:12 PM
Can I have your V for Vendetta poster.. Hehe.
Meroki says: Jan 11, 2009. 4:01 AM
dude that is awesome, could i like...commision one off of you? btw nice choice in music x3
gmjhowe (author) in reply to MerokiJan 11, 2009. 6:34 AM
You can purchase this one if you want. I don't have room for it.
Meroki in reply to gmjhoweJan 11, 2009. 8:37 AM
what would it cost?
gmjhowe (author) in reply to MerokiJan 11, 2009. 12:50 PM
id be looking for about £40 for it.
Meroki in reply to gmjhoweJan 12, 2009. 3:54 AM
oh, um i need to find out how much that is in USD
gmjhowe (author) in reply to MerokiJan 12, 2009. 4:09 AM
40.00 GBP = 59.8486 USD
You got good conversion atm... few months back that would of been 80 USD
mg0930mg in reply to gmjhoweJan 31, 2009. 4:11 PM
$60. HMM.. I want that. I need money though...
bobby sissom says: Jan 31, 2009. 4:06 PM
your gonna shoot your eye out
ajk97 says: Jan 31, 2009. 1:04 PM
I made one and its sweet! (*-*_)
gmjhowe (author) in reply to ajk97Jan 31, 2009. 3:43 PM
Picture!
cowscankill says: Jan 19, 2009. 2:53 PM
Very nice, indeed. I still have not trained myself to apply much detail to my things.
gmjhowe (author) in reply to cowscankillJan 19, 2009. 3:42 PM
You will, give it time.
cowscankill in reply to gmjhoweJan 19, 2009. 5:12 PM
Ah, well, let's just see what happens to my future gun models ;)
gmjhowe (author) in reply to cowscankillJan 20, 2009. 12:26 AM
Well, you always welcome to pm/comment me any time for help. I look forward to seeing some of them! Even if you don't manage a full ible, be sure to at least put slideshows up. (i know they don't get as many views, but i love to absorb other peoples ways of working and ideas)
NinjaSloth says: Jan 15, 2009. 4:47 PM
what is PVA?
gmjhowe (author) in reply to NinjaSlothJan 16, 2009. 12:01 AM
Wood glue, or elmers glue.
jwomack94 says: Jan 13, 2009. 9:36 AM
Those vials look suspiciously like insulin vials for a Novopen. (My son is Type 1 diabetic) Great use for them.
gmjhowe (author) in reply to jwomack94Jan 13, 2009. 1:43 PM
Yeah, my mum supplies me with them! Great thing to use.
jwomack94 says: Jan 13, 2009. 9:40 AM
How do you keep the hinge closed when 'in action'? Is there a latch that I can't see?
gmjhowe (author) in reply to jwomack94Jan 13, 2009. 1:42 PM
the tightness of the bolt that it pivots on is enough to hold it in place. You could add magnets however.
Nattwood says: Jan 4, 2009. 2:21 PM
im going to be builduing a working and firing pump action crossbow as well (or as soon as i get to a hardware store anyway) so if anyone wants an instructable plz tell me so i can start it soon
gmjhowe (author) in reply to NattwoodJan 5, 2009. 12:45 AM
Kiteman Says..
kitemanslaw.tif
Nattwood in reply to gmjhoweJan 5, 2009. 4:33 AM
ok then i will post everything, but i dont know how long it will be its still kinda in planning and prototyping, but as soon as i get started on the full thing i will post.
gmjhowe (author) in reply to NattwoodJan 5, 2009. 5:01 AM
thats fine, make sure to take your time, i always get a much better end result if i take my time.
Nattwood in reply to gmjhoweJan 5, 2009. 5:08 AM
well im on holidays now until 27th of jan so i might have it finished by then it all depends
gmjhowe (author) in reply to NattwoodJan 5, 2009. 5:25 AM
well, if you need some pointers feel free to PM me etc, or you can talk to me directly in the Instructables Chatroom im the head Moderator, so im in there alot..
Nattwood says: Jan 3, 2009. 9:56 PM
nice idea i like it, im thinking of doin one but crossing it with this
gmjhowe (author) in reply to NattwoodJan 4, 2009. 5:18 AM
Nice, kind like a shortened three barrel shotgun idea - i did think about going for more than two barrels, but bumpus quickly put me back in my place.
ItsTheHobbs says: Dec 26, 2008. 5:48 PM
Just a question, what do the silver nitrate and acid do? I mean, the c-4s kinda obvious...
gmjhowe (author) in reply to ItsTheHobbsDec 26, 2008. 6:23 PM
Silver nitrate - vampire alergic to silver, also handy for werewolves. Acid, just damages most things...
ItsTheHobbs in reply to gmjhoweDec 27, 2008. 1:49 PM
Vampires aren't allergic to silver... I personally would put garlic paste in it's place.
peanutthegreat in reply to ItsTheHobbsJan 3, 2009. 8:49 PM
"Ahhhhh, vampires! coming down from the hills! Quick Boby, get out the garlic paste....
gmjhowe (author) in reply to ItsTheHobbsDec 27, 2008. 2:15 PM
and you have taken out how many vampires? trust me, they do not like silver...
ItsTheHobbs in reply to gmjhoweDec 27, 2008. 2:39 PM
I've met enough vampires to know they are not affected by silver.
gmjhowe (author) in reply to ItsTheHobbsDec 27, 2008. 2:42 PM
Met, but not slain... hmmm
ItsTheHobbs in reply to gmjhoweDec 27, 2008. 5:14 PM
Well, from what I've read, some vampires may have an aversion to silver. Still, I would put garlic in there.
gmjhowe (author) in reply to ItsTheHobbsDec 28, 2008. 5:32 AM
Well, from what i have experienced, although silver is not lethal, it weakens their bodily forms, which allows the acid and c4 to do their thing.
Garlic, they just don't like the taste of... it doesn't do them any harm..
mg0930mg in reply to gmjhoweDec 28, 2008. 11:46 AM
You could put garlic chunks inside the silver vial. That way you both are satisfied.
heliosrising in reply to mg0930mgDec 30, 2008. 9:45 PM
They don't like silver. My Cousin's one, and he'd know.
mg0930mg in reply to heliosrisingDec 31, 2008. 9:44 AM
That's what I'm saying, put garllic chunks into the silver. That way they are weakened. Shoot it into their mouth, it burns/hurts them, and they don't like the taste.
Mr. Brownie in reply to mg0930mgJan 1, 2009. 10:25 AM
Just do what Van Hellsing did to his stakes, put Holy Water in them.
peanutthegreat in reply to Mr. BrownieJan 3, 2009. 8:50 PM
Yaaaaaay!!!!! Hellsing!!!!!
ItsTheHobbs in reply to Mr. BrownieJan 3, 2009. 8:17 PM
Holy water is just one of those strange religious beliefs that I don't get. What makes it holy, a strange man that talks to it?
mg0930mg in reply to Mr. BrownieJan 1, 2009. 4:47 PM
True, I forgot the holy water.
heliosrising in reply to mg0930mgJan 2, 2009. 10:30 PM
Holy water soaked stakes smeared with garlic, with bits of sliver on it. Perfect.
Mr. Brownie in reply to heliosrisingJan 3, 2009. 9:14 AM
Actually, Hellsing had a vial at the top aof a stake that contained holy water, so the water is injecteed into the vampire and kills it from the inside.
gmjhowe (author) in reply to Mr. BrownieJan 4, 2009. 5:19 AM
well if were gonna go that far, i will get to work on some UV rounds... sure to do the trick..
mg0930mg in reply to heliosrisingJan 2, 2009. 10:51 PM
Yes, Muy Bien! haha, Nice idea.
Chrysaor says: Dec 31, 2008. 10:49 AM
That Gun is amazing! But sorry, being the newbie!, I cant work out how you load the shells without them going all the way down the tubes and falling out? :| Dumb question, I know, but just can't work it out (",)
gmjhowe (author) in reply to ChrysaorDec 31, 2008. 12:36 PM
I put a couple of bolts in the barrel which act as stoppers, thanks for the comment
Chrysaor in reply to gmjhoweJan 1, 2009. 1:49 AM
Thanks for clearing that up :) You've really inspired me to make one now. Thanks for posting your build and picture of the end result. Awesome!!!!!! :D Right off to Wickes tomorrow morning then :) !!
gmjhowe (author) in reply to ChrysaorJan 1, 2009. 6:24 AM
haha! yes, alot of stuff comes from there, including the hinge i use on most my handguns!
tallfuzzyone says: Dec 23, 2008. 6:09 PM
but doesn't work.....useless....
gmjhowe (author) in reply to tallfuzzyoneDec 24, 2008. 3:27 AM
Its a prop, its useful as a decoration for a home (talking piece) or to sell for lots of money to indie film makers.
mg0930mg in reply to gmjhoweDec 28, 2008. 11:47 AM
Have you sold any of yours?
gmjhowe (author) in reply to mg0930mgDec 28, 2008. 2:19 PM
not yet, but working on it!
mg0930mg in reply to gmjhoweDec 31, 2008. 9:48 AM
I've seen steampunkk nerf guns go for $600 for the cs longshot. Your's could easily go for that amount. Good Luck!
mg0930mg in reply to gmjhoweDec 28, 2008. 2:42 PM
You would make a lot. I know I'd easily pay $50+ bucks for one of them guns. If I had the money.
Damage, Inc. says: Dec 27, 2008. 5:34 PM
One thing I've always wanted to do is take apart a camera and rig up the flash so at the press of a button it would go off in the barrel.
gmjhowe (author) in reply to Damage, Inc.Dec 28, 2008. 5:33 AM
I have a camera flash gun, awaiting this purpose - you can buy flash guns that clip onto cameras, most the time they have a test feature - saves tearing anything apart, or resoldering etc.
ItsTheHobbs says: Dec 26, 2008. 3:49 PM
Best one so far, definitely. Hmmm...... I might even be able to make this one, if I do, I'll post some pics.
gmjhowe (author) in reply to ItsTheHobbsDec 26, 2008. 5:45 PM
Nice, i look forward to some pictures!
temp says: Dec 25, 2008. 1:31 PM
it would be awesome if it was like... real. but it's not =( ...sigh
mikeEinsein says: Dec 22, 2008. 9:13 PM
I've Been admiring your work for a while and I must say, this might be one of your best pieces to date. Keep it up! Also on another note, I'm new to the cyberpunk scene, so any tips you might have could be very helpfull
gmjhowe (author) in reply to mikeEinseinDec 22, 2008. 11:58 PM
Make it look like its old, and grungy - try not to over complicate things, a partial dry brushed effect always works, there is always something a bit future like about things, normally relating to computers, etc. Thanks for the comment.
mikeEinsein in reply to gmjhoweDec 23, 2008. 12:18 PM
Thanks! Oh, and by the way, My name is supposed to be mikeEinstein but my forgettfulness made it look like Einsein. I'm also working on a project making an airsoft gun look CP. I could send a pic and you could give me suggestions.
gmjhowe (author) in reply to mikeEinseinDec 23, 2008. 12:51 PM
Id love to look at some pics, and offer advice.
mikeEinsein in reply to gmjhoweDec 23, 2008. 2:34 PM
Cool! Just as soon as I get a digital cam. I'll post'em
mikeEinsein in reply to mikeEinseinDec 23, 2008. 2:36 PM
Oh! and I might have a lead on an old webcam so I might just post the thing on my you tube account.
gmjhowe (author) in reply to mikeEinseinDec 24, 2008. 3:26 AM
sounds good.
mikeEinsein says: Dec 24, 2008. 1:05 AM
also, an anti freak hand cannon could go nicely with the shotgun.
Brennn10 says: Dec 22, 2008. 11:36 AM
The king of cyberpunk strikes once again. This looks sweet!
gmjhowe (author) in reply to Brennn10Dec 22, 2008. 1:34 PM
Thanks! Its nice to be called to king of cyberpunk, instead of steampunk!
Brennn10 in reply to gmjhoweDec 22, 2008. 4:12 PM
Haha, well I guess cyberpunk is a mix between the internet and steampunk. Of which you utilize both!
gmjhowe (author) in reply to Brennn10Dec 22, 2008. 4:14 PM
Indeed.
MatrixPhreak says: Dec 22, 2008. 2:35 PM
Real nice 'ible, it looks great and I love the shells. Also, nice choice on music for the video . \m/ Machinae Supremacy \m/
gmjhowe (author) in reply to MatrixPhreakDec 22, 2008. 3:37 PM
YEAH! MACHINAE SUPREMACY! Thanks for the comment, the shells were my fav part, they are what make it different.
voltskaterzb says: Dec 22, 2008. 1:00 PM
does it really shoot?
jongscx in reply to voltskaterzbDec 22, 2008. 2:15 PM
Yes, but unfortunately only at vampires...
gmjhowe (author) in reply to voltskaterzbDec 22, 2008. 1:35 PM
... Try reading the ible! :P
omnibot in reply to voltskaterzbDec 22, 2008. 1:31 PM
Yes, cardboard tubes and tinfoil is a major component in all modern firearms.
gmjhowe (author) in reply to omnibotDec 22, 2008. 1:59 PM
Haha! thats the funniest comment ive read in a while.
omnibot in reply to gmjhoweDec 23, 2008. 3:56 AM
Thanx
this comment is sarcasm-free
chiok says: Dec 22, 2008. 12:30 PM
Next to your creative ability, is your painting abilities. I always like the paint effect you achieve on your items that have that "antique firearm" look that some of my actual guns have. Beautiful work again sir!
gmjhowe (author) in reply to chiokDec 22, 2008. 1:35 PM
Everyone loves the paint jobs, ive done it so many times now, its like second nature! Thanks for the comment.
jeff-o says: Dec 22, 2008. 9:53 AM
Now why didn't Buffy think of this? ;)
gmjhowe (author) in reply to jeff-oDec 22, 2008. 11:02 AM
Well, im not sure why. There was that episode where she used a rocket launcher?
jeff-o in reply to gmjhoweDec 22, 2008. 11:28 AM
Oh, I'm sure. In general though, she tends to stick with sharp and pointed weapons. I suppose that it would have been more accurate to ask why Blade didn't think of this. ;)
bumpus says: Dec 21, 2008. 4:53 PM
Yes.
Yes..
gmjhowe (author) in reply to bumpusDec 21, 2008. 11:55 PM
I can picture the way you pronounce those words perfectly.
=SMART= in reply to gmjhoweDec 22, 2008. 1:51 AM
Hahaha yea me too :D
Kiteman in reply to =SMART=Dec 22, 2008. 7:51 AM
Sort of a faraway dreaming look, combined with a slack jaw and just little too much drool...
gmjhowe (author) in reply to KitemanDec 22, 2008. 9:35 AM
haha, with a little twist of evil?
=SMART= in reply to gmjhoweDec 22, 2008. 12:03 PM
haha like a mad scientist
crapflinger says: Dec 22, 2008. 10:20 AM
just my opinion but it looks a lot more resident evil than it does cyberpunk...but i guess that's more a state of mind than a look...
gmjhowe (author) in reply to crapflingerDec 22, 2008. 11:03 AM
Perhaps, i see what you mean, kinda grungy, like the games.
crapflinger in reply to gmjhoweDec 22, 2008. 11:24 AM
still nifty looking though
KentsOkay says: Dec 22, 2008. 4:29 AM
That has got to be the most bad ass gun TO DATE. Congrats, 5 star!
KentsOkay in reply to KentsOkayDec 22, 2008. 9:43 AM
See, silly JimyJoe no think me post a comment..
Sunbanks says: Dec 21, 2008. 3:35 PM
That's really awesome looking! :D How long did it take you to make?
gmjhowe (author) in reply to SunbanksDec 21, 2008. 3:43 PM
Ive been working on it and other things for about 5 weeks or so now.
=SMART= says: Dec 21, 2008. 3:39 PM
Very very cool ! It looks really good ! I love the vial shells !!
gmjhowe (author) in reply to =SMART=Dec 21, 2008. 3:42 PM
Thanks smart! they are what make it really..
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
