Remove these ads by
Signing UpStep 1The parts for the VDG
These are the parts used.
1 Lightbulb socket (I pried out the bottom most contact, to give less surface area to bleed off static charges.
1 Large globe lightbulb
1 1.50"" to 2" pvc adapter (lightbulb socket fits in here nicely, and gives space to mount the brushes)
1 2" to 3" pvc adapter
1 3" to 3" PVC Coupler
1 5" threaded rod and assorted washers and nuts, I think it was 5/32"
1 6" threaded bolt, and washers, small enough for the wheel to glide on)
2 slightly curved plastic bedframe rollers. (was going to use skateboard wheels sanded down on my drillpress, but my dad had these in his shop)
1 3"x3"x1.50" PVC Tee
1 length of pvc (Ihad to use ABS which is not as good due to its carbon content, but it was all I could find in precut lengths, and didnt want to buy 9 more feet of pipe.
1 1.50" to 0.25" pvc adapter
2 sets of skateboard wheel bearings,
Some copper wire both to make a ground wire, and a spark wand wire, but also to make the brushes.
1 outlet plug (this is only connected to the ground pin
1 can of cold galvanizing spraypaint
1 can of copper metallic spraypaint
1 drill socket adapter. (to turn the bottom wheel)
1 drill, (optional speed controller)
1 sheet of latex exercise banding
1 tube of bike tire patch glue.
Teflon pipe tape,
copper foil tape
Other misc Stuff, A board to screw it down to and some long screws. and A binding post for the charge wand, some wire, a old junk drawer nob pull for the wand, some plastic tubing for the shaft of the wand.
nice project however.
Anything in particular you would like to see?
That would be useful for folks that want to build it! Text is nice, but pictures are always very precious to help check everything is ok!
thanks a lot !
and what difference does the ground make in that time?
you would probably need to somehow mount the wand so that you can get a consistent distance for timing. maybe mount it to the side of the shaft? as a matter of fact, it would be cool for demonstration if you had a couple of them mounted so that it could spark back and forth randomly.
I did find the charge does indeed build faster with the ground plug in, and you get a better "zap" if you are touching the wand to ground yourself.
ideally for the best zap zap, demo you setup another globe same size ans height and ground that one,
I may play with garden globes next.
Scavenged the wire, and the wheels, and the wand knob, and the wood its mounted on, used a drill and a controller we had.
oh yah the exercise band was pricy, came in a pack of 3 at about $12 only used part of one, so will probably use the other 2 for something else like a giant slingshot or whatnot. might be able to buy single ones, or find another source. (id love to find big rubberbands.
BTW Great Idable!!
Jax
Found at a local artshop, had nice large gummy ribber portfolio bands, that were about 1/2 the size i want. but would make a good VDG 1/2 this size.
