3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Van Gogh for Breakfast
Step 33) Construct
3) Construct
Now, begin construction! The final picture will be approximately 11” x 15”. On the large cutting board, use the ruler and a pencil to mark out the proper sized rectangle. Discard the ruler and pencil. From the pile of white bacon fat, select the longest pieces to frame the edge of the picture. You should now have a bacontangle (n. an 11” X 15” two-dimensional geometric figure formed of four sides and white bacon fat.) Cover empty baconangle inside with dark turkey slices. This is the foundation of your picture, so cover it thoroughly – none of the cutting board should be showing. This way the finished product will be as solid and beautiful as possible.
Using the piles of color, begin to assemble the picture. This is a picture of layers, so start first with the swirling cloud, and then move onto the moon and the stars. When you are happy with the placement, fill in the sky by weaving swirls of red around the stars and clouds. Open the final package of bacon and use whole pieces to create the hills. Use layers of various depth and breadth to re-create the movement and life of the painting.
Now assemble the Village. From the remaining whole strips of bacon, cut a triangle that’s about 3 inches long and 1 inch wide. This is your church steeple. (Fun factoid: if you open it up, you’ll see all the people!) Slice up various smaller squares and triangles that will become the church building and village houses. Place them on the picture in ways that resemble the buildings and church in the painting.
You’re almost finished! Twist the lighter turkey bacon slices and place them in the extreme foreground of the picture, left of center. Houston, we have a treetop! Use the rest of the bacon bits to fill in spots and add detail and interesting texture to the picture. Don’t forget doors and windows in the village, vegetation on the hills, and divots and swirls in the sky. If you have much more energy than I do, you can even incorporate bacon bits, bacon grease, and the sadly misconstrued Canadian bacon.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:CopperTwist
