3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Van de Graaff Generator made from junk
This is instructions on how I built a Van de Graaff generator from junk lying about my house.(And I do mean junk.)
Step 1Parts
parts
Okay, the first thing you will want to do is gather all of the necessary parts. They include 1 pencil with ereaser, two dried out old click pen parts, a piece of 8in. long PVC pipe, 1 dead light bulb, 1ft long piece of 2 by 4, a elastic band, one metal paper clip, aluminum foil, see through tape, one small toy motor, 9 volt battery, and some junk wire. A good sense of humor and a few band-aids would come in handy too.
293 comments
1-40 of 293next »
May 21, 2012. 8:45 PMmaryamyam says:
is the top wire attached to BOTH the light bulb and the upper rubber band?
Mar 2, 2012. 5:11 AMSCIENCEPAL says:
Nice project for a science fair!!!!
Oct 23, 2011. 11:56 AMTobor 2.0 says:
Can you leave out the bottom wire? I want to know the point of the bottom wire.
Dec 9, 2011. 4:54 PMjoshuaw97 says:
the bottom wire is to keep the generator grounded.
Nov 15, 2011. 1:46 PMswaghmare says:
where does the another end of the bottom wire go????
plz reply fast.
Nov 3, 2011. 7:33 PMbuilder23 says:
I REALLY need to know if this generator works. i am doing a science fair project on electrostatic electricity, and have already tried to build one of these from another website. Somebody please respond!
Mar 20, 2007. 10:56 AMrocketbat says:
LOL!" super size it and send your neighbors annoying cat into the next century" that is just what i intend to do!
Oct 26, 2011. 3:09 PMcheezy monkey says:
Been there.
Done that.
=D
Jun 3, 2010. 2:24 PMyetibunny says:
You could also send your neigbor with them!   >: )
Jun 29, 2011. 2:37 PMeric m says:
photography here is awful.
how bout some closeups of the comb and pulley.
Jun 21, 2011. 3:59 AMDaniel Deacon says:
does it have to be PVC? or could the tube be Cardboard or something else thank you :D
Apr 30, 2011. 9:16 AMCrazy-Inventor says:
Hi,
Can u plz tell me how much volts will this generator produce?
and one more question if it produces high voltage then why can't we use it for electicity supply for home.
waiting 4 reply.
Thnx
-Jerin
May 21, 2011. 1:30 PMSLDxRaPiiDZz says:
because this needs a motor, I think it produces electrostatic energy.
May 23, 2011. 2:58 AMCrazy-Inventor says:
thank you
May 11, 2011. 2:46 PMtecnokid says:
why do we have to have a burnt lamp instead of a working one
Dec 28, 2009. 2:12 PMGrundalizer says:
 Where is it in action?
May 7, 2011. 1:03 AMmstryker says:
thats what she said
Apr 11, 2011. 2:03 PMprncess_101 says:
What brushes are you talking bout?
May 3, 2011. 5:35 PMgmartínez schacht says:
The brushes can be stranded copper wires
May 3, 2011. 5:34 PMgmartínez schacht says:
Hey there, could youplease specify if its a broken lamp or a burned one? Also, a xmas globe culd work instead of a lamp?
Apr 20, 2011. 6:31 PMjoehudy says:
i bult this and it dednt work like every other vdg i tryed
Mar 15, 2011. 5:39 PMjustindouthat says:
has anyone gooten this design to work
Jan 15, 2011. 3:00 PMWagging your Dogma says:
This is a fascinating construction project. Have you built anything bigger?
Jan 3, 2011. 6:00 PMvinc3_76 says:
i'm trying to make my own VDG, and I follow ur step... but still it doesnt work...
what should I do?
Jan 3, 2011. 8:18 PMaidylgs says:
I have the same problem. I built the VDG according to protocol but still NO SPARKS. Need Advice.
Dec 3, 2010. 8:42 AMslimshady13 says:
im trying to charge a leyden jar for a science project with an equal amount of charge. so what i mean is that if i charge it with static each one wouldnt have the same amount of charge inserted. would this work for that reaason and good tutorial.
Oct 14, 2010. 7:09 PMA.C.E. says:
do you know how many volts this is? and how far can it ark? i want to make one and this seems good because it doesnt need to be plugged in haha
Jul 8, 2010. 11:40 AMsora says:
if we had a working light bulb would there be any way of making it turn on and off (aka spark gap)?
Oct 12, 2010. 3:19 AMnutsandbolts_64 says:
planning on making a spark-gap transmitter I see.... Well, the light bulb won't be a spark gap. For all I know it's either just gonna blow out or just shine for a moment.
Sep 5, 2010. 3:17 PMEthan B says:
(removed by author or community request)
Oct 12, 2010. 3:18 AMnutsandbolts_64 says:
Well yeah it can hurt you, but it won't kill you. For sticking up hair, you're gonna have to be standing on some kind of insulator (no, not just the ground).
Apr 5, 2009. 7:32 PMcowgomoo says:
is is the faster the motor the more power the output?
Apr 21, 2009. 2:35 PMxerxesx20 says:
Not quite, but speed will effect how quickly charge is built up, but for more power, a larger, smoother surface (EG: A metal ball) is the best upgrade. Electrons are lost through rough areas due to corona discharge, or the "leaking" of stored electrons into the atmosphere, eventually finding their way to ground. Using different materials in the triboelectric series can also aid the rate of charge developed, thus increasing efficiency of the charge system. To increase the efficiency of the charge storage system the "oomph" (of the spark) if you prefer. A large seamless flat, smooth and overall shiny surface (who doesn't love something shiny?!) will work wonders. :-)
Sep 29, 2010. 3:27 PMcowgomoo says:
thanks!
Jul 9, 2010. 11:52 PMimadeyou says:
can the bulb save lots of charges?
Sep 13, 2010. 5:31 PMkikiclint says:
the amount of charge depends on the size of the sphere. I did the math a while ago, but I think for relatively dry air it is about 3 million volts per meter radius.
Sep 9, 2010. 7:23 PMjake_the_snake says:
thanks for replying to my last q but i am just wondering where the other end of the wire goes, the bottom one
thank you
Sep 6, 2010. 9:18 AMjake_the_snake says:
Im confused, where does the elastic band go?
Sep 9, 2010. 12:38 AMLance Mt. says:
It connects both top, and bottom parts of the PVC.
Jan 16, 2008. 4:08 PMNicholerae says:
Where do u get the motor at?
1-40 of 293next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:Sedgewick17
