Van de Graaff Generator made from junk
 by Sedgewick17
Featured
This is instructions on how I built a Van de Graaff generator from junk lying about my house.(And I do mean junk.)
Step 1: Parts
Okay, the first thing you will want to do is gather all of the necessary parts. They include 1 pencil with ereaser, two dried out old click pen parts, a piece of 8in. long PVC pipe, 1 dead light bulb, 1ft long piece of 2 by 4, a elastic band, one metal paper clip, aluminum foil, see through tape, one small toy motor, 9 volt battery, and some junk wire. A good sense of humor and a few band-aids would come in handy too.
1-40 of 312Next »
dng8 says: Jun 18, 2013. 9:14 AM
here's another website from MAKE http://blog.makezine.com/projects/simple-van-de-graaff-generator/
marvel_x23 says: Apr 20, 2013. 5:45 AM
what can be used instead of the pvc tube
scristian says: Mar 2, 2013. 6:23 PM
i made a shake machine :(
scristian says: Mar 2, 2013. 6:08 PM
Does it still work if i use 1 engine on the top roller and one on the bottom one?
also i covered the top roler with somme duct tape so that the ruber band stays centered.
PS:for somme reason mine doesn't do anything other that shake
awesomecreations says: Feb 1, 2013. 10:29 PM
Haha, read the title of this step...
Velin9 says: Feb 1, 2013. 3:58 PM
also can you use a plastic straw instead of the pen tube?
Velin9 says: Feb 1, 2013. 3:48 PM
Can you use a piece of foam for the base instead of the wood or not?
btw this looks like a very cool project. good job.
_
__\_ `-\
(____))( \----
(____)) _
(____))
(____))____/----
Thumbs Up
mohtashim says: Jan 16, 2013. 9:11 AM
Where the bottom brush has to be attached?
FREEZZZINGICE says: Jan 11, 2013. 6:16 AM
Does it actully work?
SgBriggs says: Jan 5, 2013. 8:01 PM
dose the grounding wire need to touch the ground or the - terminal on the battery or a wand so you can do the lightning stick thing?
frederickgraff says: Dec 11, 2012. 11:17 PM
Check out www.physicsplayground.com for extreme Van de Graaff generators!! Its a must see!!
teslapulsa94 says: Nov 13, 2012. 2:28 PM
how thick pvc?
CoolDon says: Sep 27, 2012. 12:13 AM
and if we attach a 9 volt battery to a toy motor wont it burn?
CoolDon says: Sep 27, 2012. 12:12 AM
Hey can we run something on this one because i need to do it for ma science fair project
swaghmare says: Nov 15, 2011. 1:46 PM
where does the another end of the bottom wire go????
plz reply fast.
CoolDon in reply to swaghmareSep 27, 2012. 12:10 AM
Its a ground wire i think so!
Aron313 says: Aug 19, 2012. 3:11 PM
Do you have a video on it?
Isaac Laserman says: Aug 19, 2012. 1:04 PM
video please
onlymadhur007 says: Aug 7, 2012. 7:52 AM
can anybody plz send me the pdf file for it?
i need it urgently as m havin an exhibition in school.
Thanx :)
KronoNaut says: Mar 22, 2007. 8:38 PM
Am I assuming correctly that you attach the top lead to the aluminum foil, and not the metal part of the bulb?
Daxuto in reply to KronoNautJun 15, 2012. 6:35 PM
Yeah, connecting to the metal of the bulb would just attach to the filaments, however, what we want is charge to build up in the foil sphere outside.
maryamyam says: May 21, 2012. 8:45 PM
is the top wire attached to BOTH the light bulb and the upper rubber band?
SCIENCEPAL says: Mar 2, 2012. 5:11 AM
Nice project for a science fair!!!!
Tobor 2.0 says: Oct 23, 2011. 11:56 AM
Can you leave out the bottom wire? I want to know the point of the bottom wire.
joshuaw97 in reply to Tobor 2.0Dec 9, 2011. 4:54 PM
the bottom wire is to keep the generator grounded.
builder23 says: Nov 3, 2011. 7:33 PM
I REALLY need to know if this generator works. i am doing a science fair project on electrostatic electricity, and have already tried to build one of these from another website. Somebody please respond!
rocketbat says: Mar 20, 2007. 10:56 AM
LOL!" super size it and send your neighbors annoying cat into the next century" that is just what i intend to do!
cheezy monkey in reply to rocketbatOct 26, 2011. 3:09 PM
Been there.
Done that.
=D
yetibunny in reply to rocketbatJun 3, 2010. 2:24 PM
You could also send your neigbor with them!   >: )
eric m says: Jun 29, 2011. 2:37 PM
photography here is awful.
how bout some closeups of the comb and pulley.
Daniel Deacon says: Jun 21, 2011. 3:59 AM
does it have to be PVC? or could the tube be Cardboard or something else thank you :D
Crazy-Inventor says: Apr 30, 2011. 9:16 AM
Hi,
Can u plz tell me how much volts will this generator produce?
and one more question if it produces high voltage then why can't we use it for electicity supply for home.
waiting 4 reply.
Thnx
-Jerin
SLDxRaPiiDZz in reply to Crazy-InventorMay 21, 2011. 1:30 PM
because this needs a motor, I think it produces electrostatic energy.
Crazy-Inventor in reply to SLDxRaPiiDZzMay 23, 2011. 2:58 AM
thank you
tecnokid says: May 11, 2011. 2:46 PM
why do we have to have a burnt lamp instead of a working one
Grundalizer says: Dec 28, 2009. 2:12 PM
 Where is it in action?
mstryker in reply to GrundalizerMay 7, 2011. 1:03 AM
thats what she said
prncess_101 says: Apr 11, 2011. 2:03 PM
What brushes are you talking bout?
gmartínez schacht in reply to prncess_101May 3, 2011. 5:35 PM
The brushes can be stranded copper wires
gmartínez schacht says: May 3, 2011. 5:34 PM
Hey there, could youplease specify if its a broken lamp or a burned one? Also, a xmas globe culd work instead of a lamp?
1-40 of 312Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
