3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Van de Graaff Generator made from junk
Step 9Step 8
step 8
The next and finale step is to wrap the dead light bulb in a piece of aluminum foil. The key to making the aluminum hold more of a charge is to smoothen it out as much as possible. Then you cut off any aluminum that might be touching the metal part of the bulb, and place it into the PVC pipe. Then attach the top brush wire to the light bulb. Well, that's it you now know how to build a Van de Graff Generator from junk which can give a door knob like spark or do neat tricks. Now the only thing left for you to do is super size it and send your neighbors annoying cat into the next century.
23 comments
May 21, 2012. 8:45 PMmaryamyam says:
is the top wire attached to BOTH the light bulb and the upper rubber band?
Oct 23, 2011. 11:56 AMTobor 2.0 says:
Can you leave out the bottom wire? I want to know the point of the bottom wire.
Dec 9, 2011. 4:54 PMjoshuaw97 says:
the bottom wire is to keep the generator grounded.
Mar 20, 2007. 10:56 AMrocketbat says:
LOL!" super size it and send your neighbors annoying cat into the next century" that is just what i intend to do!
Oct 26, 2011. 3:09 PMcheezy monkey says:
Been there.
Done that.
=D
Jun 3, 2010. 2:24 PMyetibunny says:
You could also send your neigbor with them!   >: )
Dec 28, 2009. 2:12 PMGrundalizer says:
 Where is it in action?
May 7, 2011. 1:03 AMmstryker says:
thats what she said
Jan 15, 2011. 3:00 PMWagging your Dogma says:
This is a fascinating construction project. Have you built anything bigger?
Sep 5, 2010. 3:17 PMEthan B says:
(removed by author or community request)
Oct 12, 2010. 3:18 AMnutsandbolts_64 says:
Well yeah it can hurt you, but it won't kill you. For sticking up hair, you're gonna have to be standing on some kind of insulator (no, not just the ground).
Jul 8, 2009. 12:26 PMbelgvr says:
what would happen to myself if i touch a BIG (really big) van de graaff generator? would I die? does electrostatic energy kills?
Aug 23, 2009. 3:30 PMlasermaster3531 says:
NO! every one should stop thinking that!!! static electricity is what makes your hand spark to a doorknob after walking on a carpet. it is also what lightning is, but short of that, there is no way in heck that you could be hurt by this or any other Van De Graaff. there is more risk in licking a 9 volt battery. now, on with the question. if you are insulated from the ground with a block of Styrofoam, you would charge up to the point where if you touch someone else they will get shocked. if you are just wearing shoes and not standing on styro, yow would be shocked repeatedly from your feet inside your shoes to the ground.
Jul 15, 2009. 9:11 AMBenthomash says:
Absolutely! This one couldn't kill you. not even a full sized 7ft tall you could. But a bigger one with the right amount of amprege could! Think of it this way, lightning is indeed static electricity!
Feb 12, 2009. 5:55 PMknoxarama says:
can you make a brush from conductive (not magnetic) copper wire strands?
Jul 24, 2009. 7:52 AMcodex653 says:
yeah you can
May 3, 2007. 9:49 PMvandeegraaffsrock!! says:
yo like does it like matter if u like have a like non llike dead like bulb like toatally(lol)<(~_~)>
Sep 6, 2008. 1:20 PMtheXmaker says:
I like...
Sep 19, 2008. 4:33 PMviacin says:
X RAYS? ha ha ha. I havn't heard that one yet. Whoever started that must have missed science class, like all year.
Jul 8, 2009. 12:25 PMbelgvr says:
hahah LMAO!!
Sep 28, 2008. 12:19 PMbiolethal says:
like all of school... lol where did you read it though?
Aug 26, 2008. 12:51 PMjeff-o says:
It really, really won't. You risk electrocuting yourself though.
Sep 29, 2008. 11:13 AMikke_1206 says:
Yeah, because you can't get electrocuted by this device on its own. Lol
Jan 31, 2009. 2:40 PMjridley says:
Yes, you're right. It is completely impossible to be electrocuted by this device. Absolutely impossible. You're as likely to be killed by a shock from a doorknob.
Jan 26, 2008. 4:23 PMmickdoodle says:
does this make ur hair stand up or shock u
Mar 27, 2007. 3:51 AMGifford says:
interesting, but pelase try to be more clear on what your saying.
Mar 24, 2007. 11:51 AMBillyBobFett says:
A nice thing to do is stick a thin strip of Kleenex or toilet paper to the top; it will raise up as the top charges up, and it gives a good indicator of how well the generator is working.
Mar 22, 2007. 8:38 PMKronoNaut says:
Am I assuming correctly that you attach the top lead to the aluminum foil, and not the metal part of the bulb?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:Sedgewick17
