Introduction: Home Made Swing
Picture of Home Made Swing
Hello, for school, I was assigned to make a homemade swing.
Follow the steps and come to the same result.
Step 1: Material
To make this swing, you will need 2 things:
- wooden beam (+- 80cm)
- 2x rope (+- 8m)
- 1x little rope (+-2m)
- bag
- weights
Tools:
- Drill
- Saw
- File brush
- Knife
Step 2: Drill
Picture of Drill
Drill 4 holes (diameter 11) in the wooden beam (2 each side) on a distance of 3.5cm and 7cm
Step 3: Larger the Outer Holes
Picture of Larger the Outer Holes
Larger the outer holes (diameter 30) and drill 1 cm deep.
Step 4: Slot
Picture of Slot
Saw from the side a slot (1 cm thick) up to the first hole.
Step 5: File Brush
Picture of File Brush
Work the slot with a nice file brush
Step 6: Big Rope
Picture of Big Rope
Stick your rope through the small hole and make sure it does not come loose.
at the other side of te rope, create at different locations (25cm apart) nodules.
Step 7: Little Rope and Bag With Weights
Picture of Little Rope and Bag With Weights
Fill the bag with weights.
Nodule small rope around the bag and close it.
Step 8: Perform
seamster (author)2014-12-17
Cool swing!
Can you explain more about the slots on the ends of the seat/beam? What are those for?
Sybren. (author)seamster2014-12-17
These serve to pull the rope there through and to confirm the knot in place.
see step 7, Video 2
seamster (author)Sybren.2014-12-17
Ah, that's brilliant. My apologies for missing that!
About This Instructable
395views
3favorites
License:
More by Sybren.:Home made swing
Add instructable to:
