3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Vans Roller Skates
Vans Roller Skates
It's easy to make your own Vans tennis shoe skates out of an old pair of roller skates. I chose the old school high tops because they have good ankle support and they're just bitchen.
Step 1Take apart old skates
I found these skates used on craigslist for $25. They were a size 10 and I wear a size 11.5 so I couldn't use the boots. I'll try to sell them back on craigslist for what I paid. It's cheaper to buy used skates rather than buy all the parts new online. You need the plates, 8 wheels and 16 bearings. It gets pretty expensive. I will probably buy some 72 mm Sims Snakes wheels later to make them even more awesome.
Remove the insole and unscrew the base plates of each skate. You might want to do one at a time so you can use the old skate as a reference when drilling the holes in you Vans.
26 comments
Dec 5, 2011. 11:13 AMlwhitehurst says:
Do the plates need to come from skates that are the EXACT same size as the shoes you are using or can they be smaller? Please email me at leannel80@hotmail.com.
Thanks!
Nov 27, 2011. 5:55 PMswaggbot says:
like i already have skates but the boot of mine ripped. can it still work and does it have to e vans only or can i use any shoe i want?
Nov 27, 2011. 5:48 PMswaggbot says:
Hey can i use any shoe or does it have to be vans?
Sep 8, 2011. 7:51 PMXoXWHITEXoX says:
My uncle has a pair of boots his dad designed where there is a washer with a notch on the bottom of the boot and when he buys new boots he drills a hole in the heel and has skates (the part his dad designed) that has a pin about (1/2 - 3/4" in diameter) that slides into the washer and he slides a lever over and locks it into place and the front just lips over the sole. When he's done skating takes the plate off and has boots to walk in. He's had these since he wore a size six shoe when he was a kid he's about 43 now. Great build!
Jun 15, 2011. 4:27 PMkat_the_vamp says:
WOW ive been pining away for skates n i wanted a pair for my birthday but i never could find any . then i found this n was like AWESOME and went looking for any trucks. i found some today n then realized that you posted this the DAY after my birthday this year :) how awesome are you
Jun 8, 2011. 1:57 PMsnotty says:
Hey, this is cool!
Makes me wonder though. You see, there is a common injury that results from wearing platform footwear. It's a little bone in your foot that gets busted when your platform shoe tips over. I wonder if some ankle support is in order here. Sorry to be a party pooper. Maybe we should just live dangerously lest we die of boredom :)
Jun 8, 2011. 1:04 PMBobMarleyFan says:
REALLY STUPID QUESTION: I don't know if it matters, but, do I have to use vans?
Jun 7, 2011. 3:13 PMdoxsys says:
I wonder if you could attach the plates with VHB tape or industrial-strength epoxy? That would obviate the whole bolting issue.
Jun 5, 2011. 8:06 PMkenny70 says:
Would this work with inline skates
Jun 5, 2011. 10:25 PMbeeedy says:
Suregrip actually sells an inline plate designed to be mounted on skate boots so with some slight modification it could be mounted to shoes. keep in mind though that with blades/inlines you want as much ankle support as you can get, and most shoes simply don't offer a lot of ankle support so your shoe choice will be key with these.
Jun 5, 2011. 8:38 AMbeeedy says:
I've actually built quiet a few pairs of shoe-skates before and this is an awesome instructable! one suggestion however is to build a wooden sole for your shoes, especially with such narrow plates. It will help make the sharp turns and severe leaning a lot more comfortable because with such a floppy sole you will be able to feel the plates. also you won't have as high a chance of the sole of your shoe ripping out!
Jun 5, 2011. 10:48 AMSpokehedz says:
You can also use a plastic cutting board from Walmart for $3.
Jun 5, 2011. 8:53 AMgreatpanda says:
I was wondering about that...
Jun 5, 2011. 9:19 AMbeeedy says:
Yea it works great! just remove the insole of the shoe and trace it on to either 1/8" or 1/4" plywood and cut it out, sand down areas so it fits nicely into shoe and then redrill your holes through the wood. Then see if your local rink will be willing to give/sell you a pair of skate insoles for on top of the wood (just a piece of felt actually) and slip them in on top of the wood soles! and tada! If inserting a wooden sole your not gonna wanna start with tight fitting shoes however so if your shoes were tight to begin with I would not recommend doing this. if the shoes fit perfect or were a little big this would work perfect then!
Attached is a picture of one of my skates that I made, only difference is I bought all parts new rather then buying a used skate.
Jun 5, 2011. 10:15 PMbeeedy says:
Yeah that is also a possibility, keep in mind though that most shoe insoles are actually pretty thick, and with the addition of the piece of wood the shoes will most likely no longer fit correctly, hence the thin felt insoles. Tell us how yours go though!
Jun 5, 2011. 8:39 AMimatoymaker says:
Very cool! I did that about 25 years ago with a set of Converse high tops. I was the envy of the skate rink. Took a few rounds to get used to the floating on air feeling. Plus I didn't feel as worn out after the session. Got to say though I like the Vans better.
What I did to bolt the shoes to the plate was to use flat head bolts and fender washers on the inside. I had to trim the fender washers so that they would not lay on each other or rub against the sides. I also made a counter sink dimple in the washer by using an extra flat head bolt inserting it through the washer and setting on something with a hole that the flat head could pass though and then hammering on it to dimple the washer until the flat head was flush with the washer without distorting the bolt head. This may take some trial and error.
For the outside I used a standard flat washer and poly lock nuts. The poly locks work better than a lock washer because you can adjust how much compression you have on the sole of the tennis shoe without distorting it or fear of it coming loose at an inconvenient time.
Thanks for the pleasant memories. I have been inspired. Now to go make some new ones.
Jun 5, 2011. 7:23 PMBtheBike says:
i have on those exact ol' school suede Vans now =)
weirdness.
Jun 5, 2011. 6:39 AMpdub77 says:
Dig!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:tk1314
