Introduction: Variable DC Power Supply for <$15
Variable DC power supplies are critical to many electronics projects. You'll never have to go out and buy dozens of different single-voltage power supplies or battery configurations with this new unit. Professional units can cost hundreds of dollars, but now you can make one for less than $15!
Step 1: The Parts
These are the parts you will need:
  • LM317 Voltage Regulator ($0.50)
  • 0.1 uf Mylar Cap (~$0.10)
  • 1 Axial Electrolytic Cap (~$0.20)
  • 220 Ohm Resistor (~$0.05)
  • 5K Potentiometer ($1.00)
  • Cheap Voltmeter ($7.95)
  • Enclosure ($1.65)
  • Power Supply ($2.85)
Total Cost: $14.30
Not bad for a homemade variable DC power supply!
Step 2: The Variable Voltage Regulator.
Start by making the variable voltage regulator. Refer to the schematics below.
Step 3: Adding the Digital Readout
Adding the digital readout is really simple! Just open up your multimeter and solder your output to the test leads. Add a switch to the battery. And that's it! You're done :D
Step 4: You're Done
Test it and have fun! Put it in an awesome enclosure like I did to impress your friends :)
