Variable Voltage Regulator Using the LM317
3,226
37
Posted
Introduction: Variable Voltage Regulator Using the LM317
hello,
today I’m gonna show you how to make an adjustable voltage regulator with the LM317.
Step 1: Watch the Video
The video is in my youtube channel Chris' Project. LInk:
Step 2: The Schematic
Step 3: Buy All of the Components
The components for this project are:
1pc old credit card.
1pc LM 317
1pc heatsink
A screw
1pc 10k ohm potentiometer
1pc 1k ohm resistor
1pc switch
Red and black wires
And a couple alligator clips
Step 4: Put the Heatsink on the Mosfet
Put the heatsink on the LM317 with the screw so the LM317 will not get hot.
Step 5: Glue the Components to the Credit Card
Glue the LM317, the switch, and the potentiometer to the old credit card.
Step 6: The Connection
Solder the resistor to the adjust pin and the output pin. Then connect the adjust pin to the middle pin of the potentiometer, the output pin to the red wire, and the input pin to the other red wire.
Step 7: The Last Connection
Finally, connect the left pin of the potentiometer to the black wire, and the alligator clips to the output wires. And the switch to the red input wires. And we are done.
Step 8: Testing
Now I’m gonna connect the input wires to a 12V power supply and the output to my multimeter. If I turn the potentiometer the voltage will go up and go down.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
3 Comments
superrrrrr kid
nice,and read what the say(ask)to make it more better,then it already is.
greetings from a fan
hey, seems like you forgot to connect the switch?? Over all good effort for showing how the LM317 works. Keep posting more.
The circuit does work and is about 100 (give or take) years old.
It is good for teaching people that are not familiar with the LM317 how to make it variable. I would strongly suggest, to make the schematic logically obvious, put the input on the left with the +ve on top, -ve (ground) on the bottom and the output on the right, +ve on top, referenced to ground. R1 simply goes from Adj. pin to ground in the middle. Much nicer on the eyes.
