Step 3Variations: Coordinates
iImage Information
In the classic version of the game, the end score is calculated by adding all of each player's respective territory of squares. The player with the higher number of squares wins. However, to make the game more interesting and strategic, a coordinate system can be used, to assign different values to different squares, thus forcing players to make moves that will value 'heavier' squares over ones with less value. A coordinate system can be used in two ways. 1) Two sets of numbers on both the horizontal and vertical walls of the board. The square's value is calculated by multiplying the numbers on its horizontal and vertical axis. 2) There is only one axis of numbers along the side; along the other are letters, to make it easier to call out squares if need be. In this system, each square in a row has the value of the number on it.
Note: This game is also a good way to practice your multiplication if you feel the need.
