Enter vegetable juice! I wanted a pop of color without harsh chemicals in the house. I was inspired by some cranberries that leaked juice on the table to try a juice stain.
I am by no means a professional when it comes to wood, so please if you are going to try this test it in an inconspicuous area and make sure you and your (parent, spouse, whoever) agree to try it :)
Step 1: You will need
Vegetable/fruit juice (amount will vary depending on what you are covering and how many coats you want to do)
clean paint brush/foam brush/cloth rag for applying stain
bowl for your stain
damp cloth that you don't mind getting stained
object to stain
paper towels for spills/small cleanups
masking tape if you only want to do part of your object
optional: oxygen bleach in case you get any juice on your clothes/other fabric, and gloves if you need your hands not to be colors for a day or two
Step 2: Make your stain
You can use a variety of fruit and/or veggie combos to get different shades of greens, reds, purples, probably oranges .... feel free to experiment!
I have read you can cut up vegetables and simmer them for 4 hours or so (adding water as necessary) and strain that off to create a stain as well. I think directly juicing would give you a darker stain but either way should be fine.
I did 3 generous coats on my entire table and a 4th coat on half of it. My table, with leaves in, is approximately 7 feet by 3.5 feet. I used 12 or ounces including any spills and what was left in the foam brush when I was done.
I would advise making more than you think you need, because this will be a completely custom color for you and running out part way through would be sad!
Step 3: Prepare your surface
I wanted a two-tone effect, so I masked off the trim on the table top.
Also, be sure to clear this project with anyone who thinks they own the table. Princess approved.
Step 4: Start applying!
Work in manageable sections. For me, that meant a quarter of the table at a time, which was nicely delineated by the seams where the leaves get added in.
Let this set for 5 minutes.
Step 5: Wipe off
You will need to let the section dry for a bit (20 or 30 minutes for me) to be able to accurately see what color stage you are at.
Step 6: Stubborn Areas
With some careful work I was able to overcome the slight seal, so I thought I'd show you in case you ran into something similar.
First, I would gently press my foam brush into the table top, getting a puddle of stain on there. Then I would very gently dab, with my brush perpendicular to the table, across the sealed area. By moving slowly I was able to get coverage so that the stain could work into the wood better. Some areas still resisted stain after doing this in multiple coats, but not very big areas when all was done.
Step 7: Keep going!
For this first coat, keep doing the 5 minute rest before you wipe the excess off. You can adjust time after you see how the first coat takes.
Step 8: Build up your color
If you like it at this point - awesome! If not, add a coat. Remember to let it dry to gauge where you really are with the color.
At this point you can also adjust the wait time before wiping. For me, I let the leaves (the middle half of my table) sit 10 minutes on the second coat because it was not taking the color as fast as the outer parts.
Keep adding layers of stain, wiping them after 5-15 minutes to get up the excess, and letting it dry to verify the color until you are happy with the color depth.
This was most of the way through the 3rd coat on my table. When this dried we removed the leaves and I did one more coat on the ends.
Step 9: Admire your work!
Step 10: Clean up any over-stain
The stain was still partly damp. I was able to scrub it down with a wet paper towel and dramatically lighten the spots. Your mileage may vary - mask well if you are making!
Step 11: Clean up!
I accidentally used a dish cloth from a new set for wiping between coats. I gave it an oxygen bleach soak as soon as I was done with the last wipe down. It came clean very well.
I jarred up the unused stain and put it in my freezer, just in case I need to touch anything up before we seal the table, or if we decide to stain more of it.
Anyway, there you go! Unsealed this will probably fade a lot, faster the more it is in the sun. However, it is a fun way to play with color and add your personal touch to some furniture, without introducing harsh chemicals into your home.
I hope you have fun playing with this and feel inspired to experiment! And please, again, be sure you have permission to try this on whatever you are trying it on! My hubby thought I was a little crazy for wanting to try it but he was totally ok with me doing so. He does really like the color now that it is done!
Visit Our Store »
Go Pro Today »
And this definitely needs some sort of sealant over the top. When it gets wet, the color does lift. We need to do some work on the table so I haven't been able to seal it yet (hubby wants to sand it for part of the repair, kinda silly to finish it first). It still doesn't smell or anything weird like that, I am very pleased!
but when it is very young(less than 2ft tall) it is picked, cooked and eaten like any other form of greens so long as the stalk is fully green.
http://www.instructables.com/files/deriv/FPO/6HJ2/HD4VF8WK/FPO6HJ2HD4VF8WK.SQUARE.jpg
We have not noticed any smell or any extra flies. Granted, we just hit our first big cold snap here (down into the low 50s outside during the day) so it isn't as big a fly season as June would be. I would imagine what fruit/veggies you chose would affect that - some are going to be more sugary than others.
So, perhaps if you live somewhere hot (which I do) this would be a better cool weather project, so you could properly let it dry before sealing it. But I do recommend sealing it especially if you think it will get wet.
Thanks for the link - it'll make it much easier to reference later :)
I like how you left the border unstained to get a two-tone table top.
I really like the two-tone as well. I was a little unsure if it would work with the final color but it really makes it pop.
