3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Vehicle efficiency upgrades: 30+ MPG in 2.5ton commercial truck
Step 2Improving aerodynamics
This is what I did on my 1983 F-250.
Not everything will be directly applicable to your vehicle. Modify and improvise as appropriate.
-I added an underbelly panel to smooth airflow beneath the vehicle made from Coroplast (corrugated plastic - the stuff cheap signs are made from). It is attached to the front bumper, and about 1/2 way back with cut outs for the wheels to turn, and a cut out for oil changes (and to avoid the hot exhaust manifold).  Then there are smaller pieces anywhere a pocket of air could collect, while letting the transaxel and muffler plenty of space.
-I built some homemade wheel "skirts" (wheel-well covers) to improve aerodynamics. The current  are made of cardboard coated in layers of aluminum tape, and then painted and edged with velcro. I lined the wheel well with velcro, and stuck 'em together, then taped over the seams with clear tape to cover the gaps of a less than perfect measuring and cutting job. These were originally just supposed to be a test, but they held up to a winter of rain and months of hauling, so I have no motivation to replace them.
-The headlights come in a little scoop. I had covers custom cut out of thin Lexan plastic, which is totally clear, scratch resistant, flexible, and nearly indestructible (the same stuff my custom motorcycle windshield is made from). I traced the headlights and brought the tracing to Tap plastics who were able to cut them for me in about 5 minutes. I drilled holes in the corners and screwed them onto the grill so I can easily remove them if a headlight burns out.
-I taped over the front turn signals, (because tape is cheaper than Lexan.)
-I removed the windshield wipers (inc. the entire arm). They come off in a few seconds with no tools. I keep them inside the cab, just in case I get caught in unexpected rain.
-I installed a tonneau cover which, in addition to increasing the trucks aerodynamics, will keep small loads clean, dry, and protected, making it a (semi)legitimate business expense.
I cut triangles out of plywood to mount the cover's rails at an angle, so that it tapers down from halfway up the window to the tailgate.
Having it angled this way makes it much more aerodynamic (I picked up about 1-2mpg just from tilting the cover), but having it go only 1/2 up the cab instead of joing at the top of the roof means I can still see over it and don't lose any visibility to the rear.  It rolls up so I still have full access to the bed when I need it.
31 comments
May 12, 2009. 1:01 PMswoopsdad says:
Actually, having been in the automotive industry for almost 20 years I feel the whole tonneau cover, tailgate up or down aerodynamics issue needs to be put to rest at last. When the box is empty the most fuel efficient state is without a tonneau cover and the tailgate(solid) in the up position. This is because the truck has a bulit-in laminar airflow to it when empty and in this configuration. Simply put, this means that the airflow created in the bed of the truck acts like a cushion to keep the airflow from the front above the bed until it gets to the rear bumper. By putting a toneau cover on(or leaving the tailgate down) it disrupts the laminar airflow creating downwards pressure on the bed(or rails) of the truck. This results in a higher drag coefficient and therefore higher gas consumption.
Sep 4, 2011. 1:39 PMpddonovan2011 says:
You are correct, there is only one modification that could be done that would make the 'tailgate up/bed empty' mileage even better! From the top of the tailgate to the bottom o the lowest part of the bumper make a perfect radius or half dome on its side. Create round Plexigalss or Lucite covers with this same radius to cover the side taillights and you will complete the laminar flow on the tail will Actually be pushed along at highway speeds!
Jun 17, 2011. 2:45 AMzolar1 says:
This would be vehicle specific. I have a 2009 Ranger. Tailgate up - 18-20MPG.
Tailgate down - 24mpg.
Oh, Mythbusters has been caught outright lying about a great many things. And intentionally skewed results from a lot of other things as well.
Great entertainment, but please do not believe anything they say. They do it for entertainment value only.
BTW, how come no one has done an experiment with the tailgate removed?
And another one with those cargo straps for a tailgate?
Sep 4, 2011. 2:23 PMpddonovan2011 says:
I HAVE, how's this for vehicle specific!
2003 Chevy S10.
I have an iPhone App that reports real time MPG via the OBD2 port.
No tailgate, 29.8 mpg!
With tailgate, 30.3 MPG!
With hard Fiberglass Bed Cap 30.7 MPG!
With thin Plastic vehicle specific,'Cab-hi Shell, 30.6 MPG.
With the tailgate and the Shell Hatch removed, 30.8 MPG.
With a round tail-cone installed and sealed to the rear of the bed and shell, lots of duct tape!, 31.2 MPG.
These tests were made at the same time, during the same commute, down the same highway and reflect the average collected during a FULL WEEK of commuting for every result!
The Saturday before each of these weeks, the battery was disconnected, overnight, to reset the computer in the truck. This way the computer relearned the trip for that week. The ONLY modifications made were to the rear of the truck.
I have not yet tackled the front of the truck! I could change the grille, the head lights, use clear tape to seal any 'dirty' gaps. remove the windshield wipers. I could really go nuts with this stuff! But the truck has the 4.3 V6 and Over-drive Automatic. I KNOW I am doing damned good with the MPGs I am getting!
Aug 14, 2011. 2:07 PMFuzzyBearGeek says:
omg. Are you one of those paranoid type people? They do it for entertainment porpoises only? Wow. Floored.
Do you believe dinosaurs didn't exist too?
Aug 14, 2011. 9:24 PMzolar1 says:
LOL. Of course dinosaurs existed.
But Mythbusters is strictly an entertainment show, nothing more.
Fun to watch them blow up stuff.
And no, I am not the paranoid type. I am more of a doubting thomas of sorts.
If I cannot recreate their experiments with the same or very similar results, then their show is a farce.
There have been complaints with them about some of the things they show.
Maybe googling 'mythbuster lies' could be of use?
Feb 6, 2011. 11:40 AM13blue says:
There was a great "Mythbusters" on this that proved the same thing. Empty bed with the tailgate up was the way to go. Also the windows up with the air con on is more efficient that with the windows down. I had to adjust my driving for both of these.
Aug 14, 2011. 2:08 PMFuzzyBearGeek says:
I love your brain. :o)
Jun 27, 2009. 3:14 PMkikiclint says:
I have been turning my truck off going down hills on the free way. I can definitely tell a difference when I have my canopy on. It slows me down. With it off I have to keep my foot on the breaks to stay in the speed limit.
Jun 16, 2009. 1:59 AMjoeofloath says:
That is true of newer vehicles, but remember when this truck was designed, aerodynamics weren't even tested. The first regular (IE not a race/performance car) car to really be looked at from an aerodynamic perspective, as far as I know, was the European Ford Sierra. In older trucks, It would be more efficient to keep the tailgate up and use a tonneau cover.
Feb 24, 2010. 6:51 PMAdvokit says:
(removed by author or community request)
Jun 14, 2010. 5:39 PMunkledave says:
hello, i just happened to stumble upon this site and was reading through some of the posts and was intrigued. great site and good posts, but i'm writing in regards to the 'cold engine' post that jacobaziza wrote. you say that cold air is not the same thing as a cold engine, and i don't want to step on any toes or to seem disrespectful in any way but i have to disagree on several points. you said that cold air is denser than warm air. true. the air molecules in cold air are more densely packed, so in effect you are getting more air per cylinder full. more air means more fuel must be added to maintain the proper stoichiometric air/fuel ratio so that the combustion will be neither too lean, nor too rich. a hot engine receiving cold air will produce less power than a cold engine receiving cold air if the air/fuel mixtures are correct. remember, 2 things in the engine are creating heat, friction of moving parts and air and combustion. yes, air can create some very high heat from friction. take the sr-71 blackbird jet. at mach 3.2 (2,436 mph), the inside of the windshield reaches a temperature of 250 degrees F. that's much hotter than the temperature water boils at sea level at tropical temperatures. the jet's outer surfaces get well over 500 degrees F, so besides just creating drag, air can create heat. and since i'm on the subject of drag, i must also correct you on the post where you said: "However, regardless of gearing, there is an upper limit to efficient speed imposed by aerodynamic forces which increase exponentially with speed above around 40MPH or so." aerodynamic drag exponentially increases from the get go, not just at 40 mph. a doubling of any mph (10-20, 30-60, 50-100, 100-200) will quadruple (not double) the aerodynamic drag, and in order for a vehicle (same vehicle with the same aerodynamic drag) to double its speed, it will need 8 times the horsepower to do it. that is why it is so easy for a streetbike like a stock suzuki gsxr 1000 to hit 100 mph (it will do about 104 mph in first gear stock) but it can't hit 200 mph because of this aerodynamic/horsepower ratio. on to the cold vs. hot/warm motor facts. a hot motor gets hot partly because of friction, but mostly from combustion. if friction were the primary source of a motor's heat, it would wear down in a matter of a few hundred miles or less. during combustion, the heat of the burning mixture is moved out of the combustion chamber/cylinder area, but not before some of that heat has transferred to the surrounding parts. heat is transferred to the spark plug, the head and valves, the engine's block, and the piston (which transfers heat to the wrist pin bearing and wrist pin, connecting rod, lower rod bearing, then to the crankshaft. since oil is saturating all of these parts, the oil picks up a lot of this heat also, and that is why the oil/oil sump pan will be very warm/hot even though it's the furthest from the combustion chamber and has colder air blowing past it (providing air is allowed to flow under the vehicle). all around the engine, radiator coolant is also being flowed. in the head(s), the block, and ends up in the radiator which is mounted at the front of the vehicle to get the coolest air possible to blow through it and cool the radiator fluid via a heat exchange with the incoming cooler air, where the hot air is then blown straight back on the hot motor. i find this to be less than efficient and think that if you have the option, mount the radiator somewhere else where cool air can flow through it, and let that hot air being emitted from it blow straight out the back so it does not heat up the engine. even just a radiator hose will cool down the fluid to some degree. i once did an experiment using both clear hose and standard black hose on a smaller 2 stroke motor. my engine ran a lot hotter with the clear hose and i could wrap my hand around the hose and not get burned, yet when i touched the radiator, it was hot. i then switched back to the black hose and my temperature dropped quite a bit. the black hose (total length of 6 feet combined to and from the engine/radiator) acted like a sort of radiator of its own. they say that black objects attract heat, and i used to think it only related to light wavelengths, but from that experiment, it may apply to all forms of heat. an engine is basically an air pump. the more air (and correct ratio of fuel) you can pump in and out of an engine, the more power you will have. a normally aspirated engine will only be able to take in so much air until it reaches its limitations of induction. that is why when engines (and their operators!) require more power, forced induction is used. superchargers, blowers, and turbochargers will force more air into an engine by means of either impellers, or vanes (fins). superchargers and blowers are considered parasitic devices as they run off of a belt to the crankshaft, so they use power to make power. a turbocharger is also a parasitic device, but much more efficient as it runs off the pressure generated by the hot exhaust gasses exiting the motor. the closer you can mount the turbo to the valves, the greater the power ratio increase will be as the air is hottest and most expanded closest to the engine. if running a large turbo, running it further from the engine will result in more turbo lag as the larger turbo requires a lot of exhaust volume to get moving quickly, and if mounted further away, those hot gasses are allowed to cool somewhat and decrease volume. for those in search of even more power, oxygenated fuels and additives are used. nitromethane, nitropropane, nitrous oxide, and even to some extent, methanol. you wrote that a cold engine is less efficient and that is why diesels have glow plugs. not true. the glow plug is simply to ignite the mixture which is harder to ignite at lower temperatures. a diesel engine works by ignition by compression, unlike a conventional 4 stroke gasoline engine which works by ignition by spark plug. those knocking sounds you hear from a diesel engine are the same detonation sounds you hear from a car that is running a fuel who's octane rating may be too low for its compression. the parts of a diesel engine are built extra tough so it can handle this operation of detonation running. a normal motor would not be able to handle this as detonation is exactly what it implies, an explosion. a gasoline engine is a controlled combustion over a given period of time. once hot, a diesel engine does not need the glow plugs to start (although they do help). while a cold engine may give you more total power (in the racing world), i can't say with certainty what temperature a high mileage engine would benefit from the most, but it would seem that fuel burning efficiency is one of the priorities. also, the reason people had to 'warm up' old motors with carburetors is because unlike computed fuel injection, the carburetor had set jetting which delivered a given amount of fuel regardless of the temperature of the air being drawn in, and the temperature of the motor. that is why carburetors were given manual or vacuum chokes. a choke is simply to a supplemental fuel delivery system to enrichen the air/fuel mixture for a time until the temperature of the air being delivered into the engine matched the flow of gas through the jetting. you can look at it as a warm motor will draw in warm air as drawn through the warm metal of the carburetor, intake manifold and the warm engine block. also, remember than anytime air is compressed, it develops heat. as in an engine, this rapid compressing of air instantaneously heats up the air and even a modest 9:1 compression ratio of a 2 stroke motor will burn your skin pretty badly. imagine that a motor that is running at say 6,000 rpm. that means that a 4 stroke will have 3,000 combustion cycles per minute, and that comes out to 50 compression cycles per second. that's compressing the air in the cylinder in 1/50th of a second, which means that it gets very hot. a modern 4 stroke motorcycle like a yamaha r-6 600cc engine has a redline close to 16,000 rpm! that's 8,000 compression strokes per minute and comes out to 133 compression cycles per second. even more amazing is the 2 stroke motors i have built that redlined at 13,000 rpm, but since a 2 stroke fires every rotation of the crank (a 4 stroke fires every other rotation), it was doing 216 compression cycles per second. compressing air/gas at that fast rate will heat it up a lot. sorry, got a little off track there. so, a cold engine is more efficient in terms of power (unless you're running a full drag nitromethane rail/funny car which requires that the motor be hot so that the oxygen released from the nitromethane is burned more efficiently for power. all that flames you see shooting out of a dragsters exhaust is unburned nitromethane. a lot if not an equal amount of the nitro's combustion happens in the exhaust pipe, thus producing all those fantastic flames we all love. you also wrote that a cold engine had nothing to do with the air intake temperature. that too i have to disagree with. a cold intake means that the air drawn through it will be cold too (if the air is cold). if the air is warmer than the cold intake, it will cool slightly, if it is colder than the intake, it will warm slightly. this is due to the 2nd law of thermo dynamics in which simply says that energy naturally flows from "more concentrated" to "less concentrated", more concentrated being colder and less concentrated being hotter. so, if an engine is equally as cold as the intake charge, then the intake charge will flow to the combustion chamber at the same temperature where it will be denser. if the intake is colder and the engine is hotter, the law states that the colder intake will draw heat from the hotter engine and become hotter and expand for less density. and in regards to your statement that the air intake temperature normally does not come from the engine compartment, this is only if your engine's intake system is equipped with a cold air intake system which draws air from the outside of the compartment. if it's a traditional motor which draws air from within the engine compartment, it will be hotter, which will make an engine run hotter as the hotter air is compressed, making it even hotter than before. your statement that power does not always translate to better efficiency is also something i have to disagree with. let's take gasoline as an example. it has a very specific btu (british thermal unit) which tells us what kind of energy will be released with it is burned. the key to efficiency is not how much fuel is burned, but how efficiently. was all of it burned during the combustion cycle? or was some of it passed out the exhaust (potential power lost out the tailpipe)? was the stoichiometric air/fuel values on the rich/middle/or lean side? a lean burn will give you more power due to the greater temperatures expanding the gasses more, but at the expense of engine heat. if you can get rid of that heat (great cooling system) then you have no problem. but if you can't, the heat will rise higher and higher. ask any serious go-kart racer. they have adjustments to lean out their motors for ultimate power, but can do so for only so long before they have to richen up the mixture to cool down the engine. what happens is that in a 2 stroke motor, there is no regular engine motor oil. the only lubrication it gets is the oil that is mixed with the gasoline, like a 2 stroke weedwhacker machine. the fuel/oil is moved through the carburetor/injector, down the intake and past the reeds, into the crankcase where it lubricates the crankshaft bearings/connecting rod bearings, and the piston/cylinder below the piston rings. as the piston travels downwards, it compresses the mixture (because the reeds have closed and the air/fuel/oil mixture is now trapped in the crankcase) until the rings/top of the piston move down far enough for the transfer/boost ports to become uncovered and the pressurized mixture is then shot through these ports and now find themselves above the piston, lubricating the cylinder walls/rings above the piston. this is the only lubrication it receives. if the temperature rises too high, it starts to burn off this ultra thin oil barrier and metal to metal contact starts and if not corrected, will result in a seizure. the metal from the piston, which is about 65-70% aluminum and 30-35% silicon (to limit aluminum expansion) melts onto the steel/iron of the cylinder walls. as can be imagined, this is some very bad damage. but i'm getting off track once again so let me get back on track. one key i don't see mentioned in your quest for ultimate mileage is cam timing. in a 4 stroke motor, the cam is what determines when the valves will open (cam timing), how far they will open (cam lift), and how long they will remain open (cam duration), and considered by many to be the heart of any motor. it also determines how much of the fresh intake mixture is allowed to flow into and through the exhaust (to help cool and to ensure a fresh intake charge by purging as much of the old burned mixture out of there), and this is called 'overlap', or in the world of engine builders and cam degreers, "lobe center angle". if an exhaust valve opens too soon after combustion, the energy that is used to force the piston down/turn the crankshaft around will be lost out of the exhaust when it still had power to be used. if it's opened too late, the remaining pressure will hinder the intake charge's flow as part of the flow is also inertia (weight of suspended fuel particles in the air/fuel mixture) which is why intake manifolds such as 'tunnel rams' were used to optimize the inertial flow of fuel. while not 'the' answer to high mileage, it is a very important part of it. other areas are, vehicle weight, vehicle aerodynamic profile (drag, downforce, high/low pressure areas), tire size (contact patch, compound, tread pattern, more on this later), compression ratio, piston design, combustion chamber design (swirling patterns, squish velocity), valve size, valve seat cut angles (3,5,7 angle, more on this later), intake system size/design, exhaust system size/design, fuel delivery system (fuel atomization, very important), ignition timing, spark plugs (many designs to choose from as well as temperature ratings), spark temperature, spark thickness, spark duration, number of gears, width/depth of gears, gear angles (helical cut vs. straight cut), drive train from trans to wheel, lubrication, bearings (this can make a huge difference), engine running temperature, and fuel (pure gas or gas with ethanol) are some of the things to consider. it is well known that alcohols will not give you the same mpg of gasoline. it has (depending on your source of information) anywhere from 76k btu to 84.4k btu while gasoline (again depending on source of info and gas grades) has anywhere from 112,000 btu to 125,000 btu, but most sources list 125,000 btu so we'll stick with that rating. for gasohol they list the btu at 120,940 btu. so, if you're running gasohol, right off the bat you're losing about 3.24% of your btu, which doesn't seem like much unless you're on a quest to get the most mpg out of a gallon of fuel. but jacobaziza's post is on his biodiesel vehicle. so my alcohol portion is just for the people who run gasoline and wonder why their mpg has fallen. getting back to tread pattern, a lot of people don't realize that the design of treads not only help divert water away from the center of the tire during rain, but they also catch air as they rotate. i believe that the air caught by these treads may be more of an aerodynamic drag than the windshield wipers and un-taped lights and turn signals combined. don't believe me? i use a freespinning motorcycle tire balancer to balance tires. these tires have much less tread and are not as numerous or deep as some car tires and most truck tires. i got the air hose with a nozzle and pointed at the tire and a shallow angle and shot air across the surface. i had attached some reflective tape and used a non contact tachometer to measure the wheel's rpm, then calculated the rpm with the tire's rollout in inches and just from an air hose i got that tire to spin more than 35 mph. i then did the same test on a motorcycle racing slick with no tread pattern and even with no treads it still got spinning to 6 mph. air friction. also, a motorcycle tire has a nice round profile unlike a car's flat surface profile so i'm sure that a car/truck tire is creating quite an aerodynamic drag. as for the valve angle cuts, most valve cuts are what they call a 3 angle cut. besides providing a good seat for the valves when they close, the angle and thickness of the cut also determines how much heat is transferred to the valve (if exhaust) as the gasses rush past it. the 5 and 7 angle cuts are basically just trying to 'round off' the edge as much as possible for a smoother air flow. as far as fuel atomization, it is very important to get those fuel drops to break up into as fine a particle mist as possible for large drops will not burn anywhere near complete in the time span given, and the smallest particles will. while a smooth polished surface not only looks cool, it helps air flow with the least resistance. however, for the intake tract, smooth polished surfaces are frowned upon because it is said that they allow the tiny fuel particles to fall out of suspension and create larger unburnable drops. whew, i did not know how much i had written and apologize for its length, but i hope that it will have helped some people in knowledge. if any of my information is in error, i would like to be corrected as i'm interested in truth and if the correction is logical and valid, i'll gladly accept it as my new truth for i am always finding new truths that better my life and hope that in some small way, i have bettered yours. i wish jacobaziza and the rest of you the best of luck in your quests and hope that you achieve them. best regards to all, david really sorry it's so long, didn't realize it until i just read through it.
Jul 4, 2010. 7:49 AMJoenavy85 says:
Absolutely, colder temperatures do not support proper combustion. I work for the US Navy in an engineroom that uses a 700 PSI Boiler. We use Marine Distillate Fuel and steam atomization, along with 2 large steam turbine driven fans for combustion. If the automatic boiler controls control the fans at too high of a speed it will cause the boiler to "smoke white" but what we see on the firebox camera isn't smoke but unburned fuel. Too much air cools the atomized fuel to the point where it won't ignite (keep in mind the fuel that does burn burns at around 3000 degrees F, and the firebox walls and floor/ceiling are about 1800 degrees F), And that is just the air coming in causing that, imagine if the sides of the firebox were cold as well.
Jul 5, 2010. 7:49 PMAdvokit says:
Aug 9, 2010. 7:53 PMMikeyBBB says:
Your right, but you have a completely wrong point. The whole point of this post is about fuel economy, not making more power. Warmer air yields less power but higher fuel economy, which is the end goal of this modifications. Winter MPG Vs. Summer MPG.
Feb 6, 2010. 10:27 AMGreenD says:
My 2000 Kia Sportage gets the highest MPG at around 69mph, around 26-28.
If I drop to 60, I get around 24, and if I get up to 75,80mp it drops to 22.
Whats up with that? Does it have to do with the computer chip?
Feb 11, 2010. 7:01 AMJohnMichael says:
Cars are geared to run more effeciently at certain speeds.  A number of years ago it was usauly 50mph.  The speed limits have changed and gearings in newer models have probably changed in response to the speed limit changes.
While it is true that driving faster than the rate a vehicle was geared to be most efficient at will reduce MPG, driving slower does not always improve MPG because vehicles are designed to run at certain speeds.  The vehicle described in this Instructable is a 1983 model, and was probably designed to be more efficient at 50 mph rather than 60 or 65.
Mar 3, 2010. 8:21 PMpfun41 says:
how did you figure out the optimal speed? my 94 bronco has a 4speed auto overdrive trans. at 60 im already in top gear
Mar 4, 2010. 6:14 AMGreenD says:
The way I figured this out was I went on a 3 hour road trip. Now, I haven't looked at elevation maps but I'm pretty sure it's "fairly" level. What I did was: 60mph one way - about 22mpg. and 69-72 the way back which averaged out to be 24mpg.
On a second trip of same length I went 75... this then went down to 22 again.
I also was not aware of wind direction on any of the trips, I also hyper miled on some and tagged behind semis which worked slightly... but I don't think is actually worth the risk.
May 20, 2010. 11:42 PMnerys says:
Drafting semi's has HUGE impacts on FE !!!
I was able to cruise at 65 mph IN my 94 XFI metro WITH a trailer massing over 500 pounds and still score 55mpg by drafting semi's
its NOT risky unless your a nimrod. That semi CAN NOT out brake you.
I don't care HOW hard he slams on his brakes I don't care WHAT he hits. Your brakes won't even have to work hard to "out brake" a semi.
its simply physics simple inertia.
as long as your back far enough to account for "reaction time lag" and a little more for safety you are perfectly safe.
What if you fall asleep? the issue their was you falling asleep not your distance to the semi.
I will tail a semi at 45-50feet without hesitation. If I have the CB and "get the ok" from the driver I will cut that to 30ft and get some SERIOUS FE improvements (and dramatically reduced noise since I am in his suck zone)
I get behind a semi so he can see me and call out to him. Hey mr trucker in the estes semi. I the little blue mouse behind you.
You mind if I snug up behind you while you punch some atmo for me.?
They get a chuckle and almost always say "have at it little mouse"
May 27, 2010. 3:47 PMBrianJone5 says:
 Did you know they hate 'Trucker'? No? You sure?
May 21, 2010. 9:22 AMnerys says:
It might be an interesting experiment though. Even without over drive the aero effect is SO huge that it might offset the higher RPM's  (ESPECIALLY if you can gear it down some !)
as for truckers. I understand. suddenly someone it right on your butt and you have no idea why. You can't see them You don't know what they are doing or why. Yeah I can see how that would freak them a little bit.
so anytime I want to get close enough that they can not "see" me in the mirrors anymore I always ask permission.
Jul 4, 2010. 8:07 AMJoenavy85 says:
I've actually done this with my Rolling Brick (2005 Jeep Liberty). I drafted behind a Semi about 2 seconds back, and turned off my overdrive (don't shifted a gear for you stick shifters) and my scangauge II said 39 MPG, when i turned the overdrive back on it dropped to 35 MPG. with the overdrive off it operated in a higher power area of the power band and provided better volumetric efficiency. NOTE: EPA ratings (which don't really mean much in mind) for my jeep are 17 city/21 highway
Feb 11, 2010. 7:22 AMJohnMichael says:
In many places it is illegal to drive a vehicle without the windshield wipers regardless of whether or not it is raining.
Nov 19, 2009. 7:38 AMHmff says:
Why dont you put the air dam on the inside of the car with a non flameble materal?
Apr 25, 2009. 7:13 PMshammallamaman says:
yay, you did added the underbelly :) (i have been following this instructable and it's comments quite a bit)
May 2, 2009. 8:28 PMshammallamaman says:
please excuse my incorrect english, i was just too exited :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
46
Author:JacobAziza
I am an ordinary guy. Except that I live in an RV, drive a 250cc motorcycle, have a truck that runs on bio-diesel, am vegetarian, and have had almost 30 jobs in 10 years, including armored truck drive...
more »
