3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Vehicle efficiency upgrades: 30+ MPG in 2.5ton commercial truck
Step 4Facilitate coasting
Facilitate coasting
Driving with the engine off provides a couple challenges:
The ignition switch isn't designed for such constant use, but more importantly the power steering and power brakes go out.
(Note: Laws vary from state to state. In CA it is illegal to coast downhill in neutral. It is not illegal to coast with the transmission in gear, but the clutch held in.)
-I installed an electric vacuum pump to run the power brake booster.
These were standard on a number of late 80s American full-size cars, so I was able to pull one from the local wrecking yard. This change removes a drain from the engine (diesels have a belt driven booster pump) and prevents the power brakes from going out whenever I shut the engine. Stopping a 2 1/2 ton truck with just the power of your calf muscle is doable, but can be somewhat challenging.
-I switched to manual steering. This both removes the parasitic drain of the power steering pump from the engine, and means that the steering is not affected by shutting off the engine.
-I wired in a kill switch and remote starter onto the gear shift lever which means I don't need to use the key at all.
The switches I got from the local electronics place are dual purpose: wire them one way and they are momentary open, wire them the other and they are momentary closed. I used one each way, so that one stops fuel to the engine, the other triggers the starter. I mounted them side-by-side in a block of scrap wood, attached to the gear shift with a strip cut out of a steel can lid.
As I had hoped, they definitely make coasting downhill and killing it at red lights much faster, simpler, more precise, and safer, then using the key each time (especially since the ignition on this truck has been very finicky as long as I have had it) which encourages me to do it a lot more often.
If you happen to own a 7th generation (80s) Diesel F-250, and you want to wire in a kill switch or remote starter:
The thick red wire with a green stripe goes to the injector pump (for a kill). Wire the switch normally closed in series with the red wire. Since I didn't have any wire as thick as the one I was tapping into, I used two thinner wires in parallel.
The thin red wire with a blue stripe goes to the ignition relay (for a start). Wire it in parallel to a normally open switch. The other end of the switch goes to 12v positive. Ideally find an accessory (no key off) circuit. Some accessory circuits drop voltage slightly due to their load and therefor aren't strong enough to trigger the relay. I ended up wiring to a constant hot lead, which means the starter can be turned over even with out the key in (not a big deal, because it won't catch)
25 comments
May 16, 2011. 2:17 PMbahi says:
I admire you work and effort. I wish I could do the same here in Spain, but such radical modifications are illegal.
But one of the most important things we all can do is driver slower, it saves fuel and the most important thing, lives.
Max speed has been temporary lowered here from 120km/h to 110, and most of the people are raging against it, it's sad to tell, but most of the people don't really care about Self-sufficiency, environment or other peoples lives...
Anyway thank you for your great instructable.
p.s. I have a pickup too but I also ride a 250 bike or bicycle to work :)
Dec 21, 2009. 10:59 PMpete82291 says:
Im sorry but I have to put this out there. At first I was verry interested in reading this instructable. From 15 to 30 mpg that sounded great! Until I read the step involving removing parts of the engine. I was a bit skeptical when you made your turck "more aerodynamic" The grill has an opening like it does so the radiator and engine can get air to help with cooling and perofrmance. The fan is needed for the colling system, Removing the power steering not sso smart idea for such a heavy truck. If this is a farm truck not driven on the raod this would be a great project but for saftey reasons I do not belive a vehicle modified like this should be allowed on the road. Its unsafe and many of the engine componenets are missing. If you want to drive a truck like this one just buy a 50's model. Go to Montana they got lots of them for sale!
Jul 4, 2010. 3:26 PMunkledave says:
i have to agree with pete82291 in that removing the power steering is dangerous. you say that the only time to tell there is no power steering is when parallel parking or doing a 3 point turn. i disagree. i say that even turning right or left after starting off from a stop sign will give considerable more resistance. doubt me? let me see you do your turn using 1 finger. that's how much easier power steering make turning. sure, when you drive you won't need the ease of power steering 99.9999% of the time, but just that .0001% of a time when a kid runs in front and you need to swerve, or something falls off of a vehicle in front of you, or a driver in the oncoming lane is reaching down to pick up a cd that fell on the floor and has drifted into your lane, that split second of having your power steering functioning or not may make a difference in someone's life (yours and theirs) and the outcome may be totally different had you the power steering enabled. you're quest for high mileage is good, but as always, safety first!
Aug 14, 2011. 9:16 PMzolar1 says:
Hmmm. I have health problems that necessitate power steering, air conditioning and automatic transmission.
I also live in the northern half of the US. For over 6 weeks the daytime temps were in the mid to upper 90's with a heat index of over 100.
If I were healthy, I still would need air conditioning to ensure I would stay healthy due to the things I do.
I drove vehicles without a/c, auto, and without PS. It sucked. And better MPG? Not hardly. It took more engine rpm's for me to park those vehicles and engine running time too.
I even had a Geo Metro with a stick. They claimed 45 tp 50 MPG. But due to the hills where I live, I could barely get 30mpg.
So, when I switched to an automatic my MPG stayed the same.
The power steering and A/C increased my productivity and I could do more instead of fighting the heat, thus offsetting the cost significantly.
Now, I have a small ranger with auto, A/C, PS. PB, cruise, and a 4 cylinder.
It gates the same MPG as one without all that stuff. About 18MPG on average.
If I lived in Kansas where it is nearly all flat, I could probably get by without the auto and maybe the PS, but not the A/C.
According to the experts you get better fuel economy on the highway running the a/c that if you didn't and had the windows down (air drag).
I tried a long trip one day. One without the a/c and windows down and one with.
With the A/C and windows up, I managed to get 28mpg. With the windows down and a/c off I got 20mpg.
Stop and go traffic or slow moving traffic on the interstate kills your gas mileage.
Steady speeds on the highway, but not more than 55MPH would yield the best MPG even with the A/C running.
One way to gain significant fuel economy is to get rid of on demand traffic light sensors & go back to the timing method.
Another way is to eliminate all multi-way stop signs at intersections - someone should always have the right of way. Why hold up dozens of cars just to let one person get out because of convenience?
Artificially low speed limits kill gas mileage too. Best mpg for most vehicles is around 48mpg.
Making a road that can easily handle 55mph and setting the speed limit to 35 mph does not help with fuel economy. It only serves to act as a revenue generator for greedy cash strapped political subdivisions.
About vehicles in the 70's.
I had a 1966 Ford Galaxy 500 with a 289 in it. I drove 55MPH on the highway for 400 miles one way at a constant speed. I got a whopping 20mpg out of that car, and the car weighed a LOT. It had none of the pollution control garbage on it like vehicles do today.
The government and oil companies are who makes the fuel economy so low. The addition of ethanol is supposed to reduce pollution. In fact, it makes more pollution due to trading unburned hydrocarbons for carbon dioxide a greenhouse gas.
Give me 100% straight, quality gasoline and I can get 20% better fuel economy thus reducing our dependence on foreign oil.
Driving in the cool evenings during the summertime can also give better fuel economy due to denser air and higher humidity.
I could write all day about this topic, but there is nothing I can do to change anything. I just watch how hard I step on the accelerator and try to time the red lights.
Dec 13, 2010. 8:58 AMKevanf1 says:
He, he :) nice ible, extreme but nice. For those naysayers I would suggest looking at the Land Rover utility vehicle. Prior to about the late 1980's (this is a generalisation so please nobody go nit picking) Land Rovers were manual steering. Some people modded them to accept power steering from the more upmarket Range rover. Like your truck Landies are difficult to steer when near enough stationary but no problem when on the move. Ok, you can't use 'one finger' to steer but as you say, that's simply not safe. Land Rover added power steering to the Defender range because of customer demand. It is purely a comfort item not a safety one. That said I'm actually adding a power steering box to my 40+ yr old Landy but that's because I have arthritis and find it difficult now to park up.
As for plating up the front. As long as the radiator can get it's flow of cooling air then you don't need a grille at the front. Take a look at the old Austin/Morris Mini. I've owned two of these and they have the radiator at the right hand side of the engine (when facing the engine from the front). The fan draws air in from beneath, from the front grille if it can and from the wheel arch area. Most people boarded up the front grille anyway because rain used to get straight on the foward facing distributor and cause the old Mini to stop due to no spark at the plug.
Have you considered putting a sloping cover over the back of your truck? The slop going down from the roof to the rear. I just wonder if it would help with air flow efficiency? Just a thought..
Take care.
Kevan (over in the UK if you hadn't guessed)
Dec 14, 2010. 1:23 AMKevanf1 says:
I must have missed that one :( Sorry. Did it make any noticeable difference? I would imagine that it must do something as it would stop the 'swirl' effect of the airflow over the rear. Without a cover there are a lot of 'pockets' that can trap and slow down air movement but without any positive effects.
Along similar lines, have you ever seen the aerofoils that some truck drivers use? I've seen them over here in the UK and I believe they use them over in Europe. I don't recall seeing pictures of any in the US though? Again, just throwing some thoughts in the wind (bit of brainstorming).
Good work mate, keep it up.
Take care.
Kevan (still in the UK)
Dec 15, 2010. 2:40 AMKevanf1 says:
It sounds like the same thing. In very basic terms it's a bloody great big piece of either fibreglass or possibly ABS plastic that is stuck on top of the cab at an angle of around 45 degrees (don't quote me on that though as it's a guessestimate). A lot of lorries have them over here (UK) but I haven't seen them in the US. However, I have to qualify that by saying I have never actually visited your country (would love to someday but my wife will not fly, I will and have right to the other side of the world) and only seen traffic scenes in tv and movies.
Anyway, yes, I think we are both talking about the same thing :) I have seen a smaller version used to smooth air flow over a standard roof rack/roof bars on cars. I will be making one for my Land Rover when I put the roof rack back on it. I need to get the brakes working and the clutch all piped up again first though :)
Take care mate.
Kevan
Dec 14, 2010. 1:42 AMKevanf1 says:
Just had a look at the rear cover, very nice. I hadn't given rear vision a thought as I don't have any in my Land Rover (it's an old military ambulance without any rear windows). Excellent mate :-)
Take care.
Kevan
Aug 7, 2010. 8:15 PMrallen71366 says:
I really appreciate your 'ible.
I recognize many of the suggestions from ecomodder.com, and I applaud your dedication and skill.
I just wanted to make a few comments on power steering and aerodynamics. I used to drive a "Deuce and a half" - 2.5 ton truck when I was in the infantry (Mechanized). It also didn't have power steering, just "armstrong". I did almost break my thumbs driving off-road with a load, and running up on rocks would apply force back to the steering wheel, but I learned, and never once did I ever have any incidence on pavement. I also had a Fiero sports car without power steering. It was so small and light, it didn't need it.
And for the "naysayers" regarding the importance of your aero mods, they need to google Craig Vetter, a motorcycle industry legend, and read up on his "real world" efficiency contests, where a motorcycle rider, on mixed city streets and tracks, got well over 200 mpg in traffic. In the 80's.
I've been noticing on a lot of discussion boards, not just here, that some people are so worried about "safety" that they're too afraid to even light a propane grill. Please don't misunderstand, I do advocate safety. I also advocate growing a pair, and taking life by the throat and letting it know you're in charge.
Thanks. For the 'ible, and your efforts to spread a little education to the people around you.
Jun 3, 2010. 2:15 PMpecosbill42 says:
As an old gear head from the 50's I find it hard to understand how you can safely get 30 mpg on an old Ford 3/4 ton.  The late model cars and trucks are getting more mpg than they ever did and have more power.  I just hope that you don't drive this truck where you are endangering other peoples safety.  Sounds very risky to me, but good luck on your project.
Jun 4, 2010. 5:27 AMpecosbill42 says:
I would never dispute your mpg, but based on over 40 years in the automotive industry I find it hard to understand how you can get 30 mpg out of a 3/4 ton truck of any kind regardless of modifications unless you are driving unsafe. i don't believe that coasting down hill with the transmission disengaged is safe, but I have been wrong before. As I said in my first reply I wish you well and hope that you continue to get the great mpg.
May 14, 2010. 3:01 PMzomfibame says:
I like your 'ible, and I do agree that many things that add to comfort on a car are not for safety, they are just for luxury. I very much like your idea of making the underside of the truck more aerodynamic by putting the corrugated plastic under it. I can see myself doing that to the back half of my old truck at some point. ..... one thing I would remind people of though is, if you live in a very humid place (as I do) you might not want to remove the AC compressor because it is part of the defog system. on humid mornings and rainy hot days with steam rolling up off the asphalt the AC compressor can be cut on, (in some cars it is automaticly engaged with the defogger.) the AC is a dehumidifier and this dry air helps to defog the windshield. I did not have a car with working AC till' I was in my 30's so I know it is not NEEDED; but believe it or not,  in some places like the SC coast it does add to the safety factor. ...just something to keep in mind if a person lives in this kinda' climate. ...on the other hand if I was living back up in the northern midwest I'da taken my AC compressor off (of at least my truck) years ago. anyhow, cool instructable!
May 20, 2010. 11:29 PMnerys says:
many cars DO NOT HAVE AC - the ac dryer helps with defogging its not required. hundreds of thousands of cars work just fine without AC.
though I have had ZERO luck with defogging fluids. Not a one I have tried yet works in fact many seem to CAUSE fog.
May 23, 2010. 3:20 PMkill-a-watt says:
try a bar of glycerin soap like generic neutrogena (or in a pinch any bar of soap)
  - Clean the window for best results. It must be dry in any case.
  - get a rag, get it barely damp (dry except for ONE SPRAY from an atomizer, or dry except a small amount of condensation wiped from the window )
  - Rub  the rag on the bar of soap to pick up a bit of the stuff
  - Apply to your window, maybe a 1-2 square foot area
  - Buff with rag, (or a clean spot on the rag if there's too much soap applied) until clear.
  - If you EVER see suds, your doing it wrong, it's way too wet. If you can't get the window clear because of haze from the soap, try just a bit more water on that rag.
  - reapply as needed, maybe every 2 months. I keep clean dry old towels in the car to apply the stuff and newspaper and spray window cleaner to pre-clean the glass
  - Keep the bar of soap in a reused plastic food container with a tight fitting lid. I use hot-and-sour soup container from carryout.
  - works for mirrors in bathrooms too
May 20, 2010. 9:02 AMbeberly37 says:
 Did you track your mileage before and after each step?  I have a 1971 F100, which is similar in size and shape, but with a gas engine and a weaker suspension.  I get 14mpg on the highway and that never changes.  I did an air dam over the grill, electric fan on a manual switch (which only needs to be used in stop and go traffic), I have driven with and without a bed cap, it is a bit of a dog, so I don't accelerate hard or drive fast.  The only thing I have not done is the wheel covers, the under belly pan or remove PS.  I still get 14mpg.  I do however plan on swapping a 5-speed overdrive transmission soon.
Also they do make low rolling resistance tires for trucks, but they are advertised as high mileage tires.  I have 80,000 mile tires on my truck, which accomplishes this with a low friction rubber and tread pattern, just like low rolling resistance tires.  They are awful in snow, but I can't complain otherwise.
May 20, 2010. 11:18 AMnerys says:
until the introduction of ethanol it was not uncommon for me to go months with virtually zero change in FE from tank to tank. My van got a rock solid 19mpg pretty much no matter how I drove it (within reason)
When E10 came to my locale well the sh$t hit the fan 13mpg is normal now. Whenever I am out of state and can get E0 it goes back to 19mpg almost immediately (depending on how empty it was when I filled it) by tank 2 on E0 its 19mpg again.
My Jeep went from 22-23 mpg to 17-18 mpg
My minivan went from 28mpg to 20-21mpg
My Metro gets 57-58mpg on E0 On Wawa Gas (its about E8 usually) I get 47-48mpg on "joes gas" ie no name gas 10-13% Ethanol I get 36-42 mpg in the same car
part of the reason SOME of us see very little deviation is we have a very long and extremely consistent commute. Previous to E10 I did not even see a more than "noise level" drop in FE in the winter time.
my commute is 54 miles one way 6 days a week. (thats how I got 494,000 miles on my 88 Cherokee :-)
Ethanol sucks big time. You want to see a big boost in FE with your gasser? see if you have an E0 stations around you. Trust me. DO the math and its worth paying more for E0
I get 48mpg on E10 which means I can go 480 miles on 10 gallons.
If I take that same 10 gallons of E10 and REMOVE the gallon of ethanol from it (I use water mix forced phase separation to do this ie just dump some water in a tub of gas mix it up let it settle and remove the water (which now has the ethanol in it instead of in the gas)
you end up with 9 gallons of E0
I put that 9 gallons in the car and I get 55mpg or 495 miles from 9 gallons.
SO I can actuall go FURTHER ie pay less money per mile if I remove the gallon of ethanol from E10 and THROW IT AWAY and just drive on the 9 gallons of left over nearly pure gas.
Go figure. Newer cars are not hurt so badly (3-5% losses) but the older pre 2004 especially pre 2000 cars are hit BADLY. and if your a TBI and older its even worse!
I can get E10 in Nj for $2.72 I can get E0 up in the mountains (when I am their I bring home 10 gas cans full) for $2.89
So E10 costs me 5.6 cents per mile while E0 costs me 5.0 cents per mile
so in a year (40,000 miles for me) I save $240 by buying $2.89 E0 over $2.72 E10.
And this is in my METRO !!! I did the math for my Van. Its scary.
20.9 cents per mile on E10 and 15.2 cents per mile on E0
Cost Burden of E10 in my Van is 5.7 cents per mile extra in other words compulsory E10 COSTS ME $2,280 a year in EXTRA fuel expense!!!
The metro cost me $1000 after repairs to put it on the road. So now you know why I bought a metro.
heck the BURDEN increase in fuel costs for the van is greater than the COMPLETE fuel burden in the metro on E10
the LOWER you fuel economy the more Ethanol hurts your bank account.
Jun 23, 2010. 6:09 PMhawkeye.tech says:
So when you 'throw it away' where do you throw it? Do you just pour it down the drain, or skip a step and dump it directly into the river?
May 20, 2010. 12:21 PMbeberly37 says:
 This might make me sound crazy, but I done care about the price of gas.  All I care about is my environmental foot print.  I like old cars because the impact of manufacturing them is long gone and keeping them out of the dump/scrap yard is also good for the planet.  I only drive my truck about 2000 miles a year, so I don't spend all that much on gas.  I go out of my way to find ethanol gas because it greatly cleans up the emissions of my pre-catalytic converter, pre-EGR engine.  I actually converted my truck to run on E85 and despite the 40% hit in FE i took, I spent the same on fuel and had the carbon footprint of a car that got 70mpg.  But since moving to an area without E85, i have since switched back to gas and still get a consistent highway mileage of 14mpg, empty or full of stuff, cap or on cap.
May 20, 2010. 1:14 PMnerys says:
I am sorry but your mistaken. Ethanol gas on anything but NEW cars creates MORE emissions and is dirtier for the environment.
Think about it. Your burning "MORE GASOLINE" so automatically your creating MORE emissions and a larger footprint.
In my van Ethanol means I need 838 MORE gallons of E10 per year over when it was E0 that means
I need to burn 83.8 MORE gallons of ethanol and 754 MORE gallons of Gasoline Every single year because of the usage of ethanol.
If the MPG loss from ethanol was less than 10% it MIGHT be possible to reduce emissions and environmental foot print via ethanol usage.
if you have a flex fuel vehicle OK it might reduce emissions.
but on your admittedly older vehicle you are creating DRAMATICALLY more emissions and a dramatically larger environmental foot print by using ethanol based fuels (UNLESS you convert to run E85)
Your truck uses about 142 gallons of fuel at 14mpg. I am betting you would get 18-19mpg on pure gasoline (its physically impossible for your fuel economy to NOT change between E10 and E0)
So on pure gas you would only need 105 gallons of gas a year.
SO because of ethanol your burning 37 MORE gallons of gas every year and 37 gallons worth MORE emissions and foot print per year.
thats just not logical. and its more expensive. Unlike you I drive 40,000 miles a year so my "cost per mile" is very important to me.
I learned a "green" trick. If its not cheaper its NOT green. Period.
if it costs more money its "fake" green.
May 20, 2010. 6:34 PMbeberly37 says:
(removed by author or community request)
May 20, 2010. 11:21 PMnerys says:
I am burning 20-30% MORE FUEL.
I don't care how much cleaner the ethanol burns the 18% to 27% more "actual gasoline" I burn in the process or burning that 10% ethanol is NOT going to burn cleaner.
MORE emissions. your studies and tests are on engines that PROPERLY and EFFICIENTLY burn Ethanol.
Try doing those same studies on cars NOT designed to burn ethanol and get back to me.
I BARELY passed my nox test. 10% ethanol I can NOT pass NOX 8% ethanol I passed (wawa gas at the time was about 8% ethanol)
so now I know from now on when I get inspected make sure I am running E0
you CAN NOT burn 20-20% more fuel and tell me its cleaner unless you can magically make these engines orders of magnitude more efficient somehow without changing anything mechanically.
in a 2010 car off the show room floor. SURE you might lower SOME emissions by using ethanol (did you account for the emissions to CREATE that ethanol??)
take any pre 2004 car and run the same tests and let me know what you get.
what percentage of the cars on the road today are pre 2004?
May 21, 2010. 6:26 PMbeberly37 says:
Why do you keep bringing up your car?  I told you why you get less mileage in some fuel injected cars.
My point is that in my truck, which doesn't have a catalytic converter to reduce CO or EGR to reduce NOx, E10% helps a lot.
Also, you have no idea what studies I was referencing so you do not know what engines they were using.  The one in particular was using a commercially available spark ignition engine designed for gasoline, not optimized for E10 and they ran on a wide range of air/fuel ratios and ignition timing.  I am not around the computer that I saved those papers on, but by all means next week I will post them so you can see for yourself.
If you can not pass smog with E10, then there is something wrong with your car.  You probably have a minor vacuum leak, a stuck EGR valve, a failing O2 sensor or a catalytic converter that is about to fail.  Either way, all modern cars are EPA certified and are guaranteed to work on E10, check your owner's manual.  New, your car probably had no problem passing smog on E10, otherwise it would not have passed EPA certification, which means that if it doesn't pass smog now, then something needs to be fixed on the car.
As for burning 20% more fuel, I don't.  I have not seen anything but measurement noise with or without ethanol in the gas and I can tell by the smell of the exhaust that it is cleaner and if a human nose can sense it, I would venture to say that it is probably at least an order of magnitude.
Why do people alway argue about the emissions from making ethanol?  No one ever mentions the emissions for making gasoline.  Drilling, shipping around the world, and refining oil is not a clean process by any means.
Why is 2004 so special, is your car a 2003?
I have messed around with newer cars (remember, mine is a 71 so most cars are new from my perspective).  I helped a friend with a 91 CRX pass smog by adding 10% ethanol to pump gas, which already had 8ish% to begin and I got a 92 jetta to pass smog by adding 20% ethanol.  I'm not saying that tricking smog is the best thing to do, but every engine is designed differently and every engine wears differently so what happens in one or most, might not be true for one.  There are always outliers.
But I only buy E10 because I know that at least 10% of my fuel was made in the US and in my 1971 F100, I get better emissions on E10
May 21, 2010. 8:31 PMnerys says:
"But I only buy E10 because I know that at least 10% of my fuel was made in the US and in my 1971 F100, I get better emissions on E10"
for MOST of us here is the FLAW in this logic.
lets do the math. lets use my best mpg but normal car my minivan 28mpg on E0 - Average person (I drive 40k a year) drives 11k a year.
so in 1 year you would consume roughly 393 gallons of gasoline.
SO what about E10. 354 gallons of gasoline and 39 gallons ethanol right?
WRONG.
with E10 your now getting 21mpg if your REALLY careful and if you use LOW ethanol gas (on joe's gas I get 18-19mpg) but lets be generous here so we will use the better 21mpg.
Now your using 523 gallons of E10 a year or 470.7 gallons of Gasoline and 52.3 gallons of Ethanol.
so sure your now spending money to buy 52.3 gallons of USA made Ethanol but your now buying 77.7 MORE GALLONS of foreign oil gasoline than you were BEFORE ethanol !!!
Do you not see how screwed up this is ?
I would really love to see actual unbiased test data for your fuel economy on the track with E0 and E10.
I would be a years salary you are putting out signigicantly MORE emissions per year. you might be cleaner "per cycle" but your not going to need MORE CYCLES to cover the same miles. IE more pollution not less.
if I lower pollution 10% but increase the cycle counts by 20% well you get the idea.
the only way you could be burning cleaner is if your fuel economy dropped LESS than 10% on E10 from E0.
I contend that short of modifying your vehicle this is impossible for a 1971 vehicle.
Feb 11, 2010. 7:20 AMJohnMichael says:
In addition to being illegal in most places, many vehicles will not operate properly coasting with the engine off.  Modifying the power steering and brakes makes the vehicle less safe.  Doing so makes the vehicle more dangerous not only for the driver, but for those in other vehicles around them.  If you are ever in a collision with another vehicle you will probably be faulted for driving an improperly maintained vehicle.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
46
Author:JacobAziza
I am an ordinary guy. Except that I live in an RV, drive a 250cc motorcycle, have a truck that runs on bio-diesel, am vegetarian, and have had almost 30 jobs in 10 years, including armored truck drive...
more »
