Introduction: Venison Sausages
Picture of Venison Sausages
From field to kitchen, showing you how to make home made venison sausages!
Step 1: Preparing the Meat
Picture of Preparing the Meat
Without going into to much detail, the first step is obviously to get yourself a source of venison. This is a Samba deer that I shot recently and with much respect and without wasting any venison, the meat was harvested from the animal. Leaving the meat to hang in the coolroom for 5 days allows the blood to drain.
Step 2: Ingredients
Picture of Ingredients
The first step in any cooking effort is obviously to gather all the necessary ingredients. With venison sausage making, it is important that you mix fat through the concoction as venison is a very lean meat that when is cooked becomes very dry, so, rule of thumb is to add of 30% pork fat and 70% venison accompanied with 1 cup of iced water. When adding flavours to the sausages choose spices and herbs that you enjoy, for instance, I added curry in one batch, and chilli in another. Now the main ingredient, the skins, personally I use natural skins as they seem to not burst as easy in the filling stage, and when being cooked. however, the only down side being the varying circumference of the intestine that creates fatter sausages, any local butcher would sell sheep intestines (which is the snag casings).
You will also need mixing bowls, a meat mincer with the sausage filling attachment and a lot of time.
Step 3: Mincing
Picture of Mincing
Alright, now that you have all the ingredients it is time to start. first you need to run the venison through the mincer, I like to use a medium sized mince, which is around 4mm. After you have minced the venison now mince the pork fat.
Step 4: Flavouring
Picture of Flavouring
As listed earlier you should pick flavours that you enjoy, firstly you must mix 30% pork fat mince with 70% venison mince along with the flavours you wish to add and 1 cup of iced water different flavours such as curry and chilli do not require much of as they are strong, so in terms of quantitys it is hard to guess, however, there is a small trick I like to use, after you have mixed your minces and flavours you can take a small scoop of mixture and cook it and sample to see if it needs more flavour or more mince to tone the strength of the flavours down.
Step 5: Casing the Mince
Picture of Casing the Mince
the final step is to put the Mince in the case, and to do this you first must put the sausage attatchment onto your mincer, while you are doing this soak your natural skins in water as they are preserved in salt you want to get all this salt out of the skins. Now cut a length of skin around 1 meter, and slide it onto the sausage filler until you have 2 inches hanging off the nozel, now tie a knot in the end of the skin and slide the rest on, now add your mixture into the chamber of the mincer and on the surrounding tray, turn the mincer on and very steadily (not to fast) stuff the Mince down the shoot so that it fills the skins, with one person doing that the other must support the sausage and slowly aid it in filling by moving away from the mincer. After you have filled about 95cm of your 1m skin stop filling and again tie a knot in the end, to make sausage length sausages you can first pinch and then twist the pinched area to form a perfect snag! let the suasgaes sit over night in the fridge.
Step 6: Cooking
When cooking theses sausages venison takes a while longer to cook than your standard snags, depending on sausage width sometimes it is good to bbq the snag and then chuck it in the oven to cook it right through.
Robbzilla (author)2014-11-25
1 thing to add: Absolutely put in some Curing salt. I use Prague Pink. You don't want food poisoning after all.
JM1999 (author)2014-10-11
Nice, you can't use too lean meat or the sausage will split, there needs to be an element of fat in each one for it to work properly.
Nice deer and good job on the win!
Tecwyn Twmffat (author)2014-09-22
That deer will have enjoyed a much better life than anything found in a supermarket. Certainly better than the poor souls stacking shelves etc, not that I would eat them myself.
yes there is definitely a difference in taste of free range meat. The deer would have had a lot better life in the wild as apposed to farmed venison!
ssingh15 (author)2014-09-16
In our country, killing a Samba will lead us to Jail!!!!!!!
beluga4prez (author)2014-09-12
If I was to use straight pork, what difference should I make? Aside from not adding all the extra bacon fat
stoobers (author)beluga4prez2014-09-15
You may still need to still add fat to sausage. It is hard to get meat that is fatty enough at the store. I go with 60% meat, 40% fat if you want to grill. 70/30 if you boil the sausage.
The change: use a very course grind for the pork. Pork tends to squish into a paste when grinding and the sausage doesn't have much texture without a coarse grind.
beluga4prez (author)stoobers2014-09-15
Great info. Thanks.
billstar414 (author)2014-09-15
thebeatonpath, hard sausage? is that like a venison salami?
ktrantham (author)2014-09-15
LOOKS YUMMY! Misspell in the title
thebeatonpath (author)2014-09-14
DROOOOLLLLLL! I can almost taste the deliciousness! Grew up on venison and love it to this day. Have you tried the hard venison sausage? My brother and another friend have had some made from their hunts and it was amazing! Your sausages would not last long with my family. Plus, no antibiotics, just natural meat. Great job!
Egav (author)2014-09-14
i'm not so happy whit you, human
jmyers1 (author)2014-09-13
A really good instructible. Venison sausage is one of my favorite ways to prepare our hoofed friends.
billstar414 (author)2014-09-13
hi beluga4prez, The leaner the meat (less fat in it) the dryer it becomes when it has been cooked, so adding fat makes the sausages more moist and therefore better tasting. As pork is higher in fat you will not need to add much extra fat to make your sausages perfect, I'm not sure of the exact pork to fat ratio but I'm sure you could find out easy enough.. hopefully I've answered your question.
Haha seamster, venison is not everyone's cup of tea however if I were you I'd try crumming thin venison steaks and frying them.. they'll love them!!
egladwell (author)2014-09-12
You should add this to the hunter-gatherer contest!
About This Instructable
15,275views
191favorites
License:
More by billstar414:Recurve BowCar Console Can Cooler!Venison Sausages
Add instructable to:
