Vent Air Redirector
1,258
16
7
Posted in HomeLife-hacks
Introduction: Vent Air Redirector
My bed is far away from my air vent, I didn't want to move my bed around my room just for the air to reach me so I instead created an air distributor for my vent from just a cardboard box. This will help you save money by cutting back on cranking your thermometer output settings.
Step 1: Get the Box
Find a box that's the size of your air vent, then cut a hole in the bottom of the box like in picture 2.
Step 2: Cut Other Holes
Next cut a hole in both of the sides of the boxes. In picture 2 there is a bigger hole I cut on the side. In picture 3 there's a small hole that has a flap that's seen in picture 4 that can cover it. The flap can control your air so that it can either come out both the sides of the box, or just one side of the box. The flap is a piece of cardboard strip with tape on the top that let's it fold up and down.
Step 3: Finish
Now the air comes out of the side like drawn in picture 1. I keep mine behind my dresser and it shoots at my bed, you can paint the box for a nicer look if you don't like the way it looks unpainted. Now you can save heat in the winter and ac in the summer. You won't have to crank your thermometer settings to max output anymore. Enjoy this essentially free hack!
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    7 Comments
    Wow! This is really creative. I have this problem, but I never would have thought of this! Nice job.
    thanks!
    one suggestion to make it more efficient. if you look at some air ducts the corners are curved to help direct the airflow. if you use a strip of cardboard in the top corner you can create a curve so there is less resistance for the air to come out. it may not be much but more air flow is more
    I think it would be even easier to just connect the bottom right corner of your picture with the top left corner using a straight flat piece of cardboard. That would cut the box in half and angle the air right out of the opening.
    Great idea! Add a little light weight ribbon to the opening so you can see the airflow!
    I like that. I used cardboard boxes to build libraty shelves until I could get real ones.
    Now put a knex sail car an watch it go!!
