3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Venturi Vacuum Degassing Apparatus for use in Rapid Biomedical Part Prototyping
Step 3Attaching the Vacuum hose: Drill a hole in the side of the container
Make a hole in the side of the container.
Instead of using a drill, you might consider heating the connector and melting your way through the plastic container. You might also heat the base end of a drill and melt it into the side of the plastic container. This will assure that the nozzle fits snugly.
When you have a hole in the side of the container, screw in the connector and then hot-glue or rubber cement the nozzle in place from the INSIDE.
This fitting has to be air-tight
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:siderits
