loading
Step 3: Adapting Monitor Mount
The metal monitor mount has tabs formed into slits to restrict its movement back and forward. To be mounted the tabs have to be bent out of the road. To do this I used a set of pliers to lever them out of the way- shown in the second picture. When the tabs have been bent out of the way the mount can be straitened out.
I then measured the 60 mm (the width of the wood) from the pivot point and made a mark with a marker. I then drew a cut line using a square for accuracy and clamped it in the vice to be cut. Note in the picture I have made sure the line to be cut is as close to the vice jaw as possible to reduce vibration when cutting.
I used a hacksaw to cut the excess material off but if you have an angle grinder this will be much quicker. Once cut it is a good idea to use a file and remove any sharp edges left after cutting.
To allow mounting of the brackets to the wooden frame with the M8 bolts an 8 mm hole must be drilled. On the brackets here there was already a hole that could be widened. If there is not you will have to measure and mark the centre before using a smaller drill to make a pilot hole. Once you have a pilot hole you can then drill it out to 8 mm. I have a small press drill but a hand drill would to the job fine.
<p>very very good work.</p><p>Very motivating :)</p>
<p>Really like this instructable. Very well presented and well implemented. Super idea.</p>
Very nice! Im looking to do something like this for my dual monitor setup. <br> <br>By the way, how did you get one taskbar to stretch across all of your monitors? All of the programs I found just put a new taskbar on each screen, thanks.
<p>there is a program named display fusion the is a free and a pro and a trial but you really only need the free to get the taskbar to stretch</p>
Thanks, I am in the process of redesigning it so I can get it machined. Ill post the CAD model when I am finished. New features will include level monitors across the horizontal plane, variable height adjustment and a refined look. <br> <br>The task bar is across all screens is a feature of the graphics card. It is Eyefinity enabled. Not sure how you would do it if you didn't have a dedicated graphics card.
Very good idea, love it how you worked it out, I might apply it to make a wall mount for my screens later on. Thanks for sharing.
projects such as the one I like the most. great ideas and functional
I have a suggestion for an improvement.&nbsp; I am so anal, I could not stand to have my monitors misaligned in the horizontal plane.&nbsp; Take the bottom outrigger arms for both the left and right monitors and move them &quot;underneath&quot; the bottom arm of the central monitor.&nbsp; Get longer carriage bolts for the outboard brackets and add appropriate nuts &amp; washers.&nbsp; Now, adjust the mounting bracket down to be horizontally co-planer with the central bracket.&nbsp; All monitors are now aligned.&nbsp; That reverse camel hump arrangement would bug the &quot;H&quot; &quot;E&quot; &quot;Double Hockey Sticks&quot; out of me. ;-)<br> &nbsp;It would be like passing by a crooked picture everyday that I couldn't fix.&nbsp; Otherwise, awesome ingenuity and execution.&nbsp; Two thumbs up!
Believe me I have not overlooked this problem! I am sure there is a combination that would have the monitors aligned horizontally. I did try several combinations during the build. I had it clamped to the table while I screwed around with it. <br> <br>The problem I had was time, when I cut the original individual stands there was no going back! I needed my computer up and running asap so I made the sacrifice of having them slightly out of line. There is only a problem from this when running full screen applications where you definitely see the continuity error from monitor to monitor. I mainly use my desktop for research, writing, media etc. so each monitor is allocated its own application and the alignment isn't a problem. In a way it is incentive to stay of battlefield and actually work! <br> <br>I appreciate the input though and will try something like you suggest when I get a chance.
Referring to step 5, last picture, add an intermediate &quot;elbow&quot; on each side made of three pieces sandwiched around the two. 130mm long should be about right. Holes are still 30mm from each end, so this should space the inner and outer arms apart by about 10mm so they can swing without interference. You will have a double elbow system for adjustments and your mounts will all be level!
I gotta tell you alasdair - that's a damn fine instructable. Beautifully photographed and laid out with clear simple &quot;how to&quot; steps. I imagine a tutorial like this is not accomplished in 5 minutes. Thanks for taking the time and energy to share it with us.
Only issue I have with the design is that to two outer monitors are at a different height form the center, not sure about you but this would drive me nuts. Overall a good design. <br>I would have mounted the brackets a bit differently to allow for them to be the same level.
hahaha...My OCD would also drive me mad ...but not like my friend Greg who had a three screen setup and one of the screen blew and because he he couldn't find the exact smae screen again...he went out and bought three new ones...
I sit at a computer most of the day and half the night. Early on, I was getting pains in my neck and across my shoulders. I sought out the help of ergonomic health advisors and found that the best position for your monitor is for the top of it to be at eye level. Also, the keyboard and mouse should be set on an articulated keyboard extender so that the line from the forearm to the palm of the and is straight, and the arms should rest gently on the chair arms. I tried all this and the pains went away within a day.
Very nice - well thought out, used existing and inexpensive common components, and well documented. I am thinking of making this for my post-graduate son as he is doing a lot of research via the internet with multiple monitors. Are you sure the wood you used was pine ? I ask because the wood in some of the photos appear oak-like. For myself, I would be inclined to use a hard wood like oak to lessen my concern about the wood splitting eventually at the elbows. But that is just me. I may also adapt it for wall mounting. I'll let you know how it works out if you are interested.
Thanks for the comment. As the wood comes from an old bed and it is very light in colour I presumed it was pine as it is a popular inexpensive wood. Now I have had another look it could possibly be beech. I am not exactly sure because it is not heavy and is quite easily worked. <br> <br>That is the reason I love this website, you can look at ideas and projects other people have submitted and adapt them for yourself. Id definitely be interested to see what you come up with to wall mount your version.
Nice Job!
Impressive. I would worry about the torque around the attachment of the horizontal arm to the vertical leg. And especially so if the desk sways with use. Where's a mechanical engineer when you need one?
Cheers Andrew, Yeah I think you are right, there is only a single bolt and the horizontal frame hangs from it so there is a lot of strain here. I don't think it is a major problem though. The point of failure would be the bolt and I think it would take a lot of swaying to sheer it. If had any worries I would not have monitors on it. <br> <br>You do have a good point though, I were to remake it I would have the horizontal frame in a slot so it would be supported from the bottom and the top.
Awesome project! I have made several simple monitor mounts and I have thought of something similar but I was over engineering the joints in my head and the use of thera bands are quite brilliant in your application. I may have to make one of these myself when I have the time. <br>Keep up the good work <br>Dan
Are you sure you needed all of those screws in the &quot;top hanger&quot;?
Very nice work! , looks awesome!
Thanks Roey, I've had a look, you have some very nice projects yourself!
You did a great job with the design and build with this. Is it pretty sturdy?
Thanks a lot for the comment. Moving the frame back and forward on the pivots is extremely secure, the hinged frames holding the side monitors counter balance each other. There is some flex but I have no worries of any failure from accidental knocks or bumps. In a way the mechanism will act as suspension. <br> <br>If you were looking for a really solid build you just need to use thinker material.
About This Instructable
50,445views
456favorites
License:
More by alasdair.robertson:Varifocal Triple Monitor Stand Easy Electrical Continuity Tester Jewellery Tree
Add instructable to:
