Versatile RGB LED PWM Driver
Step 10Assembly Step 7, LED
Next we install the 3mm LED.
This LED is simply a power-on indicator LED.
The LED has one lead shorter than the other. The short lead is the Cathode and it must be fitted in to the hole nearest the text "LED1" on the overlay as indicated in the photo.
You can fit the LED without bending the leads, or you might want to bend the leads through 90 degrees if you are mounting the board inside a box or case. This will then bring the LED into line with the mode switch S1 which is also right-angle mounted.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:peteg
