Versatile RGB LED PWM Driver
Step 2Identifying the kit contents
All the parts shown are supplied in the full kit available from http://picprojects.org.uk/shop/
The kit is fairly simple to construct, but you will need a soldering iron, solder, side cutters (long nosed pliers can be usefull too). If you've never soldered before, have practice on a scrap board before attempting assembly of the kit I also recommend checking out this Instructable 'How-to-solder' http://www.instructables.com/id/How-to-solder/
The board should be assembled starting with the smaller parts and working up to the larger ones. Install and solder into place one component at a time.
The MOSFETs Q1,Q2,Q3 should be left in the anti static packaging until you are ready to install them onto the PCB.
Resistors 1/4 watt, carbon film 5%
R1, R2, R3 120 ohms [brown red brown gold]
R4, R5, R6 10K ohms [brown black orange gold]
R7 1K ohms [brown black red gold]
R8 270 ohms [red violet brown gold]
Capacitors
C1 100nF mutilayer ceramic 2.5 pin spacing
C2 220nF miniature polyester 5mm pin spacing
C3, C4 100uF 25volt electrolytic capacitor
Semiconductors
D1, 1N4148 diode
LED1, 3mm Green LED
Q1, Q2, Q3 STP36NF06L, N-channel logic level MOSFET
IC1 PIC mictrocontroller preprogrammed with RGB PWM LED driver firmware
IC2 78L05, 5 volt regulator
Other parts
CN1, CN2 3 way 16amp PCB terminal block
S1 PCB mounting right angle tactile switch
8-pin DIP socket for IC1
Nylon PCB standoff spacers + M3 x 6mm screws (4 off)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:peteg
