3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Versatile and Low Cost Digital Counter
Step 2Testing and Disassembly
First, turn on your calculator and press: "+ 1 =" It should display "1." Now (This is very important), press "=" again. Does it read "2" as the answer? If yes, continue foreward. If not, you need a different calculator that will do this.
The fun part -- take apart your calculator. With any luck, your calculator uses a graphite pad to close the circuit on a printed circuit. Just like most keyboards. You want a calculator that you'll be able to solder onto - so if your calculator printed circuit is printed on a plastic - you're likely to have a lot of trouble (like I did).
Now locate the printed section for the "=" button and fire up the soldering iron.
4 comments
Aug 23, 2008. 3:40 AMmanicmonday says:
Oops. Correction. It worked for a few minutes correctly, then the stiff wire started causing the "=" to go off on it's own multiple times. So then I tried another wire that wasn't so stiff, and it worked for a few minutes, then stopped getting connection. So, unless someone knows of a glue that is also a conductor, then that kind of calculator doesn't work for this application.
Dec 9, 2010. 8:29 AMDIYShared says:
Look at my page how to do it with that kind of calculator: http://diyshared.com, click on Homemade Measuring Wheel. I have put also instructions on how to do a kind of conductive glue.
Oct 23, 2010. 3:40 AMbeehard44 says:
graphite mixed with glue will do the trick
you can shave pencil leads for the graphite, should be mostly graphite over glue
Apr 30, 2010. 12:25 AMXOIIO says:
Dec 23, 2008. 2:27 AMPyroMonger says:
there is a type of conductive glue but thats all I know on the matter. I don't know what its called or where you can get it from, sorry
Aug 22, 2008. 4:37 PMmanicmonday says:
I bought that exact clear calculator, and it was easier than another than had an actual PCB. I wasn't able to solder the PCB at all, and that was if I was right about the place to solder it anyway. It was very confusing. But the clear calculator was much simpler, and I noticed that there were holes at critical junctures. I placed stiff wire in the 2 holes that lined up with the "=", bent it double, and crimped it down. It was no problem.
Jan 21, 2007. 7:36 AMthejrb says:
yeah man i agree not sure were to connect the wires
Oct 15, 2006. 10:11 PMpolavision says:
can you post a picture of the wires soldered to the board? I'm not sure exactly where to connect them... thanks
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
324
Author:trebuchet03
I'm an Engineer in San Francisco. Mass producer. Former Intern. Rapid Prototyper. Sometimes, I post Instructables. My Favorite number: 42 By profession - I am an energy engineer. I count electrons p...
more »
