Introduction: Vertical Axis Wind Turbine Generator Diy!
HomeMade!!! Are you looking to build a Vertical-axis wind turbine! ok ,Two years of planning and Building this turbine it using some tools and scrap parts as the stepper motor to make a generator and various parts of steel to make chassis for turbine . Vertical-axis wind turbines are a type of wind turbine where the main rotor shaft is set vertically. During the night and the day, they accumulate energy from the wind. This arrangement allows the generator to be located close to the ground, facilitating service and repair. VAWTs do not need to be pointed into the wind! To support my "work" every little bit helps! click the "ADS" & THANKS for sharing...
Step 1:
FelipeR45 made it! (author)2016-03-04
great. What kind of motor/generator did u use for it? Thanks.
ETERNUR made it! (author)2015-12-23
That's great work. Alternative energy is always appreciated. :)
About This Instructable
3,146views
37favorites
License:
Bio: A big hello to all mankind! This is my channel I hope you can find here various interesting things on in Renewable Energy Technologies and ... More »
More by GEORGE CHANIOTAKIS:MAKE PERMANENT MAGNET SYNCHRONOUS MOTOR-GENERATORMake Wind Turbine High Voltage Die!
Add instructable to:
